| Thread Tools |
Rating:
Display Modes |
#16
Re: 2-Speed vs 1-Speed drivetrain
The ideal situation for us several years ago was to go with a 2 speed transmission, and use code to do "auto-shifting" depending on the speed of the robot.
It proved short lived when we started having roll pin issues with our shifter. Although there are now fixes to this issue, I still dont think that shifting often in every match is a reliably good thing to do. I say run as quick as your drivers can handle comfortably and give yourself the option to switch into a ~5fps low gear range in pushing situations. There are many more options available that you can buy compared to just a couple of years ago. Our robot this season accelerated much better vs. our 2013 robot. In 2015, we plan to run faster (add additional motors also), with the intent that our 5th year driver will be able to handle it and he wants to. Last edited by waialua359 : 13-05-2014 at 03:57. |
#17
Here is some data on 3 gear ratios and acceleration / top speed tests.
http://www.chiefdelphi.com/media/papers/2911 |
#18
So this year we ran a two-speed 4 CIM drive with auto-shifting, geared about ~11 in low and 16 or 17 in high, on 4 inch wheels. With the current auto shifting setup, would it be beneficial to make the low gear lower to accelerate faster?
So would an ideal system (barring weight and other limiting factors) be a 6 CIM two-gear drive, the low being only used for pushing, and high gear for everything else? I think this is what 254 used this year. Last edited by Abhishek R : 13-05-2014 at 08:20. |
#19
boy this is a mess
2 speed= Lets push stuff!!. yaya robot 1 speed 6 cim (13-14fps) = We don't have time to push, bum us and watch us run. (see 610/talk to Mr.Lim he is the MAN) |
#20
Everyone should try datalogging acceleration if they have encoders on their drivetrain, particularly with 2 speed transmissions. Depending on the ratios, there really is no difference in acceleration.
#21
For instance, if a weird situation occurred where a gearing of 5 fps did NOT slip the wheels in a pushing match, the breaker would still trip in about the same amount of time as if the gearing was 16 fps correct? Basically, the CIMs draw the same amount of current at stall regardless of the gearing so any stalling of a 6 CIM drive is just as dangerous. Am I right in that assessment? |
#22
That said, there's pretty much no traction material available that won't slip drive wheels with 6 CIMS geared for 5 fps. Drive trains are "traction limited" (wheels slip) for the most part. The amount of current drawn per motor while the wheels are slipping depends on your gear ratio. Going well above 40A per motor can trip the resetting breakers. Going well above 200A per system risks tripping your main breaker a bit too quickly. |
#23
Well....stall current is kinda stall current. The stall current per motor for 4 motors is slightly different than the stall current for 6 motors. Stall current for a 6 CIM system is about 75 Amps/motor and the stall current for a 4 CIM system is about 87.5 Amps/motor. This is because when you add more CIMs, the motor voltage will decrease. This voltage can drop to about 7.5-8 volts when stalling. The stall current cited in the CIM motor documentation (~131 Amps) is assuming the voltage is a constant 12 volts (not what we see in robots). It is correct that friction is what limits the stall current. Also, note that there's a difference between the static friction and kinetic coefficient of friction. In fact, you can even have just as much pushing power with a 4 CIM drive as a 6 CIM drive (if geared properly).
#25
I had always thought that, for things like pushing matches, voltage briefly dropped down to ~8 volts but then jumped back up to some value around 12. The battery should be applying a relatively constant voltage, so I don't see why the voltage would remain notably lower for any extended period of time. So yes, the stall current might be ~90 amps for short periods of time, but I am thinking that the stall current is much closer to 130 amps for most of the time in a pushing match. |
#26
However there is one other thing that makes a bigger difference on acceleration than most realize. That would be the number of rotating components (gears) in the gearbox. Typically a good 1-speed gearbox will have 1 or two stages and have 3-5 gears (2 small pinions). Most shifters have 2-3 stages with 6-9 gears (3-4 small pinions). Not only do the motors have to get the robot moving they also have to get the gears spinning. And in the early stages of the gearbox they don't have the mechanical advantage of multiple gear reductions to increase torque. This is made worse when the gears are steel not aluminum. Now whether or not that actually creates a noticeable difference, maybe not. However it certainly is something to keep in mind when designing a gearbox. |
#27
There is a lot of talk about speed in this thread.
There is no talk (yet) about designing for speed and still being able to turn well. There are extra variables in play here would make the fastest robots worthless without special consideration:
#28
This year we were having problems tripping our main breaker, and did a fair number of tests pushing against a wall. With a not-quite-full battery and the compressor running (i.e. pretty reasonable in-match conditions), we were only drawing ~50 amps per motor on a 6CIM drive when stalled. |
#29
The voltage the battery outputs is proportional to the amperage being drawn, and the resistance of the circuit. This is also known as ohm's law.
V=IR Although batteries are not always perfect voltage sources, you can use ohm's law to determine the voltage drop in your robot fairly accurately. If you were drawing 300 amps, and the total circuit resistance was .020 ohms, you would lose 6 volts. This does not fluctuate over time, it is directly related to the current being drawn. (ignoring temperature and other factors). Hopefully this clears things up. |
#30
![]() Here, they relate a voltage drop on current draw to a capacity fraction. Last edited by dellagd : 13-05-2014 at 17:47. |
