Go to Post As Murphy as my witness, things happen and will continue to happen. - Pavan Dave [more]
Unread 23-02-2003, 16:39
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
Image Discuss: Team 122 testing out the robot
Unread 23-02-2003, 16:42
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Cool design, there are only a few designs that I've seen that can protect the boxes, and move them, while they stack.
Good Job.
Unread 23-02-2003, 16:52
srawls's Avatar
srawls srawls is offline
#0122 (Nasa Knights)
srawls is an unknown quantity at this point
Send a message via AIM to srawls
Thanks for the kind words!
To tell you the truth, our lifter was expririencing problems when we shipped, so we haven't actually moved a stack over the ramp ... but we hope it works
We also have a ramp blocker, king of the hill unit that isn't attached right now. If you look closely you'll see some wires that aren't attached to anything ... that's what they are for.
Stephen
Unread 23-02-2003, 17:12
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
What are the Chiaphuas driving?
Unread 23-02-2003, 18:22
srawls's Avatar
The chiaphuas are in a gearbox with the worm gears, and they drive the manipulators which orient the boxes. It's hard to see in the picture, so let me explain the manipulators. One side swings to contact the low side of a crate, and the other swings to contact the high side of the crate. The one which contacts the high side has a rubber wheel (off a roller blade I believe) which through empirical testing helped us flip crates. We re-designed the manipulator 2 nights before ship day to be made out of lexan so that it could bend and touch the boxes at a higher position to generate more torque, but still start off low enough to go under the bar. The manipulators allow us (hopefully) to rotate crates around so we can pick them up, and also to bat crates against the wall or field barrier where we want them.
Stephen
Unread 23-02-2003, 18:37
Clanat Clanat is offline
Custom Title
#0753 (High Desert Droids)
Clanat has a little shameless behaviour in the past
I like it.
Edit/ Nice shirt too! /Edit
Former Co-Captain
Winner NW Regional 2002 and 2003
Unread 23-02-2003, 18:50
Scott England Scott England is offline
FRC #0118 (The Robonauts)
Scott England is a name known to allScott England is a name known to allScott England is a name known to allScott England is a name known to allScott England is a name known to allScott England is a name known to all
Nice, us alumns out in Bburg have been waiting to see this one for a while. Did I read correctly that you can go under the bar? Does that whole polycarb chimney rotate down 90 degrees? If so, for Bill and Ansel's next trick are they going to turn water into wine? Don't suppose we'll get to see any vids of it loaded before VCU. Just curious, do i see its only driven by the drill motors? Roughly how fast is it this year? Last question, does anything extend upward from that chimney to secure a stack that is more than 4 or 5 boxes high?
Sorry for the bombardment of questions, but somethings gotta help me put off working on my Finite Elements Analysis take home midterm.
~Scott
122 --> 401 --> 118
"The Earth is a very small stage in a vast cosmic arena. Think of the rivers of blood spilled by all those generals and emperors, so that, in glory and triumph, they could become the momentary masters of a fraction of a dot. Think of the endless cruelties visited by the inhabitants of one corner of this pixel on the scarcely distinguishable inhabitants of some other corner, how frequent their misunderstandings, how eager they are to kill one another, how fervent their hatreds. Our posturings, our imagined self-importance, the delusion that we have some privileged position in the Universe .... In our obscurity, in all this vastness, there is no hint that help will come from elsewhere to save us from ourselves. "
Carl Sagan
Unread 23-02-2003, 21:07
srawls's Avatar
You read correctly, we can go under the bar .... just not in this configuration. We can easily remove the "chimney" as well as the ramp blocker (not shown in the picture), and go into the match in our "under the bar mode." And if we could turn water into wine, I'm sure Mr. Wooward would be ontop of that
You are correct, we have two drills as the only drive motors. We use two servos to shift gears, and in high gear we are a little over 6.3 feet per second. Fast enough that we had to get Mr. Fahringer to waterjet some heatsinks to save our poor motors
And nope, we can only support 5 crates high with our chimney ... we use every single motor in the kit, so it's not like we could have easily made an elevator mechanism even if we wanted to (well ... we could have had a passive ratchet-like mechanism I suppose, but 5 high is good enough for us).
And since we didn't get any practice time on the 'bot, I'm afraid we don't have any video to share.
Can't wait to see team 401 in Richmond, especially since I'll be a Hokie next year!
Stephen
Unread 23-02-2003, 21:39
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
I like the sweater.
Unread 23-02-2003, 21:48
kristen's Avatar
kristen kristen is offline
PI loves you!
#0639 (Code Red)
Team Role: Human Player
kristen will become famous soon enough
Send a message via AIM to kristen
Originally posted by JosephM
I like the sweater.
Is the sweater supposed to be some sort of joke? LOL because I don't get it. -_-
Anyways, impressive robot, it resembles ours. Our frame is the same basic shape.
Is the robot not able to go under the bar with the plastic stacking feature? What is you robot's strategy if you were to take it off?
Unread 23-02-2003, 21:51
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
"Pardon me, do you have any cheap, yellow mustard?" - lol
Unread 23-02-2003, 21:54
srawls's Avatar
Thanks for the complement on the shirt. We got new shirst this year, so they're kind of a big deal for the team. Especially since they cost 25 dollars a piece! (/me goes and grumbles some more)
And I'll pass on your comment on Ansel's sweater. We all love his yellow mustard sweater! I think I overheard him say it had about a pound of aluminum in it now, so he has to have it cleaned (talk about being commited to FIRST!!!)
You are correct Kristen, we can't go under the bar with the lexan chimney on. If we take it off, we can still lift crates, we just have no support for them. We would use this mode to go against certain types of robots. For example, if we are up against a dominant king of the hill robot, and there's no hope of moving him, we would go with this and use our under-the-bar capability to shuffle the score around. Also, if we were going against a robot like 179, or one that starts by swinging an arm and knocking over crates, we'd start in our under-the-bar-mode, and begin by ramming into them and ruining their strategy (hopefully).
Can't wait to see ya'll in Richmond, and make sure you drop by our pits to see our poor-man's segway! Perhaps by then we'll finally get a gyro on it (although I doubt it).
Stephen
Unread 25-02-2003, 19:28
some young guy's Avatar
some young guy some young guy is offline
i donno...i just build it
AKA: joe
#0810 (the mechanical bulls)
Team Role: Student
some young guy is on a distinguished road
Send a message via AIM to some young guy
Lightbulb
im lovin the design!!!! it really looks like it will do its job and do it well!!
can't wait to c it in action!!
team 810
BRUTE FORCE!!!! its all u need.....o and a BIG hammer is always good
Unread 25-02-2003, 19:43
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
great design!
we origionaly had planned on protecting stacks and we did design and implement a device that would do it...but we have the some issue of not being able to limbo very well with it attached...
Good luck!
and yes that shirt does rock!
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 25-02-2003, 20:41
Rook's Avatar
Rook Rook is offline
#0267 (The Demolition Squad)
Rook is an unknown quantity at this point
Years ago, there was a commercial where some rich dude would pull up in a limo and ask the car next to him, "Do you have any Grey Poupon?" It's some kind of fancy French brown mustard. 'Scuse me if I spelt it wrong.
Aaahhhhh! The atmosphere! Aaaahhhh!
(Things you might hear a meteor say.)
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
Image Discuss: Team 60 - Testing the Robot CD47-Bot Robot Showcase 15 10-02-2003 17:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
