User mode toggling
I'm not sure if anyone would know this, but is there a way (in coding) to make a button my controls (p2_trig for example) toggle the OI display between user mode (u000) and something else like team number (0151)?
Nope. Unfortunately, what is displayed on the OI is controlled by the uP's inside the OI, which aren't accessible from the RC. The only thing you can control is what is displayed while the OI is in user mode and the 9 (if you include basic run) LEDs you have direct control over.
As stated, you cannot control the OI from your joystick, but you can control what your User Mode displays. Just leave the OI in user_mode, and use "selection buttons" on your console.
vbutton, &c, are aliases for console buttons (OI_swAb.bit#), temp is a scratch pad, byte-size variable. The way this is arranged, if two people want to see different things (volts & direction, say) the first branch gets priority, so they will see voltage in the user window. program snippet.... if vbutton then show_volts if dbutton then show_direction show_amps: temp = sensor3 goto show_it show_volts: temp = battery_volts (=sensor8) * bewitch_factor goto show_it show_direction: temp = gyro_heading.highbyte show_it: out8 = temp.bit0 out9 = temp.bit1 out10 = temp.bit2 out11 = temp.bit3 out12 = temp.bit4 out13 = temp.bit5 out14 = temp.bit6 out15 = temp.bit7 ...rest of program Last edited by Lloyd Burns : 25-02-2003 at 05:55. |
| Programming Autonomous mode | Jared Stofflett | Programming | 3 | 11-11-2003 09:32 |
| autonomous mode problem on field | Chris_C | Programming | 17 | 26-03-2003 19:11 |
| autonomous mode timer | Don | Programming | 6 | 09-02-2003 22:16 |
| Select button and user mode | n[ate]vw | Programming | 2 | 20-01-2003 16:33 |
