Go to Post Let’s not scare the newbies away, let’s welcome them and help them. - Arefin Bari [more]
Unread 14-05-2014, 17:09
Re: We built a 6-CIM Kiwi Drive. Criticisms please!
Originally Posted by Nate Laverdure View Post
Happy to provide more data upon request.
OK, three questions:
1) what was your driver interface? e.g. did you just give the driver direct access to the 3 degrees of freedom (fwd/rev, strafe R/L, rotate), or did you put a layer on top of that to abstract it to a more intuitive level? one mode or several? etc
2) Did you derive the inverse kinematics from first principles, or did you refer to available papers on this topic?
3) Why was field-centric problematic? Were you having gyro drift problems, or did you encounter difficulties with the programming?
Unread 14-05-2014, 18:04
Nate Laverdure's Avatar
FRC #2363
I'll have a hard time answering these but I'll give it a shot; my ability to converse intelligently about programming is very limited.
Just two modes:
Robot-centric control allowed the the driver to adjust the setpoint of the PID loops for the 3 DOFs you listed.
Field-centric control added a layer of abstraction: the translation DOFs became north/south and east/west.
My understanding is that teams attempt these kind of field-centric control schemes all the time, but the drift in FRC-grade gyros often makes them unusable after ~10 seconds. Our original intent was to counteract this by integrating the data from multiple gyros with robust "sensor fusion."
I made sure the literature was provided, but I'm fairly certain my programming student derived everything from scratch. I believe he also threw out a couple of the WPI libraries and rewrote them. The often-spotlighted Matt Kline quote comes to mind: "A good programmer can look at a library, decide he hates it, and code everything from scratch. An amazing programmer can look at a library, decide he hates it, but realize the time it will save him and learn to use it." I hope to work on this with him next year.
I believe even the KOP gyro was fairly stable. Two main problems stick out in my memory:
-- Issues with communicating with the IMUs via any of the available protocols. One of the IMUs had an on-board microprocessor that supposedly provided built-in sensor integration, but we were never able to get access to this predigested data. We lost ~2 weeks on this. We ended up duplicating this capability by building a Kalman filter that ran on the cRio, ready to recieve the raw input from multiple sensors. I don't quite remember the rest of the story, but in the end we were using only the KOP gyro.
-- Whatever this was. We lost another 1.5 weeks on this.
Unread 14-05-2014, 18:35
Did you try all the suggested ways to mitigate this?
- make sure your robot is perfectly still when the gyro is being calibrated ("still" as in "not moving" and "not vibrating (e.g. compressor off)")
- make sure the gyro is at operating temperature before calibrating
- add a button for the driver to re-zero the gyro when the bot is pointing in the zero direction.
Would he be interested in posting his equations for discussion on this forum? It's possible they were not exactly correct, and this could have affected your attempt to implement field-centric control.
I don't think the WPILib has any functions that would be usable for your 3-wheel asymmetric kiwi arrangement.
Unread 14-05-2014, 20:18
FRC #2363
Did you try all the suggested ways to mitigate [gyro drift]?
I believe so. The "calibrate only when compressor is off" suggestion is an excellent one that I hadn't heard before. I understand that the quality of the KOP gyro varies considerably from batch to batch, and I think we got a good one.
I will ask. He's going to be my intern this summer, so I can assign him this task as a special project
Excellent catch! We accounted for the asymmetry in the control design.
Unread 14-05-2014, 20:29
cxcad cxcad is offline
FRC #1683 (Techno Titans)
cxcad will become famous soon enoughcxcad will become famous soon enough
Why not build a tex-coast drive? From what I read and understand is that you do not need fancy machinery to build it. I believe 624 did it without CNC.
Unread 15-05-2014, 19:19
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Stop calling it that, it's unneeded and confuses people.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 14-05-2014, 20:38
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Would you mind giving the relative positions/orientations of the wheels, I am trying to determine your theoretical max velocity in any given direction. My guesses are (back center wheel at (0,0) and oriented east/west):
front left: position = (-16,-25)in oriented 22.5 degrees west of north
front right: position = (16,-25)in oriented 22.5 degrees east of north
EDIT: changed front and back to reflect Nate's response.
Unread 14-05-2014, 21:25
FRC #2363
Originally Posted by inkling16 View Post
Would you mind giving the relative positions/orientations of the wheels, I am trying to determine your theoretical max velocity in any given direction. My guesses are...
BOLD ITEMS ARE EDITED TO ADDRESS CONFUSION:
back middle: position = (0,0) oriented west
front right: position = (-15.9,-18.5)in oriented 30 degrees west of north
front left: position = (15.9,-18.5)in oriented 30 degrees east of north
There's 120 degrees between the directions of each neighboring wheel.
Unread 14-05-2014, 21:47
The wide-set front wheels ensured that a very small amount of weight was cantilevered outside of the supported triangle.
back left: position = (-15.9,-18.5)in oriented 30 degrees west of north
back right: position = (15.9,-18.5)in oriented 30 degrees east of north
To facilitate dialog and minimize confusion, are the wide-set wheels front or back?
Unread 14-05-2014, 21:49
FRC #2363
C'mon Ether. You know an omnidirectional robot has no front or back.
Unread 14-05-2014, 22:08
[edit]OBE. I see you edited your prior post[/edit]
Unread 14-05-2014, 22:45
Kingland093 Kingland093 is offline
FRC #4215 (Trinity Tritons)
Kingland093 will become famous soon enough
The drivetrain looks good!
I would recommend having lots of driver training. My team had a similar issue as you guys in which we lost a lot of time early on in the build season and had very little time for driver training (about 2 hours total) and that killed us at our regional. To me, it's not as much what you're driving but how you drive it.
Hope this helps
McGill University Mechanical Engineering Class of 2020
FRC 4215: Trinity Tritons 2013-2016 (Programmer, Strategy, Driver)
2015 MRI Winner (with 3130, 2052, and 2531)
2015 MN State Championship Winner (with 2512 & 3130)
2015 Double DECC'er Winner (with 3130 & 525)
2015 Northern Lights Winner (with 3130 & 525)
Unread 14-05-2014, 21:51
Close.
Well, in one direction at least.
Okay, I was thinking that the back wheels were at 22.5 degrees because the 80-20 mounting plates on the back end and on the 45 degree piece looked similar. That makes for a much simpler problem.
This makes me curious though, has anyone ever done a kiwi drive with the wheels not all oriented at 120 degree angles relative to each other?
Unread 14-05-2014, 21:57
FRC #2363
One's a 60-deg plate and the other is a 75-deg plate. In the "rolling chassis" photo the bright white gusset plates are 3D-printed for rapid assembly, and they were replaced later with waterjetted aluminum.
