Go to Post None. Ours is anorexic at the moment. Lets see if the building people can come up with a simple tetra-knockdown mechanism. - Fixen [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 11-05-2014, 19:53
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Re: Custom bushings
Originally Posted by David Guzman View Post
A great material for bushings is UHMW (Ultra High Molecular Weight Polyethylene).
We used this extensively, not only on the robot but at work for many bearing applications. It is very easy to machine, has a very low coefficient of friction and can withstand significant loads for a plastic.
You can get rods from McMaster fairly cheap.
I would say +1 to UHMW, Delrin (Acetal Resin), or Nylon 6. All inexpensive all great bearing surfaces.
Another thing to consider if you can wait I would research different suppliers, Mc Master Carr is the fastest and arguably the best but not always the cheapest.
PS "All inexpensive" is a relative statement.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 13-05-2014, 22:39
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (Harker Robotics)
Re: Custom bushings
The thing is, the bushing looks pretty strange, and I can't really change the design at this stage (it follows an ultra-space-saving design that requires its weirdness). Basically I changed the design so it can use a smaller bearing, which is like 7/8" inner diameter and 1.125" outer diameter. However, it has a very large flange that's around 2" outer diameter. I'll look into using plastics for machining and cost without sacrificing strength. I've used UHMW in the past, but we tend to have a lot of acetal so I'll try that on aluminum too.
Unread 14-05-2014, 00:11
highlander's Avatar
highlander highlander is offline
Registered Boss
Team Role: Student
highlander has a spectacular aura abouthighlander has a spectacular aura abouthighlander has a spectacular aura about
Re: Custom bushings
In my experience Delrin machines really easily, while UHMW has a much lower coefficient of friction. However, UHMW is annoying to machine.
Unread 14-05-2014, 09:07
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
Re: Custom bushings
Originally Posted by DonRotolo View Post
You could cast some Babbitt, but that's way old school.
props to don for going Hit and Miss style on CD old engines are cool.
What about junk yard parts or an ATV spindle.
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 14-05-2014, 11:49
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
Re: Custom bushings
I looked into ball bearings in the 3" range, but they all cost more than $100. turret.
Ball bearings are just better than bushings and they're not expensive if you know where to look. just went to ebay and entered '75mm bearing' and here's two for $6.50 each.
http://www.ebay.com/itm/$@#$@#$@#-6215-2RSR-C3-Deep-Groove-Ball-Bearing-75mm-Bore-130mm-Outside-Diameter-New-/390838773352?pt=BI_Heavy_Equipment_Parts&hash=item 5affce6668
Unread 14-05-2014, 19:11
asid61's Avatar
AKA: Anand Rajamani
Re: Custom bushings
Interesting. I never thought to check for metric sizes.
The problem is there are some holes machined in the flange of the bearing. The main bearing is 2" OD, but the flange is 3". I need the huge flange for mounting holes to other stuff.
