Go to Post Woah woah, what about fingers? The programmers have to use something to type with? - dellagd [more]
Unread 15-05-2014, 04:47
chmconkling's Avatar
chmconkling chmconkling is offline
Jack of all groups. Master at most.
AKA: chris
FRC #2363 (Triple Helix)
chmconkling is an unknown quantity at this point
Re: Team 221 Arduino setup and problems
How do you set up the router then? Should you try and set the router up like the OpenShield (same IP)?
Unread 15-05-2014, 07:30
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
You can set the router up anyway you want... I usually do a factory reset and leave it to the default setting.
You'll connect to it's wifi network, once your computer is talking to the router, then the IP connections between the laptop and shield matter.
My non-technical answer is, don't mess with the router.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
