Go to Post 10:56 p.m. EDT, July 20, 1969. - dlavery [more]
Unread 15-05-2014, 12:56
pfreivald's Avatar
AKA: Patrick Freivald
Re: pic: Killer Bees Buzz19
Originally Posted by Jim Zondag View Post
The catapult has 6 Steel Extension springs. It has a lead screw adjustment on the spring deck which can adjust the spring draw about 5". Total spring force at max draw is about 1000 lbs. Overkill? probably: Awesome? Definitely.
We found that harder was better for shot repeatability.
Would you be willing to share the motor gearing and lead screw type (Multi-start? Single start? Diameter? Etc.) for this setup? I encouraged my team in this direction this year and they abandoned it after what I had deemed not enough prototyping. Alas.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 15-05-2014, 14:00
Jim Zondag's Avatar
Jim Zondag Jim Zondag is offline
Team Leader
FRC #0033 (Killer Bees)
Jim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond repute
To adjust the spring tension on our catapult we have a CIM with a 5:1 VersaPlanetary Gearbox. The lead screw is attached to the output of this gearbox with a shaftcoupling. We use a 10TPI single lead Acme Screw. We have a moving carrier block driven by the leadscrew which adjusts a lever arm (green). The carrier has 10" of travel. The upper 4 springs are suspended from a pivot on this lever arm (red). The lower 2 springs have fixed rear mounts and are not dynamically adjustable. We measure the position of the carrier block with a 12" string Potentiometer. THis allows us to adjust the shot from 10' to 50'. This setup has served us very well.
"To learn what is possible, we must attempt the impossible." Arthur C. Clarke
Unread 15-05-2014, 14:31
pfreivald's Avatar
Fantastic and elegant, thank you!
Team 1551
I write books, too!
Unread 15-05-2014, 20:27
Bryan1625's Avatar
Bryan1625 Bryan1625 is offline
FRC #1625 (Winnovation)
Team Role: Driver
Bryan1625 is just really niceBryan1625 is just really niceBryan1625 is just really niceBryan1625 is just really nice
You guys were for sure my favorite team to play with/against in quals and elims! Made the match a lot more interesting! Beautiful bot!
