Thread Tools |
Rating:
Display Modes |
Re: Coaxial Swerve Derivation with Paired Modules
At any rate, every game deserves thorough evaluation on the pros and cons of each drive train, because ultimately propellers will rule when it's a water game. ![]() |
I cannot speak to what the pros and cons of running them in pairs would be. We ran all 4 of our modules independently this year. Off the top of my head the only advantage I can see to pairing instead of all independent is using two less motors, but at this point with the number of motors available and the weight that teams have been able to get their swerve drives down to, that doesn't seem like a huge plus. -Nick |
I agree with others.
Full independant is mechanically easier and it lets your 4 corners exist in isolation from each other. Also, it's trivially heavier as you're not linking power transmission over long distance, so you eliminate all that weight (but do add two motors at .5 lbs each + gearing). |
Some benefits of pairing swerve modules would be:
* Ability to drive (2) swerves with (3) CIMS * Easier to add gear shift But, what kind of drive action/control are you seeking: Crab or Snake? Either could be accomplished through pairing, but not both together. For example of crab & snake, see: http://www.chiefdelphi.com/media/papers/2400 http://www.chiefdelphi.com/media/papers/2401 |
You could try a 3 wheel 6 cim having the best out of both worlds. |
#7
6 CIM drives really aren't about pushing harder; they don't, at least not with shifters. They're about accelerating better when geared for a high speed at full weight. A swerve that accelerates more slowly than the standard tank drive would be less agile - this would be bad for outmanuvering.
#8
6 cims is not for pushing, because the 120a breaker basically limits your torque, even if it delays a few seconds. Your wheels will lift before that happens at lower speeds (~7fps IIRC). It does, however, give you much better acceleration.
The main problem with a 6 cim swerve is that you lose all your cims that could go to a manipulator. Plus, you either have to do a central gearbox or go with a 6-module swerve. Using centralized gearboxes saves weight (chain weighs very little as a matter of fact) but at the cost of not being able to do complex maneuvers. For programming purposes, a simple crab would work better in my opinion, but mechanically it will be hell to line them up due to chain spacing. The chain for crabs also has to be designed around for anything that goes above the chassis. The high number of chains also can lead to faster breaks, so using #35 chain could be an advantage maintanence wise. Chain weight is 0.087lbs for #25, 1.8lbs for #35 per foot. One way to line up swerve modules is to stretch a piece of surgical tubing between the end of one wheel's axle to the end of another and tie it off there. That keeps both wheel facing forwards. Then you calibrate at 0, and remove the tubing. Last edited by asid61 : 15-05-2014 at 20:27. |
#9
-Nick |
#11
I think the reason a 6 cim drive gives you more acceleration is because it spikes the current initially. I'm not 100% sure why it is faster at accelerating (it definitely is though, one of parents did some calculations) but that would be my guess.
It won't help in a pushing match because the current spike will just kill you, because the current will not decrease over time like when you start driving. Insert blown breaker here. The reason I say torque is limited is because torque is directly related to current on a motor. Because we have (usually) a maximum 120a-180a going to all cims, and the stall current on each cim is 133a, you are not getting more torque. The delayed blow on the breaker will allow the current to spike for all the cims, giving you a torque boost with more cims, but it can't hold those current levels for long. So the max torque cap is pretty much the same if you don't want to blow breakers. Torque is also inversely proportional to speed in electric motors, so having 6 cims divvy up a given amount of current (torque) will increase their speed as well compared to 4 cims. Let me rephrase what I said about manipulators: 6-cim drivetrains are fine. You are still left with many motors for doing all kinds of stuff on the robot. However, when you have a bunch of turning motors too (which you will want, crab or swerve) then you end up being left with some wimpier motors. On a single centralized turning gearbox, it might not be a problem, but if you want to turn the modules quickly then you would want more than 1 turning motor there. Just my opinion of course. 6 cim swerves have been done in the past, and have done beautifully. However, in my opinion, it doesn't matter what you pick as long as it's excecuted well and you get driver practice. Focus more on the little picture. |
#12
However, I stand by by statement that torque is limited by the breaker. |
#14
Get back to me when you find a need for 18 motors. |
#15
The potentially big issue with a 10 motor drive on the new control system is only having 16 slots on the odb. 6 motors might not be enough for the rest of the bot.
