Go to Post Although I don't agree with the ref's call...we accept it because a ref's call is a final call. - David Guzman [more]
Unread 15-05-2014, 21:41
pastelpony's Avatar
pastelpony pastelpony is offline
Programmer/Electrical
AKA: Zach M
FRC #3525 (Nuts and Bolts of Fury)
pastelpony will become famous soon enough
Can LabVIEW take advantage of controller button pressure sensitivity?
For example, I have a steering wheel and pedal set that is registered as a generic USB controller and works flawlessly in LabVIEW. However, I would like the sensitivity of the press of a button to affect the output of a motor. Is there a way LabVIEW can read pressure sensitivity through a .dll file or such?
Unread 15-05-2014, 22:13
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Can LabVIEW take advantage of controller button pressure sensitivity?
How does the device report that pressure?
Not directly related: If only position is reported, pressure can be estimated by the rate of position change. So a 'light' press might move it 2 mm/sec, while a 'hard' press might go 15 mm/sec. (Finally! A real use for calculus! :-))
Unread 15-05-2014, 23:11
MaxMax161's Avatar
MaxMax161 MaxMax161 is offline
Allegedly Useful
AKA: Max Llewellyn
FRC #2791 (Shaker Robotics), FRC #1676 (Pascack π-oneers)
MaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond repute
What hardware are you using? If it's reported by the hardware labview should be able to read it as well as any other language.
Don, perhaps I'm just not seeing it. but just given ON/OFF how would you determine the rate a button was pressed? I'm imagining it being off for some arbitrarily long amount of time then being pressed and turning to on for an undetermined amount of time. However, I could see the length of press being used to control something about an action, assuming it was a press and release action not a press and hold action. For example in several video games quickly tapping the jump button vs holding it will result in a different sized jump.
2791 Shaker Robotics (2013-present)
--Control Systems Mentor 2013-present
--Drive coach 2015-present
1676 The Pascack π-oneers (2010-2013)
--Drive coach 2011-2013
--Lead Programmer 2011-2013
Unread 16-05-2014, 07:56
It is the game controller device, not the reading of it in code that generally determines if an input is a button (on/off) or an axis (press sensitivity).
Exceptions like the xbox hat only make some axis behave as on/off buttons, but a button never behaves as an axis.
In general, if code reads the game controller input as an Axis, then the device returns press sensitivity. However, if a game controller input is reported as a button, then it is not press sensitive.
Unread 16-05-2014, 08:46
pastelpony's Avatar
AKA: Zach M
Yes, I understand that buttons give only a boolean value. However, I thought this because these controllers have pressure sensitivity (such as speed variation through press strength when applied to a driving simulator) and I wondered if LabVIEW could read this. However, this does not appear to be the case. Thank you very much for your help.
Unread 16-05-2014, 10:15
MDAWG25's Avatar
MDAWG25 MDAWG25 is offline
FRC Capability Developer LabVIEW
AKA: Matt
FRC #2614 (MARS)
MDAWG25 is on a distinguished road
What is the name of this controller? The WPI Libraries may not be able to read it, however you can send the data from a custom dashboard that is reading the controller values with LabVIEW's default joystick input, or by extending DLLs if you want.
An example of extending DLLs In LabVIEW can be found here:
http://www.chiefdelphi.com/forums/sh...07#post1374207
This shows an example of extending the xinput dll to control the vibration of a connected xbox 360 controller.
Mountaineer Area RoboticS (MARS) Team 2614
2015-???
2014-Driver
2013-Driver
2012-Driver
2011-Programmer
Unread 16-05-2014, 17:19
pastelpony's Avatar
AKA: Zach M
I've used xinput to map vibration onto a Dualshock 3 with LabVIEW through third-party software. I can probably map this controller as well. Thank you. It is an Intec steering wheel and pedal set, pretty generic.
