Go to Post Knowledge is power. Know whats coming and you can be ready for it when it happens. - KenWittlief [more]
Unread 15-05-2014, 22:19
Re: Coaxial Swerve Derivation with Paired Modules
Originally Posted by asid61 View Post
Torque is also inversely proportional to speed in electric motors, so having 6 cims divvy up a given amount of current (torque) will increase their speed as well compared to 4 cims.
Using the above logic, a 6 CIM drive should have a 50% faster top speed compared to a 4 CIM drive, all else being equal.
Unread 15-05-2014, 23:01
Aren Siekmeier's Avatar
on walkabout
Originally Posted by Craig Roys View Post
This is one of the reasons we were considering looking at two pairs...we wanted to see about getting 6 CIMS to power the 4 wheels.
It's been a while since I've done the math, perhaps those with more recent, published models can confirm. This is all based off my intuition.
Since you have a 4 wheel drive, put 2 CIMs on modules in opposite corners, with 1 CIM in each of the other corners. The power you're supplying to your wheels should still be balanced on either side, regardless of the direction of movement which is defining said "sides" at any given time.
Adding in arbitrary rotation on top of translation complicates things a bit, since now the power available to pull off the rotation will depend on how far each "unit" of power is from the center of rotation. In particular, if you're spinning about one of your modules, if it's a 1 CIM module, you have 5 CIMs available to do the maneuver, while if it's a 2 CIM module, you only have 4 across the other 3 modules. If you spin about a point away from all the modules, you have all 6 CIMs available. A 4 CIM, 4 wheel swerve also fails to have this type of symmetry, but to a lesser extent.
In any case, a good speed control loop will ensure you still get the desired motion, but the max acceleration and force with which you can perform a maneuver may vary because of the loss of symmetry. Since a good swerve will require extensive off season testing anyway, I'd recommend trying this out so you don't have to try transferring power between modules, and seeing if the performance is acceptable.
Or go 3 wheel
Unread 15-05-2014, 23:44
on walkabout
Originally Posted by Tom Line View Post
Has anyone performed a similar variation for a paired-module swerve where 2 have 2 sets of modules, when each set has linked steering and drive?
To more explicit, picture 4 modules where the left side modules are turned and driven together, and the right side modules are turned and driven together.
For the kinematics: first take the equations for 4 wheels. A wheel's velocity is given by:
where i is the index of the wheel, r is its position vector relative to robot center, v is the velocity of the robot, omega is the rotation of the robot (counterclockwise around robot center). However, by pairing up modules, you introduce further constraints on magnitudes and directions of wheel velocities. In your case, you are requiring for some pair i,j:
or very close to zero (the wheels are allowed to scrub a little). But this means either you aren't turning very much at all, or your paired wheels are nearly on top of each other.
For other pairings you can follow a similar process to figure out what motions are still allowed. Calculate wheel speeds and directions as you would normally, then average them for each pair output, so that the pair outputs are the same, and it should work, though some motions may not be possible.
I believe it was 2451 who had a nice table of all the different ways to pair up modules for both power and steering, and the motions it allowed. I've been unable to find this anywhere online however, so I must have seen it in their pit. The paper by Nate Laverdure posted below is what I was thinking of.
Unread 15-05-2014, 23:51
smistthegreat's Avatar
smistthegreat smistthegreat is offline
robots is a hard job
AKA: Brian Smist
FRC #4930 (The Electric Mayhem)
smistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond repute
http://www.chiefdelphi.com/media/papers/2785 is a tremendously useful paper that outlines pretty much every possible combination of steering and powering modules, including a list of possible maneuvers by combination and notable examples.
The configuration that you're describing is the one labeled {5}. As mentioned earlier in this thread, it is basically a 4 wheeled tank that can translate, meaning that to spin in place you'll have a bit of scrub. One way to avoid this is configuration {13} which powers each side together but links steering modules on the diagonal. This retains the ability to strafe in an arbitrary direction but does a much better job at spinning in place. Check out team 1717 in 2011 for an example of this.
I would tend to agree with other posters in this thread and say that if you're planning on going through with a swerve, assuming the motor rules stay as lax as they are, it wouldn't be a huge step up to just go for 4 independently powered and steered modules.
I would also recommend, if you have the resources to do so (which is a decent amount of money), buying a set of revolution modules from 221 robotic systems and throwing together a chassis to give to your programmers as soon as possible. The biggest hurdle with swerve tends to be software and implementation of controls, as there are tons of resources available mechanically (221 posts cad on their website, team 1640's wiki is incredible, 973 has swerve cad on their website, etc.).
University at Buffalo | Mechanical Engineering | Class of 2016
2014-20?? | Mentor | 4930 | The Electric Mayhem
2013 | Mentor | 229 | Division by Zero
2013 | Mentor | 4124 | Integration by Parts
2009-2012 | Student | 1507 | Warlocks
Unread 16-05-2014, 01:28
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Hm, that's correct. How would you explain it then? 6 cims definitely increase acceleration.
However, I stand by by statement that torque is limited by the breaker.
Unread 16-05-2014, 01:37
Knufire Knufire is offline
You can pull huge amounts of current for a short amount of time without tripping the breaker.
Source: http://www.cooperindustries.com/cont...UITBREAKER.pdf
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 16-05-2014, 08:57
At a given voltage and speed, 6 CIMs draw more current than 4. More current means more torque. More torque means more acceleration.
As the speed approaches motor free speed (for the given voltage), current draw approaches zero no matter how many motors you have (due to back emf).
With 6 CIMs you also have 6 40-amp breakers, so the associated total current limit increases. And the main breaker is slow acting - it can sustain high overcurents for a significant duration.
Unread 16-05-2014, 10:14
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Let me rephrase what I said about manipulators:
6-cim drivetrains are fine. You are still left with many motors for doing all kinds of stuff on the robot. However, when you have a bunch of turning motors too (which you will want, crab or swerve) then you end up being left with some wimpier motors. On a single centralized turning gearbox, it might not be a problem, but if you want to turn the modules quickly then you would want more than 1 turning motor there.
I still don't buy it. Even if you somehow manage to allocate 6 cims and 4 turning motors (say Banebots), you still have 4 Minicims/Bags, and 4 AM 9015's, in addition to many other motors of decreasing value.
Get back to me when you find a need for 18 motors.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 16-05-2014, 12:57
Further detail for those interested:
Drivetrain Full-Throttle Acceleration Simulation Model with traction limiting and voltage drops:
http://www.chiefdelphi.com/media/papers/2868
see these attachments:
PDF Drivetrain Acceleration 2013-09-25 RevC
Derivation of Voltage Drop Model rev E
C source Drivetrain Acceleration 2013-09-24_2231
See attached chart of accel vs speed for one set of model parameters, using data generated with attachment ready-to-run model 2013-12-18
You can change the parameters to whatever you think is appropriate for your drivetrain and run the model to see how they affect the performance.
Name:	6CIM vs 4CIM accel.png
AdamHeard's Avatar
Lead Mentor
The potentially big issue with a 10 motor drive on the new control system is only having 16 slots on the odb. 6 motors might not be enough for the rest of the bot.
Unread 16-05-2014, 16:01
on walkabout
Still leaves enough for 2 motors to each of 3 additional degrees of freedom. We usually only have 2 additional motor powered degrees of freedom. And you can always go 1 motor on a degree of freedom. Besides the fact that pneumatics are most of the time a better option. So I'm not super worried.
Also, 3 wheel swerve only has 3 turning motors
Unread 16-05-2014, 16:14
Gregor's Avatar
The new PDB is loosing 4 20/30A slots, but none are required for the control system.
Currently you need to power at least the sidecar and analog breakout, and sometimes a solenoid breakout and a compressor, so you're effecivly loosing 2 ports without pneumatics, no ports with pneumatics.
See attached image.
<Since 2011
Unread 16-05-2014, 19:06
Richard.Varone's Avatar
Richard.Varone Richard.Varone is offline
AKA: Rich Jr.
FRC #0271 (Mechanical Marauders)
Richard.Varone is just really niceRichard.Varone is just really niceRichard.Varone is just really niceRichard.Varone is just really nice
Send a message via MSN to Richard.Varone
In 2011 we did a 2 speed coaxial crab ( fronts paired, backs paired ), I'll try to find some pics/CAD.
2016 FLR (Excellence in Engineering)
2015 NY (Regional Finalists) & LI (Quality Award)
2014 NY (Regional Finalists, Quality Award) & LI (Regional Finalists, Quality Award)
2011 LI (Regional Finalists, Innovation in Control)
2010 LI (Regional Champion, Engineering Excellence, Coopertition Award) & NY (Regional Finalist)
2009 LI (Innovation in Control) & NY (Creativity Award)
2008 LI (GM Industrial Design) & NY (Innovation in Control)
2007 LI (Delphi "Driving Tomorrow's Technology")
2006 LI (Regional Champion)
2005 LI (Regional Finalist)
2004 SC (Regional Finalist)
2003 LI (GM Industrial Design)
2002 CMP (Division Finalist - Newton)
2001 NY (Imagery)
Unread 17-05-2014, 21:15
See attached chart of accel vs speed...
Hmm. I thought I'd get some comments or questions about the shape of the 6CIM accel curve.
Unread 17-05-2014, 21:30
Oblarg Oblarg is offline
AKA: Eli Barnett
If I'm guessing correctly, the cusp is due to the transition between traction-limited and motor-limited. The 4CIM at that gearing is never traction-limited so there is no cusp. For a different gearing you might see an identical plateau at the beginning for the 4CIM, but it would drop off sooner.
I wonder why there is a slight decrease in acceleration while traction-limited as the speed increases, though?
"The breakfast of champions!"
