Go to Post The one thing that no one ever list in scouting but is one of the most important factors is reliability. I don't care if the robot scores a hundred balls a match if I can't count on you being out there for the next three because it's a fragile as china. - Koko Ed [more]
Unread 16-05-2014, 13:36
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
pic: Team 2068 2014 competition chassis
Unread 16-05-2014, 13:48
Re: pic: Team 2068 2014 competition chassis
Nice work! I think this is the closest that I have seen someone come to reproducing our frame correctly. The flanges on the outer edge of the side rails add a lot of strength.
Unread 16-05-2014, 14:52
AKA: Jesse Gibson
Team Role: CAD
Thanks! I really liked the idea of a 3-piece chassis because of how easy it made assembly. We could have people assembling the motors/gears/wheels on each module independently then they just had to slide it into the belly pan and rivet it in place when they were finished. Having the wheel wells as a single unit rather than 2 panels was also really helpful in terms of strength - using a 1 piece bumper this frame made it through 2 regionals without deforming (at least not that I can tell)
You said we came close to your frame - is it just something we did differently or did you have something in mind that could be improved that I could pass along to my team for next year? (There's always room for improvement, I'm sure)
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Unread 16-05-2014, 15:57
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
Cool to see another va team with a sheetmetal drive. I am curious though, how difficult is maintenance with only being able to access the wheels from the bottom of the drive?
Unread 16-05-2014, 16:05
AKA: Jesse Gibson
Team Role: CAD
Only maintenance we ever had to do at competition was shoot some grease up into the gears (we drove the wheels using a single stage of reduction with the pinion driving a gear bolted to the wheel), and our robot sits about chest height on our cart with the wheels hanging off the side so they're not too difficult to access. If we ever needed to replace a wheel or anything though, once the shaft is pulled out, the wheel can just fall out of the bottom. I won't be on this team next year (heading off to college) but I will certainly keep playing with this design - and shortening the height of the modules so the wheels stick out the top a bit (less material, less weight) is one thing I would change. That would also allow a secondary method to access the wheels.
2011 - Logomotion
Unread 19-05-2014, 12:39
Since you asked. We have had our front and back frame rails bend under hard impacts. If you bend another small flange off of the top flange out there, that will add a bit of strength. We also put a couple ribs in the tubes to give us a nice solid contact point for superstructure mounting and to add some stiffness. Sounds like you didn't need them if things held up well this year, which is great.
Some of the finer touches are to design in the PEM nuts into the belly pan for mounting electronics, the PD board, and to design in the battery box. Those take a while, but the end result is magical.
