Re: [FTC]: Championship OPR?
Here's the Octave script I used: format longAttached is the output list of Team OPR's generated by the above script using your data. Quote:
When you have a set of overdetermined linear equations: [A][x]≈[b] (notice the approx equal sign "≈" because there is no exact solution since the system is overdetermined) ...if you multiply both sides by [A]T, you get: [A]T[A][x]=[A]T[b] => [N][x]=[d] ...which is a set of n equations in n unknowns, where "n" in this case is the number of columns in [A] (the number of teams). Notice the "≈" sign has changed to "=" since the system now has an exact solution. The above are called the normal equations (of the overdetermined linear system), and solving these normal equations for [x] gives the least-squares solution to the original [A][x]≈[b] problem. But if you're using a language with a linear algebra library, you can solve the overdetermined [A][x]≈[b] for the least squares solution directly. In Octave the syntax is called "left division" (x = A\b). In Python you use np.linalg.lstsq(A,b). Be aware that "least squares" (min L2 norm of residuals) is only one of many possible "best fit" solutions to the overdetermined system [A][x]≈[b]. For example, there's the "Least Absolute Deviations (LAD)" solution (min L1 norm of residuals). And there are other "robust regression" methods. |
Thanks for sending that. It looks like we're in sync now. Yay!
Here's what I have for the OPRs. After the team number follows the OPR, calculated without penalties, then autonomous, teleop, and end game.
Edison: 2753 217.8 63.0 71.9 83.0 Team Overdrive 4251 204.8 64.4 48.0 92.4 Cougar Robotics 4347 192.3 52.4 64.2 75.7 Nanogurus 5069 187.6 66.0 55.8 65.8 Robogamers 724 183.2 53.3 64.2 65.7 RedNeck Robotics Wun 7023 182.9 61.7 46.9 74.3 HexaSonics 5939 178.3 55.5 58.1 64.6 Team AFOOFA 6433 172.3 38.4 73.1 60.8 Neutrinos 8347 168.6 41.1 60.5 67.0 The BOLTS 6337 163.5 34.9 56.9 71.7 Metal Marauders 6424 161.6 45.3 69.4 46.8 Oly Cow 92 160.2 35.8 57.5 67.0 Junior Bomb Squad 5035 155.1 35.2 50.3 69.6 Wired 577 154.5 47.2 45.5 61.8 Wreckers Robotics 3486 154.3 44.0 48.3 61.9 Techno Warriors 3846 153.6 49.7 54.0 49.8 Maelstrom 4318 150.4 31.8 61.4 57.2 Green Machine 5414 149.7 53.8 45.6 50.3 Techie Tornados 3550 141.8 52.5 39.5 49.7 Beta 4029 141.1 34.0 46.4 60.6 2 Bits and a Byte 1369 134.5 37.6 46.2 50.7 Minotaur 4278 133.4 30.2 50.4 52.8 De.Evolution 3785 132.5 42.4 31.7 58.4 Beastie Bots 5501 132.3 49.9 36.9 45.6 USS Enterprise 4535 131.8 29.6 52.2 50.0 RedNek Robotics Too 5421 130.8 27.9 39.0 63.8 RM‐ed and Dangerous 5931 130.5 21.7 38.4 70.4 Cru‐Botics 6272 127.1 38.7 34.3 54.1 Iron Eagles Prime 4112 126.0 29.2 39.4 57.3 Warriors 3708 124.3 28.0 42.0 54.2 Iron Eagles Optimus 5140 123.9 26.9 44.2 52.8 WACO Aerobotics 4847 123.7 41.7 37.8 44.1 CHROME 5220 121.9 43.1 36.2 42.6 The RoboKnights 4220 121.3 23.0 48.4 49.9 Landroids 3162 118.5 46.6 27.4 44.5 HHS Gearheads 4140 117.9 51.7 33.4 32.9 Fish in the Boat 7440 114.1 42.3 27.1 44.8 Wingus and Dingus 5114 111.5 23.9 35.0 52.6 The Knights Who Say C 4982 111.2 22.1 34.3 54.7 Café Bot 4965 101.6 42.1 22.1 37.4 Animatores Romani 4150 97.7 31.1 34.9 31.7 Dark Matter 327 95.8 28.5 40.3 27.1 Gamma Factor 5977 95.3 40.5 31.7 23.1 Cyberswat 365 95.0 23.6 33.9 37.5 MOE FIRST 8360 91.8 22.5 26.9 42.3 Rawabi 7712 91.3 30.1 25.8 35.4 H& M Robotics Club 6109 91.3 17.6 40.4 33.3 Punabots 5609 89.4 20.7 21.8 47.0 Ciberbots 6100 89.1 41.6 20.8 26.7 Chariots of Fire ‐Black 7591 86.0 31.2 26.5 28.3 Voltage of Imagination 3595 85.6 35.8 19.3 30.5 Schrödinger's Hat 4625 83.9 28.3 24.6 31.1 Kings and Queens 6024 83.6 36.2 18.6 28.8 The Enterprisers 6002 78.0 54.8 5.6 17.5 Basilisks 4092 66.5 18.8 30.4 17.4 Nanites 8356 58.7 16.9 10.4 31.4 LET Lead out your Engineering Talent 8359 57.8 17.6 6.2 34.0 French Toast Mafia 8357 56.6 23.9 6.1 26.6 Desert Matrix 8336 54.1 11.8 13.5 28.8 Mars Gypth 8352 51.4 26.6 -0.5 25.3 Prime Numbers 4134 44.9 16.2 13.0 15.7 Wrench in the Works 8207 44.6 30.2 4.8 9.7 CanaBot 8349 25.5 15.9 -1.0 10.7 I love super big white cat 8337 24.4 -3.4 5.3 22.4 BaCoNeers Franklin: 7013 206.8 51.3 67.2 88.3 Hot Wired 6253 191.1 71.5 53.8 65.8 Avalanche 5257 188.7 48.6 58.4 81.7 Eagles Robotics XPerience 8221 185.8 47.7 57.3 80.8 Cubix 3409 176.1 45.9 51.2 79.1 Astromechs 4250 172.3 47.9 60.9 63.5 LIGHTSABERS 5026 170.2 55.7 52.2 62.3 Tesla Coils 4507 167.9 57.2 34.5 76.2 Robo Chargers 7907 167.2 56.9 42.9 67.4 Stark Industries 5309 164.5 56.5 49.2 58.7 Plan B 4997 164.3 54.3 46.6 63.4 Masquerade 4240 164.0 48.9 37.8 77.3 4‐H Techno Clovers 7398 162.2 38.3 45.6 78.2 BLUE CREW 7149 151.3 60.6 39.2 51.5 Enforcers 6299 148.2 31.6 58.3 58.3 ViperBots QuadX 4106 148.1 34.2 54.2 59.7 Supposable Thumbs 5096 147.9 51.3 46.7 50.0 Monkey Madness 6081 147.7 48.4 43.6 55.7 I2R Robotics 6508 147.2 47.8 46.1 53.4 Radioactive Raiders 4530 142.8 62.3 51.1 29.4 Infinite Resistance 4855 141.6 45.8 40.7 55.1 Batteries In Black 5661 138.7 38.4 46.8 53.5 SHPE Wolves 5555 136.8 58.2 53.0 25.7 Option 16 5279 134.9 35.5 37.1 62.2 Positrons 4211 133.5 40.5 42.4 50.6 The Bombers 5452 129.8 52.8 38.0 39.1 Robots to the Knee 2888 129.4 43.3 43.5 42.7 Oddly Charged Particles 7129 127.6 38.7 39.2 49.8 Robo Raiders 5815 126.0 28.0 43.4 54.6 Disgruntled Robots 4443 125.6 38.3 47.5 39.8 Sock Monkeys 6451 123.1 28.7 28.0 66.4 Tarpon Robotics 5169 123.0 34.6 44.2 44.2 Watts Up? 8338 122.7 19.3 45.5 57.9 Shatterdom 4999 122.0 38.0 43.9 40.1 Imagine It 6051 122.0 51.6 29.6 40.8 Quantum Mechanics 2844 121.3 27.3 34.1 59.9 Valley X 248 120.8 23.8 28.1 68.9 Fatal Error 8231 113.4 24.1 39.7 49.6 Skyhawks 5972 107.3 47.5 21.8 38.0 Patronum Bots 8348 107.2 30.9 36.3 40.0 Crazy Shooter 7817 106.9 51.6 36.2 19.1 TaterBotz 8361 106.5 28.2 49.6 28.7 Garrins Metal‐lics 6055 101.1 33.6 26.2 41.3 Gearticks 4961 100.9 30.5 38.8 31.6 Robo Raptors 38 100.9 36.3 28.6 36.0 Pakbots 8350 99.3 39.3 19.8 40.1 Don't Throw Block 4745 92.6 26.2 30.7 35.7 Orozco's Army 5009 92.0 16.0 22.6 53.5 NET ZERO 3141 92.0 11.6 46.3 34.1 Bears 5843 91.9 33.9 34.0 24.0 AutoVortex 5604 90.9 23.4 32.8 34.7 Thunderbots 4924 90.5 24.1 17.3 49.1 Tuxedo Pandas 4475 89.7 8.2 44.6 36.8 Purple Reign 3781 85.3 10.7 22.7 51.9 Westlake Pi‐Rho Maniacs 8339 78.8 17.0 37.5 24.3 Galaxy Robo Techs 6935 78.6 31.5 25.1 22.0 Paradox 6221 78.0 23.8 14.4 39.8 Panther Bots 5875 77.6 29.2 9.7 38.7 GENIUS 101 74.1 20.1 12.2 41.9 The Indivisibles 8351 69.1 3.8 34.2 31.2 Siberian Beast 3954 62.6 10.7 22.2 29.7 Watt's Up 4287 50.1 24.1 10.7 15.3 Red Meteors 4107 37.4 24.8 7.7 4.9 Mohon Bots 4183 33.7 19.6 2.7 11.4 ICEBREAKERS Last edited by davidaustin : 16-05-2014 at 20:58. |
