Go to Post Don't fight success. - Al Skierkiewicz [more]
Unread 18-05-2014, 00:53
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
Fastest drivetrain in Aerial assist?
I have been looking at drivetrain designs for next season, and i was wondering: what were the fastest robots in terms of acceleration, and top speed and what drivetrain (Swerve, WCD, tank, etc.) did they use? I believe the fastest team in the PNW was probably Bear Metal team 2046. They used a WCD.
Unread 18-05-2014, 01:09
JohnFogarty's Avatar
AKA: @doctorfogarty
Re: Fastest drivetrain in Aerial assist?
Fastest I saw was my old team 1102. They had a 8" wheel mechanum drive that went close to 20 fps. I haven't seen a better implemented mechanum in the south-east than theirs this year.
John Fogarty
Unread 18-05-2014, 01:12
Richie_Richter's Avatar
Richie_Richter Richie_Richter is offline
AKA: Tom Richter
FRC #2502 (Talon Robotics)
Richie_Richter is an unknown quantity at this point
Take a look at team 16, The Bomb Squad. I think they have swerve drive as opposed to a WC tank drive. But in terms of speed and agility, I have seen few robots that come close.
Unread 18-05-2014, 01:17
Rauhul Varma Rauhul Varma is offline
Drivetrain and Design Lead
FRC #0192 (GRT)
Rauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud of
We geared our modified WCD to ~24 fps, and measured just below 23fps with encoder data verified with video analysis.
Unread 18-05-2014, 01:34
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
I was told 1678 gears for 22fps making them the fastest tank drive I know of. As for omni drives we may take 1st as we use mini cims geared 6:1 on 6 inch AM mecanum wheels giving us a top speed of about 19 fps. It comes in handy when things change and I need to be on the other side of the field. Just keep in mind the higher you gear the slower you accelerate. Also, we found that we would loose rollers on our mecanum wheels at speeds above 15 FPS.
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
Unread 18-05-2014, 03:22
Andrew Lawrence
Posts: n/a
How often do you think you reached your top speed in competition?
Unread 18-05-2014, 03:50
FRC #0192 (GRT)
Maybe once per couple matches, however we did hit ~19 fps all the time. Since our robot was so light (sub 115 lbs fully loaded) acceleration wasn't an issue.
Unread 18-05-2014, 06:02
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
166 was pretty fast. I think I heard 21 FPS but I could be wrong.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 18-05-2014, 12:58
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
We geared for around 20 fps actual this year (24 theoretical) on a 6 CIM WCD.
I would highly recommend that you spend some time developing nice control software and getting your driver a ton of practice if you plan on going this route.
Split - Arcade drive is IMO the best for this kind of high speed driving.
Unread 18-05-2014, 14:47
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #3501
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
We geared for something like ~24 fps, 6 cims, ~90lb robot. Haven't done an actual speed test but it should give you an idea.
254's 2011 robot slipstream was probably the fastest robot in FRC. WCD, only 4 cims, super light.
All posts here are purely my own opinion.
2011-2015: 1678
2016: 846
2017 - current: 3501
Unread 18-05-2014, 15:00
T^2 T^2 is online now
FRC #5499
We did do actual speed tests. Theoretical free speed was 22.8ft/s, actual was 17.1ft/s (~75% overall efficiency). I might have a forthcoming white paper on the analysis I did with the data we collected.
Unread 18-05-2014, 17:45
DampRobot's Avatar
Physics Major
AKA: Roger Romani
IIRC they were around 110 lbs in 2011 (although I'm remembering that from a while ago), and geared at something like 18fps. I think their 2014 bot was their fastest in recent memory, weighing in at something like 87 lbs and geared at 20+ fps.
While I'm sure they're not the "fastest" robot (in terms of straight line max speed) I've ever seen, 9973 last year has absolutely phenomenal acceleration, great driving, and a pretty fast top speed. I think they'll stick in my mind for a while as the fastest looking bot I've seen.
-Plutarch
Unread 18-05-2014, 18:28
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Wow, you guys seemed much faster than that. Your driver was very good this year.
I think that you can probably gear for like 26fps and put a software limit that can be increased with driver practice. As long as you have a low gear you would be able to stop yourself from getting stalled easily.
Unread 18-05-2014, 18:53
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
ONLY if you have a low gear/two speed gearbox. Your acceleration will be impacted significantly with a top speed of 26FPS, which may mitigate the perceived higher top speed (not useful if you never get there). Personally, I would only design up to 24 theoretical, because beyond that number most drivers seem to struggle controlling the robot.
Top speed isn't the only thing to consider when choosing gear reduction. We factor in Driver Ability, Game Requirements (open field, field with obstacles) , and Robot factors (such as weight) when choosing the reduction.
This year we were geared for 18 FPS, and achieved 16 actual due to a robot that only weighed 107 pounds w/ battery and bumpers. We thought it was a good harmony between speed, and torque (we run single reduction). If we were to run a 2-speed, the actual would likely be bumped up to 18-20 FPS actual because we can now have a low gear (5-9 FPS) for pushing
(2015-?): 973
(2012-2015): 955
Unread 18-05-2014, 19:31
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
[Already answered]
