Go to Post We were the "oooh, neat, fire!" robot that year. - pfreivald [more]
Unread 17-05-2014, 22:23
Dylan Danzeiser Dylan Danzeiser is offline
Lobster Drive Lover
FRC #0418 (Purple Haze)
Team Role: Student
Dylan Danzeiser is an unknown quantity at this point
4wd turning
I've been reading about the turning abilities of 4 wheel drives, including the famous whitepaper, but none of the resources I could find address specifically longer, arcing turns while the robot is moving forwards as opposed to turning in place. Is this easier, harder, or of similar difficulty as turning in place if you happen to have a longer wheelbase than normal?
Unread 17-05-2014, 23:09
Kevin Phan's Avatar
Kevin Phan Kevin Phan is offline
College Student
FRC #0357 (Royal Assault)
Kevin Phan will become famous soon enoughKevin Phan will become famous soon enough
Re: 4wd turning
What you're describing seems to me is what I all a swing turn. When I was teaching fll kids about programming this turn, I find that the turn is harder since one side is not powered or powered slightly and the other side of the robot is doing all the work. To answer about the difficulty turning with a longer wheelbase, I'm not sure, the bigger factor in my experience is the coefficient of friction on the wheels.
VEX & FRC Student Team Member #357 Royal Assault 2010-2014 "Dare Mighty Things"
2014-2019 Attending Drexel University Major:Electrical Enginnering
Unread 17-05-2014, 23:15
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
Re: 4wd turning
What exactly do you mean by easier or harder? In regards to programming? Driving? Stress on the robot? A little more context will do great things in accessing the wealth of knowledge here on CD.
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
Unread 18-05-2014, 00:45
Lobster Drive Lover
Team Role: Student
Re: 4wd turning
I've read a bunch about how the wheelbase has to be longer than the track width for a 4wd to effectively turn, assuming a relatively equal lateral and inline coefficient of friction. However, these talked about turning in place, not turning while moving forwards, so I was wondering if there would be much of a difference.
Unread 18-05-2014, 01:25
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Re: 4wd turning
I think you've got the inverse relationship there regarding wheelbase vs. track width there. Otherwise, turning while moving forwards or backwards while be similarly more difficult than other drive trains, but not as difficult as turning with a 4WD at a stop. Usually, this means that a 4WD will need room to swing around to pull a 180, which is a pain for the driver to plan for out on the field, and makes defense against said 4WD much easier.
Also, this means that designs that force the driver to regularly re-orient the robot, like team 1986's 2013 and 2014 robots, absolutely requires a drive train that is easy to rotate. Preferably, it should be able to rotate without the turn profile being too much larger than the robot itself, as the center of rotation should be as close to the center of the robot as possible.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 18-05-2014, 02:45
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Re: 4wd turning
Originally Posted by Monochron View Post
He actually has it correct, really wide robots turn much easier than really long robots.
That's what he's saying. The person he quoted said wheelbase needs to be longer than the track width.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 18-05-2014, 10:13
Re: 4wd turning
Trackwidth is the width of the robot (distance between front wheels). Wheelbase is the length of the robot (distance from front wheels to back wheels).
Unread 18-05-2014, 10:17
Re: 4wd turning
...turning while moving forwards or backwards while be similarly more difficult than other drive trains, but not as difficult as turning with a 4WD at a stop.
^^Yes.
In fact, a robot that will not turn in-place at all will likely be able to turn given a large enough turning radius.
