| Thread Tools |
Rating:
Display Modes |
Fastest drivetrain in Aerial assist?
I have been looking at drivetrain designs for next season, and i was wondering: what were the fastest robots in terms of acceleration, and top speed and what drivetrain (Swerve, WCD, tank, etc.) did they use? I believe the fastest team in the PNW was probably Bear Metal team 2046. They used a WCD.
Re: Fastest drivetrain in Aerial assist?
Fastest I saw was my old team 1102. They had a 8" wheel mechanum drive that went close to 20 fps. I haven't seen a better implemented mechanum in the south-east than theirs this year.
Take a look at team 16, The Bomb Squad. I think they have swerve drive as opposed to a WC tank drive. But in terms of speed and agility, I have seen few robots that come close.
We geared our modified WCD to ~24 fps, and measured just below 23fps with encoder data verified with video analysis.
I was told 1678 gears for 22fps making them the fastest tank drive I know of. As for omni drives we may take 1st as we use mini cims geared 6:1 on 6 inch AM mecanum wheels giving us a top speed of about 19 fps. It comes in handy when things change and I need to be on the other side of the field. Just keep in mind the higher you gear the slower you accelerate. Also, we found that we would loose rollers on our mecanum wheels at speeds above 15 FPS.
How often do you think you reached your top speed in competition?
#7
Maybe once per couple matches, however we did hit ~19 fps all the time. Since our robot was so light (sub 115 lbs fully loaded) acceleration wasn't an issue.
#8
166 was pretty fast. I think I heard 21 FPS but I could be wrong.
#9
We geared for around 20 fps actual this year (24 theoretical) on a 6 CIM WCD.
I would highly recommend that you spend some time developing nice control software and getting your driver a ton of practice if you plan on going this route. Split - Arcade drive is IMO the best for this kind of high speed driving. |
#10
We geared for something like ~24 fps, 6 cims, ~90lb robot. Haven't done an actual speed test but it should give you an idea.
254's 2011 robot slipstream was probably the fastest robot in FRC. WCD, only 4 cims, super light. |
#11
We did do actual speed tests. Theoretical free speed was 22.8ft/s, actual was 17.1ft/s (~75% overall efficiency). I might have a forthcoming white paper on the analysis I did with the data we collected.
#12
While I'm sure they're not the "fastest" robot (in terms of straight line max speed) I've ever seen, 9973 last year has absolutely phenomenal acceleration, great driving, and a pretty fast top speed. I think they'll stick in my mind for a while as the fastest looking bot I've seen. |
#13
I think that you can probably gear for like 26fps and put a software limit that can be increased with driver practice. As long as you have a low gear you would be able to stop yourself from getting stalled easily. |
#14
Top speed isn't the only thing to consider when choosing gear reduction. We factor in Driver Ability, Game Requirements (open field, field with obstacles) , and Robot factors (such as weight) when choosing the reduction. This year we were geared for 18 FPS, and achieved 16 actual due to a robot that only weighed 107 pounds w/ battery and bumpers. We thought it was a good harmony between speed, and torque (we run single reduction). If we were to run a 2-speed, the actual would likely be bumped up to 18-20 FPS actual because we can now have a low gear (5-9 FPS) for pushing Last edited by Dunngeon : 18-05-2014 at 19:13. |
#15
[Already answered]
