Go to Post As Alice once said: "Curiouser and curiouser!" - Mike Betts [more]
Unread 22-02-2003, 10:10
COOPERcable COOPERcable is offline
#1084 (Iron Colts)
COOPERcable is an unknown quantity at this point
Orienting Boxes
This is a very important issue, and I was wondering if any teams had dealt with it. My team (1084) has a simple "poker" that tips the box to the proper orientaton for our stacker. Has anyone else thought up some genius way to manipulate the boxes?
Team 1084 - Iron Colts
St. Clair Robotics Team
Unread 22-02-2003, 10:54
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
Re: Orienting Boxes
both teams 571 and 281 have arms that squeeze the boxes into proper alignment for their pickup mechanisms
281
http://www.chiefdelphi.com/forums/sh...threadid=18395
571
http://www.chiefdelphi.com/forums/sh...threadid=18334
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 22-02-2003, 11:24
#1084 (Iron Colts)
I meant "has anyone created a component that can flip the boxes over so they are top up?"
Unread 22-02-2003, 11:35
Keith Chester's Avatar
Keith Chester Keith Chester is offline
HGFSP
FRC #0025 (Team 25)
Keith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to behold
Send a message via AIM to Keith Chester
1089.
A proud graduate of 25.
Students. Teammates. Brothers.
Proud member of R.I.N.O.S., Rookies In Need Of Support.
Unread 22-02-2003, 11:52
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
639
Basically, if you're a stacker, there's no chance that you'll be successful if you cannot orient bins. Watching the UTC scrimmage matches (ouch, that flip hurt), maybe 4-5 bins were right side up. The majority were upside down or on its side.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 22-02-2003, 11:55
#1084 (Iron Colts)
Right... well does anyone have pics or a description of how they did this?
Unread 22-02-2003, 11:57
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
Well, yes, we do of course. But no, we will not be posting them anytime before our first regional.
Unread 22-02-2003, 12:14
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
1089 tips way over 20%
re 1089's Quicksilver machine
1089 has no hand to pick up boxes. They hook them under the lip of the box or the handles. Look at the gallery pix to see what I mean
The mechanism is so simple it is obvious but it requires that the boxes be flipped upright.
SOooo- if you look at their mechanism the hooks are on top of a pneumatic arm. As the arm swings up the face of the mechanism is held vertical .
However that means the boxes, with their overhanging lids and shape, hook on at a tilted angle.
To rectify that underneath the arm is an extension covered with rubber foam. As the arm swings up the extension swings out progressively more and the boxes are kept vertical.
To upright boxes the raised arm is lowered on top of the misoriented box. The rubber extension surface adheres to the plastic with a slight friction and with a short pull back by the robot the box flips up. The way it is all oriented the box is about 3 inches in front of and perfectly lined up with the hooking mechanism and that means an easy connection there.
They also have a finger to flip boxes and guide the driver into optimal hooking position. The can flip boxes efficiently from any position. The can hook from all 4 sides of the bins.
This thing works VERY well and I have watched them stack up to six boxes that way. They do 3-4 easily. The higher stacks are a bit unstable when lowered. They ALWAYs are able to flip the box on the first or second try.
BTW- the idea came at a time when they were about 10 lbs overweight and looking to build a grasping arm. One of the students was playing with the incomplete base and accidentally hooked the box on the plastic connector of the incomplete hand. The rest was crazy brainstorming, pizza in hand and snow coming down. It saved a good 6 lbs.
BTW2- Team 25's robot can also upright boxes with our wings but in no way as efficiently.
Too bad 1089 will only be going to Rutgers because this device is a really neat thing to see in action.
WC
team 25
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 22-02-2003, 13:46
soezgg soezgg is offline
Senior Member
AKA: Harry Miller
#0639 (The Rude Awakening)
soezgg can only hope to improve
Send a message via AIM to soezgg Send a message via Yahoo to soezgg
$$$ Orienting is EZ $$$
We will post pics soon.
Unread 22-02-2003, 15:30
activemx's Avatar
activemx activemx is offline
A M X
AKA: Akshay Dodeja
activemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of light
Send a message via AIM to activemx Send a message via Yahoo to activemx
we have two pokerts in front at different levels. Works very well!
2005 - Present - FIRST Volunteer(Inspector, Ref, Judge)
2000-2004 MVRT 115
Unread 22-02-2003, 15:38
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
1:45 is such a short time... I expect the most anyone will orient efficiently is around 3 bins and stack is about 5-6 (not including taking a human stack). Of course, if you have two teams allied together who are both stackers, the orientor team will be very good at allowing the other team to stack. The UTC scrimmage videos showed very very few bins landing right side up so the human stacks will be a big part of the game. Stealing stacks is also important
Unread 22-02-2003, 19:23
Pierson's Avatar
Pierson Pierson is offline
Pierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of light
Send a message via AIM to Pierson
Team 360 has a box orienter that rotates with a window motor, opens and closes with pneumatics and can also stack 2 boxes high.
Name:	360_2003_rmiv_back (medium).jpg
Pierson
Former Captain & Fundraiser of Team 360
Join in on these fun threads:
Three Worded Story
Word Association
Unread 23-02-2003, 17:32
FAKrogoth's Avatar
FAKrogoth FAKrogoth is offline
FAKrogoth is an unknown quantity at this point
You too, eh?
Unfortunately, due to weight requirements, we will not be able to both rotate and stack at the same time (unless some cool form of magic happens).
I thought aluminum was supposed to be light . . .
Never underestimate the power, number, or magnitude of stupid people. - me
Unread 23-02-2003, 18:37
etoleb etoleb is offline
#0891 (Neverending Chaos)
etoleb is an unknown quantity at this point
Send a message via AIM to etoleb
Although we can use our arms to flip bins to the "proper" orientation fairly quickly, we usually stack the bins when they're upside-down or sideways. Its just faster this way, at least for us.
As for our method, well, we usually just "tip" boxes over that are sideways.
Greg
Who am I?
I'm that crazy guy with the duct tape tophat.
Neverending Chaos
Team 891
Annapolis '03 10th seed; Quaterfinalists (special thanks to teams 484 and 486)
Nationals '03
Unread 23-02-2003, 19:02
Spikey's Avatar
Spikey Spikey is offline
Its NOT a Camera
AKA: College Advisor
FRC #0293 (SPIKE)
Spikey is just really niceSpikey is just really niceSpikey is just really niceSpikey is just really nice
Our robot can grab a box in any orientation. The grabber is wide enough to accomadate any position.
Check Team 293's Spike in the pic forums!
It's not a bug it's a feature!
"No, you may not drill holes in the air tanks to lighten them." -FIRST Q&A Repsonse to a question about lightening air tanks.
I'm the Not a Camera Kid at the New Jersey Regional But Not This Year, I am at Syracuse University Class of 2009
Uncrowned Champions of the 2005 Philadelphia Regional
SPIKE X NJ Xerox Creativity Award. Chesapeake Regional CHAMPIONS, and Motorola Quality Award
2006 Semi-Finalist at NJ Regional & Semi-Finalist at Chesapeake Regional, winners of the 2006 Xerox Creativity Award, and Judges Award
"Looks like SPIKE is doing its Batman thing again, that team looked like it was going to score, but SPIKE was not going to allow that to happen" -Play by play call at the Chesapeake Regional
Dimensions of the kit boxes Jean McAuliffe General Forum 2 24-06-2003 00:40
How many boxes can your robot stack? Dan-o Robot Showcase 22 14-02-2003 19:57
breaking boxes illumanat'i Rules/Strategy 6 19-01-2003 15:44
question on launching boxes 2PI4Julia Rules/Strategy 4 18-01-2003 10:17
plastic boxes Suzy General Forum 6 12-01-2003 03:27
