Go to Post Anyways, before we all get worked up over this setup, let's wait and see what details emerge. It can't be as bad as everyone is making it seem. - Karthik [more]
Unread 23-02-2003, 18:12
157#1Driver's Avatar
157#1Driver 157#1Driver is offline
Pro E King
#0157 (AZTECHS 157)
157#1Driver is an unknown quantity at this point
Send a message via AIM to 157#1Driver
Stackers
I've seen many well built robots that can pick up boxes and stack at the same time. In 99.9% of the pictures, the boxes are all upright. Can anyone make a stack while picking up boxes that are not up right?
157 The Aztechs
Luck of the Irish
157 - 12 years and still going
Unread 23-02-2003, 18:24
Duke 13370's Avatar
Duke 13370 Duke 13370 is offline
C is for cookie...
#0862 (Team Lightning)
Team Role: Webmaster
Duke 13370 will become famous soon enough
Send a message via AIM to Duke 13370
in theory, assuming that we finish with some of the little systems.
---Lightning Robotics!---
Unread 23-02-2003, 18:31
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
Although our stacker went into the box both unassembled and untested, it has hands which can rotate approximately 270 degrees which are designed to orient a box which is not upright.
I suspect that we will not have the thing working totally correctly til our second regional.
Unread 23-02-2003, 18:43
etoleb etoleb is offline
#0891 (Neverending Chaos)
etoleb is an unknown quantity at this point
Send a message via AIM to etoleb
Yes, we designed the robot so that it can grab the boxes in any orientation. During practices, we stacked bins upside down, sometimes with a sideways bin on top. Once we organize our photos and video footage, we'll probably post some pictures.
Greg
Who am I?
I'm that crazy guy with the duct tape tophat.
Neverending Chaos
Team 891
Annapolis '03 10th seed; Quaterfinalists (special thanks to teams 484 and 486)
Nationals '03
Unread 23-02-2003, 19:02
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
well, our team can pick up boxes in any orientation, but stacking them we found out that we can stack most of them
here's a link to a pic of us stacking this way
http://www.chiefdelphi.com/forums/pi...gle&picid=4020
and here
http://www.chiefdelphi.com/forums/pi...gle&picid=3936
Unread 23-02-2003, 19:03
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
We can pick up a box in any orientation and stack it in any orientation and we are very fast at it we have 3 axis motion on our arm ( with a lazy suzie on bottom ) in which we have an amazing amount of precision while stacking
That stack is to show you that we can stack any which way and balance it, we can also stack in the ordered fassion which seems to be popular ( bottom of box fitting into top of box )
this way we feel we will get a better multiplier because it is taller in shu's thus 2 boxes on top of each other gets us x3
:: edit bah I didn't know abe already posted :-) ::
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 23-02-2003, 19:40
sevisehda's Avatar
sevisehda sevisehda is offline
sevisehda is an unknown quantity at this point
Send a message via AIM to sevisehda
I'd consider a box upside down, to be virtually the same as a box upright. Varied orientation includes on the side, but more importantly at an angle to the bot, many pics show internal stackers that hold boxes long ways, can those bots come at a 45 degree angle to a box and grab it. What about crowded situations where boxes are close to each other on the floor. Can you grab a box thats at an angle, on its side, thats tightly packed with other bots? If so can you do it fast. Those are the real questions.
Unread 23-02-2003, 20:01
mav's Avatar
mav mav is offline
mav is an unknown quantity at this point
Send a message via AIM to mav
well from what i've seen at the scrimmages it is nearly impossible to get a stack over two high with the other robots ramming you while you are trying to make a stack.
Unread 23-02-2003, 20:27
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
We can pick-up in every orientation except upside down lengthwise. The most preferable stack is either upright or upside down the long way and we can manipulate most boxes into these configurations fairly quickly. We can lift a max of 6 boxes upright to make a stack of seven, and a max of 4 upside down for a stack of 5. One timed practice round we make 4 stacks of three and had time to get back on the ramp. We know it will be completely different with multiple bots but thats the best we can do.
Unread 23-02-2003, 20:32
soezgg soezgg is offline
Senior Member
AKA: Harry Miller
#0639 (The Rude Awakening)
soezgg can only hope to improve
Send a message via AIM to soezgg Send a message via Yahoo to soezgg
we finally rigged u p our bot to upright any bin in any orientation.
some bins take longer to orient than others, so i think that upright bins and upside down bins will be focused on for our team
Unread 23-02-2003, 20:52
Umm Errr...
[quote}Although our stacker went into the box both unassembled and untested[quote]
lol like our entire robot. wel lactually well, actually jst a last minute ajustment to out drive traun( we werusing just the chips and realized we had our bot geared too high soo we added in the drills)
1139 Alumni
Unread 23-02-2003, 20:58
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
The scrimmages have shown that stacking as a whole takes too much time to be truly effective. We can orient boxes just by setting our forklifts to the appropriate height, but it is much easier to simply steal the enemy's human player stacks, which by the rules have to be in the upright position. We just steal one of the enemy stacks at the beginning of the match and carry it around with us until the end, when we deposit it where we want to. The other added benefit is that carrying boxes = more mass = more traction for shoving matches.
this is how we did it
http://www.chiefdelphi.com/forums/pi...&quiet=verbose
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 23-02-2003, 21:27
Clanat Clanat is offline
Custom Title
#0753 (High Desert Droids)
Clanat has a little shameless behaviour in the past
In case you missed it in one of the first team updates, it was stated that stack heights will be rounded down to the next stack height unit, making up-side down etc. stacks pretty much useless.
Our stacker can only stack right side up boxes, but we have an easy method of orienting them.
Former Co-Captain
Winner NW Regional 2002 and 2003
Why was stacking so hard? Tton General Forum 39 16-03-2003 19:17
Props and Slops of the Granite State Regionals Rev. Lovejoy Regional Competitions 22 11-03-2003 15:24
Stackers mounting a comeback? soap108 Scouting 7 02-03-2003 20:48
Wall 'o Boxes etoleb Rules/Strategy 47 02-03-2003 18:22
