Go to Post Maybe it just seemed like five hours...I had freshmen in my vehicle! - Qbot2640 [more]
Unread 19-05-2014, 21:02
Dentyne_Ice97 Dentyne_Ice97 is offline
FRC #3965
Dentyne_Ice97 is an unknown quantity at this point
Motor Controller
Is it possible to run two CIM motors to one motor controller?
Unread 19-05-2014, 21:06
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Motor Controller
Yes, it's possible, but it's not recommended and not legal for competition under the 2014 robot rules. Use one controller per motor if you can.
Unread 19-05-2014, 21:09
FRC #3965
OK thanks, this isn't for a competition it is for a t-shirt cannon for our school. Is there a possibility the controllers were burn out?
Unread 19-05-2014, 21:17
EricH EricH is online now
Let me put it this way: CIMs can pull an awful lot of current. Let's assume that you run 40A per motor, which (can be) low, so 80A for the pair, and send that through your motor controller (Talon, Jag, or Victor). Note that it'll take a bit for your circuit's snap-action breaker to trip, and it'll untrip as soon as it cools off a bit. (Or, you'll end up with a case where the CIMs are not performing like CIMs due to only getting 1/2 the current they'd like.)
If you get into a situation where those motors are having to work hard, you're probably going to be buying another speed controller anyways, to replace the one you fried.
That said: Talons, Jaguars, and Victors are not the only speed controllers out there. Some of them might be a bit cheaper; some a bit more expensive. It might be a good idea to do a little research. (Trying to remember a couple of brands I've been known to see used in a project--one will safety itself off and refuse to turn back on, one will not.)
Is there a particular reason that you want to run two CIMs off of one speed controller?
Unread 19-05-2014, 21:20
cgmv123's Avatar
AKA: Max Vrany
Does this mean you've already tried this? Yes, speed controllers can burn out if you pull too much current and an extra CIM motor will double* the current draw. Jaguars are the most susceptible to this, but Victors and Talons have their limits as well.
*Not exactly the case if the motors are connected in a gearbox under load, but the current does increase significantly.
Unread 19-05-2014, 21:25
wilful's Avatar
wilful wilful is offline
766 Alum & 4212 Mentor
FRC #4212 (TechnoFerrets)
wilful will become famous soon enough
For the FRC approved motor controllers, it is quite possible to burn them out by running two CIMs through one. However, if you use one rated to handle the current draw of two CIMs, you will be fine (as far as the speed controllers are concerned, you may have issues with other electronic components).
Wilful
2009-2013 Student, FRC 766
2013-Present College Student and Mentor, FRC 4212
Unread 19-05-2014, 22:37
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We have run 2 cim motors on a single Talon WITH Fan and had no issue. I wouldn't recommend it, but it will work. I think you'd be better off forking out the money for another controller and just using a Y cable rather than potentially nuking one.
Unread 20-05-2014, 08:25
You can run the motors in series on one controller if you don't need the speed.
