Go to Post We found our bandsaw on Craigslist for $40. We keep looking for laser cutters and waterjets in that price range, but so far no luck. - chapman1 [more]
Unread 20-05-2014, 20:20
kleinian kleinian is offline
FRC #4531
kleinian is an unknown quantity at this point
Exclamation Broken Robot! Help Please!
Our team's kit bot has been acting strange lately. Everything seems normal, from connecting the robot to my computer with the IP switched to running the program in netbeans, (we use Java) but no matter what I do, the robot will NOT drive! Any information into how i can fix this will help a lot! Thanks!
Unread 20-05-2014, 20:22
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: Broken Robot! Help Please!
What mode is your radio in? Did you reprogram it since returning from competition? Use the Bridge Configuration utility here: http://wpilib.screenstepslive.com/s/...onent-overview
Unread 20-05-2014, 20:40
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Take the robot off the blocks
Other then that, I'm no help
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 20-05-2014, 20:43
zachrobo1's Avatar
zachrobo1 zachrobo1 is offline
AKA: Zach Cloud
FRC #1002 (The CircuitRunners)
zachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of light
You made sure that there was an actual established connection between your computer and the robot, right? Did you check that your joysticks are connected properly?
Team 1002 - Website - Facebook - Twitter - Youtube
Unread 20-05-2014, 20:44
What are all of the diagnostic indicator lights on the Driver Station display showing you? What is the pattern of flashes of the big orange Robot Signal Light? What are all of the LEDs on the robot doing? Telling us what it won't do is of little use without a description of what it does do.
Unread 20-05-2014, 21:02
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Has the code on the robot changed any since it last worked?
Has the robot physically changed ie removed/added anything, especially electrical components?
Is everything still plugged in that should be?
Do the motor controllers respond to input? Is there a mechanical issue with your drive?
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 21-05-2014, 00:57
I'm willing to bet that this is the issue. See it every year, with teams that forget or don't know, and you've got some of the classic symptoms: Robot that worked fine at competition suddenly doesn't work at home with no changes.
The other diagnostic that will tell you for sure: Tether it up. If it runs on the tether but not on the radio, your radio didn't get reconfigured.
Unread 25-05-2014, 15:05
FRC #4531
Just so everyone knows, we did NOT bring this robot to competition. This is our kit bot that we test stuff on at meetings.
Unread 25-05-2014, 16:03
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Does the robot enable correctly? What happens when you try to drive the robot? Do the lights in the speed controllers change?
-Plutarch
Unread 25-05-2014, 17:06
Briansmithtown's Avatar
Briansmithtown Briansmithtown is offline
Pilot shortage, Good thing Im tall
AKA: Brian Sheridan
FRC #0810 (Smithtown Mechanical Bulls)
Briansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond repute
We had a similar problem, which we found out the Digital side car was fried... I recommend smelling around the digital sidecar, and the motor controllers to smell the sweet smell no one wants.
2014 Team 810 Recap video https://www.youtube.com/watch?v=DS9K_j1FzF4
Unread 25-05-2014, 17:58
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Does the robot enter enabled mode, but the motor controllers just keep blinking? If so it could either be the Sidecar being fried as mentioned above, or the cable from the cRIO to the Sidecar is loose or broken.
If it does not enter enabled mode, does it actually connect to the robot at all? Which, if any, of the 3 red/green lights on the driver station are red? (Communications, code, joysticks)
Unread 25-05-2014, 20:37
dmaciel10123 dmaciel10123 is offline
The Everything Guy
AKA: David Maciel
FRC #3525 (The Nuts and Bolts of Fury)
dmaciel10123 is an unknown quantity at this point
As was mentioned earlier, if you're connected but it just won't drive, check the lights on the motor controller as well as check the sidecar and cRIO. Also, a Robot Signal Light should be on the robot to help with a visual aid to tell you what the robot is and/or should be doing at the time.
Unread 26-05-2014, 02:39
Jpatterson1710's Avatar
Jpatterson1710 Jpatterson1710 is offline
AKA: Josh Patterson
FRC #1710 (Ravonics Revolution)
Jpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura about
We always troubleshoot by looking at each component as we move from human input to robot actions. Start with the DS, check connections of all joysticks/controllers(Joysticks in the correct position in the DS). Check DS to Robot Comms(Use a tether then use wireless). Check to see if the DS is communicating with the CRio (Is the CRio IP set correctly). Check to see if the CRio is sending information to the sidecar(Is the cable loose/frayed, is the RSL flashing). Check to see if the sidecar is sending information to the speed controllers(PWMs connected). Sound redundant? It is. If you look at each piece as it moves down the line, it can be much more simple to pinpoint where it goes wrong.
2012-2014 Mechanical Team FRC 1710
2014-2015 Chief Operations Officer FRC 1710
2016-Present FTAA
