Go to Post Wait - a single message outlining the vast majority of where to find controls stuff? Goodness. What will they think of next. - Tom Line [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 21-05-2014, 12:54
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Re: 971's chassis
Based on the pictures it looks like you're adding a countersink before putting in your rivets. This seems rather time consuming, so I'm guessing there is a good reason. Care to elaborate?
Unread 21-05-2014, 13:27
Madison's Avatar
Madison Madison is online now
Dancing through life...
FRC #0488 (Xbot)
Re: 971's chassis
Originally Posted by AustinSchuh View Post
We ran the "original" 3 piece design in 2012 and 2013, and it has served us very well.
We couldn't find a way to make an octagon with a 3 piece chassis, which means it probably isn't possible or easily to machine. We wanted an unbroken flange to help form a backbone to tie everything to and to tie everything together. The best way to do that that we found was to set the chassis up as you see this year. We started by figuring out where to put the wheels and pulleys, and then built the frame to hold everything in place. This resulted in the jog on the inner face, which resulted in an internal corner which couldn't be bent without breaking things up into more pieces. We also needed a parallel face to bolt the wheel tensioners to, which drove the inner frame rail shape that you see. You can see the set of 8 #6 holes that define the tensioner location in one of the pictures.
Austin,
Is the CAD model for this available somewhere? I'd like to take a closer look at how you worked around the internal bends on that inner face.
--Madison--
...down at the Ozdust!
Unread 21-05-2014, 14:02
James Kuszmaul James Kuszmaul is offline
NEFIRST CSA
FRC #0971 (Spartan Robotics)
James Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud of
Re: 971's chassis
If we had to do the countersinks ourselves, yes it would be time consuming, but it is relatively easy for our sponsors to quickly do the countersinks (and to do them right for the rivets). This then reduces the number of protrusions that we have to avoid interfering with or that might catch on things.
FRC971 (Student) 2011-2014
FRC190 (College Mentor-ish) 2014
WPILib Development 2014-present
Unread 21-05-2014, 16:03
Re: 971's chassis
We use countersunk rivets. There are punches on the CNC turret punch which will make a .129 hole that is countersunk to 120 degrees, all in 1 hit. This makes it so the bottom, front, and sides of our bot are perfectly smooth and can't catch on anything.
Unread 21-05-2014, 16:05
Re: 971's chassis
Madison,
The CAD model isn't available, and we have no plans to release it. We subscribe to the 254 CAD release philosophy, and choose to share pictures and explain the why about what we do rather than directly share the model. We have a team meeting tonight though, and I'll (try to) have one of the students put together an exploded view that should answer your question.
Unread 21-05-2014, 16:10
Re: 971's chassis
Originally Posted by saikiranra View Post
What is the advantage of having the center drive wheels offset right/left, compared to other traditional 6 wheel drive set-ups?
We wanted our frame perimeter to be an octagon to change how the robot interacts with the field and other robots. The wheel placement was chosen to maximize the space in the center of the frame once we had decided on the frame perimeter.
Unread 21-05-2014, 17:03
Madison's Avatar
FRC #0488 (Xbot)
Re: 971's chassis
Madison,
An exploded view would be great. I think I have a pretty good idea of what those pieces look like, but the exploded view will help me to figure out if I'm missing anything.
Thanks!
--Madison--
Unread 21-05-2014, 22:48
SeanKennedy SeanKennedy is offline
FRC #1647
Team Role: Driver
SeanKennedy is an unknown quantity at this point
Re: 971's chassis
Pem nuts are great. They come in multiple different designs for different applications. We typically use an f- series nut because it is flush on both sides and is extremely to install correctly. They are much much stronger than just threading aluminum and they are a blind fastener when it comes to the installation aspect, so there is no need for any access to reach a nut or other piece of hardware on the back side. An f series nut can be installed with any hydraulic or arbor press, and most rivet squeezers.
When we cant access the back of a part, we used a rivnut which is a completely blind fastener as only one side of the material needs to be accessed to install the part. these parts are great for putting threads in tubes or in really odd spots. They can be found at our sponsors web site: enfasco.com
Unread 22-05-2014, 00:08
NEFIRST CSA
Re: 971's chassis
Thanks!
We've put up some shots of our drivebase CAD on our picasa page.
Unread 22-05-2014, 00:10
Madison's Avatar
FRC #0488 (Xbot)
Re: 971's chassis
That was speedy. Thanks so much.
--Madison--
Unread 22-05-2014, 00:16
AdamHeard's Avatar
Lead Mentor
Re: 971's chassis
I love that axle retention method.
Unread 22-05-2014, 01:48
Re: 971's chassis
I also like that the bushings that the axle go into. They both make it easy to get the axle out, and stick out a bit to replace spacers so that the bearing race on the wheels doesn't rub on the tensioner.
Unread 22-05-2014, 22:10
BrianSilverman BrianSilverman is offline
BrianSilverman has much to be proud ofBrianSilverman has much to be proud ofBrianSilverman has much to be proud ofBrianSilverman has much to be proud ofBrianSilverman has much to be proud ofBrianSilverman has much to be proud ofBrianSilverman has much to be proud ofBrianSilverman has much to be proud ofBrianSilverman has much to be proud of
Re: 971's chassis
Originally Posted by Travis Schuh View Post
We align the wheel angle by eye. It turns out that the human eye is pretty good at judging this, we typically sight if the wheel is parallel to the lightening hole. We have never had an issue of having a miss-aligned wheel.
However, it's important to check the lightening hole is straight first (they weren't in 2012 and it was a pain)...
In addition to doing it by eye, the belts always track to one side or the other of the pulley as they spin. When we tighten the belts, we sometimes spin the drivetrain by hand to see which side the belts move to and then tweak it the other way to fine-tune it.
Also, I've seen some wheels that were fairly crooked (I'd guess 10-15 degrees eyeballing it) after running matches or practice (usually caused by a bad job tensioning and/or one of the tensioner bolts backing out), and the belts seem fine afterwards, so it doesn't seem to be a very big deal.
Unread 22-05-2014, 22:50
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
Re: 971's chassis
If you don't mind, I've got a few questions.
1. How much does the assembly weigh?
2. How much is the drop center?
3. What is the gear ratios on the drive gearbox?
4. What is the diameter of you wheels?
5. What is the thickness of your sheet metal?
Thanks in advance!
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 22-05-2014, 22:51
highlander's Avatar
highlander highlander is offline
Registered Boss
Team Role: Student
highlander has a spectacular aura abouthighlander has a spectacular aura abouthighlander has a spectacular aura about
Re: 971's chassis
have you tried screw lock helical inserts to prevent the bolts from backing out due to vibration?
