Go to Post It is great to be proud of the way you do things, but to imply that everyone should match your way of thinking, is ludicrous. - JVN [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 22-05-2014, 22:10
BrianSilverman BrianSilverman is offline
FRC #0971 (Spartan Robotics)
BrianSilverman has much to be proud ofBrianSilverman has much to be proud ofBrianSilverman has much to be proud ofBrianSilverman has much to be proud ofBrianSilverman has much to be proud ofBrianSilverman has much to be proud ofBrianSilverman has much to be proud ofBrianSilverman has much to be proud ofBrianSilverman has much to be proud of
Re: 971's chassis
Originally Posted by Travis Schuh View Post
We align the wheel angle by eye. It turns out that the human eye is pretty good at judging this, we typically sight if the wheel is parallel to the lightening hole. We have never had an issue of having a miss-aligned wheel.
However, it's important to check the lightening hole is straight first (they weren't in 2012 and it was a pain)...
In addition to doing it by eye, the belts always track to one side or the other of the pulley as they spin. When we tighten the belts, we sometimes spin the drivetrain by hand to see which side the belts move to and then tweak it the other way to fine-tune it.
Also, I've seen some wheels that were fairly crooked (I'd guess 10-15 degrees eyeballing it) after running matches or practice (usually caused by a bad job tensioning and/or one of the tensioner bolts backing out), and the belts seem fine afterwards, so it doesn't seem to be a very big deal.
