Go to Post It doesn't matter what goes wrong as long as you have fun. We all thought this was one of our best trips, even though we were second to last in our divison. - afowl [more]
Unread 24-05-2014, 16:19
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
pic: Custom 3 CIM 2 Speed Gearbox
Unread 24-05-2014, 16:24
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: pic: Custom 3 CIM 2 Speed Gearbox
What spread are you using?
I take it this is designed to mount into a non WCD style drive? I bet you could probably flip the motors around and hang this over your wheels if you use a 24:60. Also I think your weight calculations are off. To be almost 2 lbs lighter than the DS Standard 3 CIM you'd have to weigh: ~2.8 - 2 = .8 lbs
http://puu.sh/8Zy3d/55951f0c15.png
and your probably around the same weight due the fact the internals + motor weight is about the same. Weight of 3 CIM DS Standard (Non WCD)
http://puu.sh/8ZxQA/bb0bb3d496.png
EDIT: *Are you comparing weight to the 3 CIM WCD with PTO?*
R.C.
MadTown Robotics Team 1323
Unread 24-05-2014, 17:03
FF TSL: Frog Farce
The spread is 3.64. It is for a sheet metal, non WCD chassis. I considered putting the motors over the wheels, but I decided that the CG benefits of lowering 17 pounds around 4 inches would be more beneficial. My weight estimate only says 10.999 lbs, but I was comparing it to the 12.94 value from http://www.wcproducts.net/wcp-shifter-3cim/ (Standard, non-WCD, with 3 14t motor pinions, motors and 1 pneumatic cylinder). I think mine has one or two fewer gears and is thinner, but .2 lbs can probably account for that. I wonder how they got 12.94 lbs?
Unread 24-05-2014, 17:11
Jared's Avatar
Jared Jared is offline
Looks cool! I like the layout.
But then he'd loose the reduction with the chains.
I'm not sure that it will be a problem, but the pinion gear on the middle CIM is going to have twice the load the others would have. I know that some teams with a similar layout have the idler gear between a CIM and the next stage of reduction, as opposed to between two CIMs.
Unread 24-05-2014, 17:15
R.C.'s Avatar
Makes sense. I normally value space savings vs CG. I've been a bit envious of 125's setup this past year.
The "builder" on the site doesn't work so hot, its mainly an approximation for shipping. We'll be fixing that value in the coming months with a site update.
R.C.
Unread 24-05-2014, 17:17
R.C.'s Avatar
For this setup it wouldn't really matter as you can just get a larger reduction in the chain setup. It would be a much larger deal if the OP decided to direct drive a wheel.
R.C.
Unread 24-05-2014, 17:43
FF TSL: Frog Farce
My FEA gave the middle pinion a safety factor between 3 and 5, but it will be something that we inspect regularly. We're designing a drivetrain that should generally avoid pushing matches, so I'm not too worried about it, and if it does break, we'll have weeks to fix it unlike in the build season. I think 254 may have done something similar last year (2013) in their gearbox with a dual loaded pinion, but I'm not certain if they did or if it worked well.
Unread 24-05-2014, 22:26
Knufire Knufire is offline
If I remember correctly, 254's 2014 gearbox had a similar layout with the motor pinions.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 24-05-2014, 23:20
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Here is an image of 254's [unpopulated] gearbox.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
