Go to Post The robot was spinning, I dont have the energy to spin like that. - Joe Menassa [more]
Unread 24-05-2014, 21:05
DjParaNoize-'s Avatar
DjParaNoize- DjParaNoize- is offline
DjParaNoize- is an unknown quantity at this point
Gearbox Mentoring
I know this is a very "Rookie" Question but I will ask it anyway. Would anyone be willing to guide me and teach me how to design and build a custom gearbox?
Unread 24-05-2014, 21:12
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Gearbox Mentoring
Check out 973's videos. They cover the CAD part very well.
http://www.greybots.com/videos.html
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 24-05-2014, 21:18
I don't think they cover gearbox ratios and etc.
Unread 24-05-2014, 21:27
Are you more on the "Where do I start" part of the spectrum, or "I have a specific question?"
First step I usually tell students is to download the JVN Design Calculator.
Unread 24-05-2014, 21:38
Chris is me's Avatar
AKA: Pinecone
PM me if you'd like me to help. Were you thinking more of an article / guide or more chat-style help? Do you have a particular application in mind?
Unread 24-05-2014, 21:39
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Gearbox design involves quite a few topics. More than should be condensed into one post. I can address your ratio question in this one. (I'm assuming you are starting at the very beginning by the way)
For the purposes of this post we will ignore the existence of the rest of the gearbox in the attached photo (the rest of it should be coming up in CD media soon).
Highlighted/blue gear would be called the output gear and the smaller gear to the right attached to the motor is the pinion. Pinion refers to the gear attached to the power source or the input. Generally the gear ratio is expressed as the number of teeth of the output over the number of teeth of the input, in this case 44/11 or 4/1 or 4:1.
basically every time the pinion spins 360deg it advances 11 teeth and the output advances 11 teeth. 11 teeth = 1/4 of the teeth on the output gear resulting in 1/4 a rotation of it for every whole rotation of the input.
This US Navy video from 2:08 to 4:37 is a great example:https://www.youtube.com/watch?v=s1i-...jLyVmGXSxTl-KQ Note he exspesses his ratio as input over output or the reverse of what I use above.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 24-05-2014, 21:59
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
I wish I had seen that pocketing video yesterday...
Unread 24-05-2014, 22:25
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
I did a presentation for my team's newer members on this and used this to explain and show gear ratios. http://www.gearsket.ch/
I also sketched up roughly what a drivetrain ends up being inside of it.http://i.imgur.com/frgi7EU.jpg?1
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 25-05-2014, 02:43
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Be sure to note that 99.9% of the time, the ratio between the inter and outer wheels is 1:1. You've got a reduction from your center wheel to your outer wheels in the second image.
-Plutarch
Unread 25-05-2014, 09:48
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Yep, I know its drawn that way because of the limitations of the website
