Go to Post ...there's nothing worse than a problem you can't solve because you don't even know about it. - Dave Flowerday [more]
Unread 25-05-2014, 01:29
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
pic: Another Drive for CD.
Unread 25-05-2014, 01:44
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: pic: Another Drive for CD.
Looks like a great start!
Few comments:
1. Why are the gearboxes not symmetrical? It doesn't seem like your cbore'n the holes so you could assemble two different gearboxes with the same components. Similar to the gearbox below.
Poofs PTO guy from 2013 - http://puu.sh/907Xp/226027b712.jpg
2. It seems as your direct driving the center wheel, why not use VersaPulleys (Larger Diameter) to save cost and load the belts less?
3. Do you have a Versahub + bearing on each wheel? I can't see if there a bearing supporting the other end of the wheel.
4. Also outer wheels could be dead vs live. You could get rid of the versahub and move bearings into the wheel/pulley.
5. Any reason for not jumping down to 4" wheels?
R.C.
MadTown Robotics Team 1323
Unread 25-05-2014, 11:35
jman4747's Avatar
AKA: Josh
Team Role: CAD
The gearboxes and plates are interchangeable between sides by flipping them about one of their axis's I just chose the put the same assembly in. I didn't feel like mirroring it that day so yes it could be arranged in either manner.
The wheels each have a versa hub on the inside and one or two 30t vex pro pulleys on the inner two and outer four wheels respectively. The pulley size was more to get the wheel spacing I wanted in terms of belt spacing.
Originally my idea with was to make something with more ground clearance for use outdoors however, at some point I realized this setup had some constraints which wouldn't allow how much I wanted so I just said whatever and stuck with the 6". Figured I'd see where it brought me and do another one later. As it is 4" wheels could be added in.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 25-05-2014, 13:08
Henrique Schmit's Avatar
Henrique Schmit Henrique Schmit is offline
FRC #1156 (Under Control)
Team Role: CAD
Henrique Schmit is an unknown quantity at this point
I believe that you could increase your drop center a bit, 1/16 is too low, 971 uses 3/16, maybe you want to use that.
Do you know if those vex traction wheels have holes to rivet down the tread or you have to use their diamond shaped tread?
Ready for the water games
http://i.imgur.com/QQXtifE.jpg
Unread 25-05-2014, 13:15
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
I don't remember if they have holes predrilled, but if not, it's easy to drill holes yourself for tread attachment. We've used them with roughtop tread for the last two years.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 25-05-2014, 14:49
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
You can either use VexPro's Traction Tire (Vex P/N 217-2860 for 6"), or drill holes to rivet your own tread.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
