Go to Post I want to win, but I want to beat my opponent when they are at their best. - wilsonmw04 [more]
Unread 25-05-2014, 22:54
raystubbs's Avatar
raystubbs raystubbs is offline
Programmer, Builder, Designer
FRC #2657 (Thundercats)
Team Role: Student
raystubbs will become famous soon enough
Re: Android Driver Station
Originally Posted by dmaciel10123 View Post
Okay, so, I tried the app today after we got eliminated and everything worked: joysticks and buttons. I still haven't gotten the image to show but I am continuing to work on it and hope to have it working soon.
It's good that everything still works. Any idea why Dr.Gusta's didn't work? I have no idea.
"If all else fails, read the instructions."
Unread 25-05-2014, 23:07
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Chiller is on a distinguished road
With my iPhone version I have had it where the robot code gets initialized but the run code does not and also the RSL does not signal that it is enabled.
It was because the timing on sending the packets was off, it has to be exactly 0.02 seconds.
Unread 26-05-2014, 09:31
raystubbs's Avatar
Team Role: Student
Thanks for the information, I'll try to fix this.
Unread 26-05-2014, 09:33
raystubbs's Avatar
Team Role: Student
I got the video to work, I used dmaciel10123's idea to get it to work, it may not be very fast, I have no idea how it will work since I have only tested it on an emulator. Feedback is appreciated.
Unread 27-05-2014, 21:20
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
I submitted a pull request that should make it easier to allow people to work on your code. It adds a .gitignore file that ignores the Eclipse build directory and auto-generated files. This makes it so only changes to code and other important files actually show up in the commit so people do not need to merge in a bunch of minor changes each time you push to the repo.
I hope you consider this. Thanks, Ben.
Unread 27-05-2014, 22:08
jpkelly26 jpkelly26 is offline
FRC #1807
jpkelly26 is an unknown quantity at this point
This is sweet! Thanks.
Installed successfully on Samsung Galaxy SIII running Android 4.3 and on a Motorola Xoom tablet running Android 4.1.2. Next step, get access to our robot!
Unread 28-05-2014, 16:50
guniv's Avatar
guniv guniv is offline
Communications / Business
AKA: Josh Witt
FRC #3966 (L&N STEMpunks)
guniv has a spectacular aura aboutguniv has a spectacular aura aboutguniv has a spectacular aura about
Now that the iOS app is out, maybe work with them and see how they got features working? You guys are competing in different markets, so collaboration would help a lot. They've gotten video working on their end, apparently. Gonna have some team members pick up the app (our school is 1:1 tech on iPads) and see what they think.
Unread 09-06-2014, 10:03
guniv's Avatar
AKA: Josh Witt
This thread is quite dead. Ray's GitHub seems to be taken down as well.
In any case, I used this app with my Nvidia Shield and it's built in Gamepad Mapper this weekend at a carnival we were at this weekend, and drove around one of our stripped down chassis. I was also able to hand off the Shield to other people and let them drive, like the kid in this video.
Unread 09-06-2014, 10:29
dmaciel10123 dmaciel10123 is offline
The Everything Guy
AKA: David Maciel
FRC #3525 (The Nuts and Bolts of Fury)
dmaciel10123 is an unknown quantity at this point
The GitHub is still up, it's just at a different repo now.
https://github.com/raystubbs/Andrid-FRC-Driverstation
Unread 09-06-2014, 10:36
guniv's Avatar
AKA: Josh Witt
Oh! My bad. Thanks!
Unread 09-06-2014, 16:44
Just released the native iPad version so make sure you update!
Unread 09-06-2014, 16:47
I just use a simple html document that loads the feed and if it times out then it displays a message, all with jQuery
Just load the html file into a string and replace {jquery} with the contents of a jquery library file and also replace {te} and {am} with teamNum / 100, teamNum % 100, and also replace width and height with the web views width and height and wallah!
<html>
	<head>
		<script type="text/javascript">{jquery}</script>
            var timeout;
			$(function() {
				$("#errordiv").click(reload);
				$("#stream").click(reload);
				reload();
			function reload()
				$("#error").text("Loading Camera...");
				$("#stream").attr("src", "http://10.{te}.{am}.11/mjpg/video.mjpg?resolution=640x480&fps=30");
                timeout = setTimeout(function() {
                    //Cam did not load
                    $("#error").html("Error Loading Camera<br/>Tap to Refresh");
                    $("#stream").css({"display":"none"});
                    $("#errordiv").css({"display":"block"});
                }, 4000);
				$("#stream").load(function() {
					$("#stream").css({"display":"block"});
					$("#errordiv").css({"display":"none"});
                  clearTimeout(timeout);
				}).error(function() {
		</script>
	</head>
	<body style="padding: 0; margin: 0;">
		<div id="errordiv" style="display: none; background: lightgray; height: 100%; text-align: center;">
			<label id="error" style="position: relative; top: 40%;">Tap to refresh camera</label>
		</div>
		<img id="stream" width="{width}" height="{height}"/>
	</body>
</html>
