Go to Post Wait hold the phone. Do you mean its physically possible to not spend time on robotics during the season?!!! Too much.......for brain......to compute!...goes against.....beliefs........aaaaarrrrrrghhhhhh!!! [syntax error] - BuddyB309 [more]
  #91   Spotlight this post!
Unread 25-05-2014, 23:07
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Chiller is on a distinguished road
Re: Android Driver Station
Originally Posted by raystubbs View Post
It's good that everything still works. Any idea why Dr.Gusta's didn't work? I have no idea.
With my iPhone version I have had it where the robot code gets initialized but the run code does not and also the RSL does not signal that it is enabled.
It was because the timing on sending the packets was off, it has to be exactly 0.02 seconds.
  #92   Spotlight this post!
Unread 26-05-2014, 09:31
raystubbs's Avatar
raystubbs raystubbs is offline
Programmer, Builder, Designer
FRC #2657 (Thundercats)
Team Role: Student
raystubbs will become famous soon enough
Thanks for the information, I'll try to fix this.
"If all else fails, read the instructions."
  #93   Spotlight this post!
Unread 26-05-2014, 09:33
raystubbs's Avatar
Team Role: Student
I got the video to work, I used dmaciel10123's idea to get it to work, it may not be very fast, I have no idea how it will work since I have only tested it on an emulator. Feedback is appreciated.
  #94   Spotlight this post!
Unread 27-05-2014, 21:20
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
I submitted a pull request that should make it easier to allow people to work on your code. It adds a .gitignore file that ignores the Eclipse build directory and auto-generated files. This makes it so only changes to code and other important files actually show up in the commit so people do not need to merge in a bunch of minor changes each time you push to the repo.
I hope you consider this. Thanks, Ben.
  #95   Spotlight this post!
Unread 27-05-2014, 22:08
jpkelly26 jpkelly26 is offline
FRC #1807
jpkelly26 is an unknown quantity at this point
This is sweet! Thanks.
Installed successfully on Samsung Galaxy SIII running Android 4.3 and on a Motorola Xoom tablet running Android 4.1.2. Next step, get access to our robot!
  #96   Spotlight this post!
Unread 28-05-2014, 16:50
guniv's Avatar
guniv guniv is offline
Communications / Business
AKA: Josh Witt
FRC #3966 (L&N STEMpunks)
guniv has a spectacular aura aboutguniv has a spectacular aura aboutguniv has a spectacular aura about
Now that the iOS app is out, maybe work with them and see how they got features working? You guys are competing in different markets, so collaboration would help a lot. They've gotten video working on their end, apparently. Gonna have some team members pick up the app (our school is 1:1 tech on iPads) and see what they think.
  #97   Spotlight this post!
Unread 09-06-2014, 10:03
guniv's Avatar
AKA: Josh Witt
This thread is quite dead. Ray's GitHub seems to be taken down as well.
In any case, I used this app with my Nvidia Shield and it's built in Gamepad Mapper this weekend at a carnival we were at this weekend, and drove around one of our stripped down chassis. I was also able to hand off the Shield to other people and let them drive, like the kid in this video.
  #98   Spotlight this post!
Unread 09-06-2014, 10:29
dmaciel10123 dmaciel10123 is offline
The Everything Guy
AKA: David Maciel
FRC #3525 (The Nuts and Bolts of Fury)
dmaciel10123 is an unknown quantity at this point
The GitHub is still up, it's just at a different repo now.
https://github.com/raystubbs/Andrid-FRC-Driverstation
  #99   Spotlight this post!
Unread 09-06-2014, 10:36
guniv's Avatar
AKA: Josh Witt
Oh! My bad. Thanks!
  #100   Spotlight this post!
Unread 09-06-2014, 16:44
Just released the native iPad version so make sure you update!
  #101   Spotlight this post!
Unread 09-06-2014, 16:47
I just use a simple html document that loads the feed and if it times out then it displays a message, all with jQuery
Just load the html file into a string and replace {jquery} with the contents of a jquery library file and also replace {te} and {am} with teamNum / 100, teamNum % 100, and also replace width and height with the web views width and height and wallah!
<html>
	<head>
		<script type="text/javascript">{jquery}</script>
            var timeout;
			$(function() {
				$("#errordiv").click(reload);
				$("#stream").click(reload);
				reload();
			function reload()
				$("#error").text("Loading Camera...");
				$("#stream").attr("src", "http://10.{te}.{am}.11/mjpg/video.mjpg?resolution=640x480&fps=30");
                timeout = setTimeout(function() {
                    //Cam did not load
                    $("#error").html("Error Loading Camera<br/>Tap to Refresh");
                    $("#stream").css({"display":"none"});
                    $("#errordiv").css({"display":"block"});
                }, 4000);
				$("#stream").load(function() {
					$("#stream").css({"display":"block"});
					$("#errordiv").css({"display":"none"});
                  clearTimeout(timeout);
				}).error(function() {
		</script>
	</head>
	<body style="padding: 0; margin: 0;">
		<div id="errordiv" style="display: none; background: lightgray; height: 100%; text-align: center;">
			<label id="error" style="position: relative; top: 40%;">Tap to refresh camera</label>
		</div>
		<img id="stream" width="{width}" height="{height}"/>
	</body>
</html>
  #102   Spotlight this post!
Unread 09-06-2014, 19:59
m1506m's Avatar
m1506m m1506m is offline
FRC #1506
m1506m is an unknown quantity at this point
Tried the app out tonight, I am able to connect and enable, but since we are set up for cheesy drive, and not tank, I can only go forward and backward. And after about a minute the connection turns off and I loose connection.
  #103   Spotlight this post!
Unread 21-06-2014, 12:07
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
After connecting to the Robot wifi and launching the app, does the app handle everything necessary with IP addresses (in other words, should it just work out of the box like that?)
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
  #104   Spotlight this post!
Unread 21-06-2014, 13:13
guniv's Avatar
AKA: Josh Witt
We've had to go in through Android's Wi-Fi settings and set the static IP ourselves.
  #105   Spotlight this post!
Unread 23-06-2014, 20:59
raystubbs's Avatar
Team Role: Student
Sorry for all the problems, some of them may have been caused by bandwidth taken by the video, which I haven't tested. I only have a kindle fire to test with and it worked perfect before I added the video code. I'm not in the U.S right now and don't have access to any robots. I will try to buy another device by the beginning of the school year, so I'll be able to debug for another device.
Reminder: This is an open source project, a pretty easy project, and my first android app. So anyone interested in trying their hand at android development this would be a good place to start.
