Go to Post In other words, don't worry about the results but strive for excellence in the way you live your life and everything you do. - Paul Copioli [more]
Unread 24-01-2014, 18:36
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Re: pic: SolidWorks Electrical KOP - Beta
Originally Posted by Michael Hill View Post
I can't be the only one confused about the wire running straight through the 40-amp breakers, can I?
Anyway, I look forward to using SolidWorks Electrical next year. It seemed like a bit too much to learn in too little time for this year.
Good catch - usually wires dont do that. That's why its in Beta - needed to put a few more points in to route the wire.
This is human error - at least you can see that you got an issue. Marie
Unread 24-01-2014, 18:40
Certainly we have some more work to do. I appreciate all the feedback. Keep it coming.
It's very tight on the kitbot. Wire looks so much smaller when it is a line on a schematic.
We are trying to get all the connectors and the components right for the SolidWorks Electrical KOP. So many pins, so many connectors.
Unread 24-01-2014, 21:29
Michael Hill's Avatar
Michael Hill Michael Hill is online now
Don't fret much about it. It looks like some awesome stuff. I can't wait to try it out.
Unread 25-01-2014, 00:35
Thank you for comment. I am used to dealing with robots that have control boxes - but I am learning all the fun parts to the FRC Control system.
The process to download and install SolidWorks Electrical is a bit more complicated than SolidWorks.
Install SolidWorks first. 1 serial number installs SolidWorks, Simulation, PhotoView 360, SolidWorks Motion, CircuitWorks (imports IDF, PADS).
With SolidWorks Electrical, follow the download instructions in the email. We are providing SolidWorks Electrical through a secure file transfer site. You are sent the username and password and number of activations.
Once installed, there will be 2 icons on your desktop, one for SolidWorks Electrical Schematic and one for SolidWorks (the one you know and love).
When you install SolidWorks Electrical, an Add In becomes available inside of your SolidWorks. You must Add In SolidWorks Electrical 3D to SolidWorks.
Control Systems single line and multiline schematics start with SolidWorks Electrical Schematic, not SolidWorks.
Unread 25-01-2014, 01:23
TJ_Watson's Avatar
TJ_Watson TJ_Watson is offline
RBE/ME undergrad
FRC #0190 (Gompei and the HERD)
TJ_Watson will become famous soon enough
It's important the teams know what the errors are in the current electrical model, so they don't try to wire it "like the picture" and blow the PD board or something.
Here is a list of errors in the wiring in no particular order:
-There are two cRIO components, and they are wired together
-No power to cRIO
-No power to Analog Breakout
-Signal Light is not plugged in
-All three versions of the ESCs (i.e. all speed controllers) are present, you should choose one set for the model, not have all 3 chosen and visible
-No power to DLink (also no power to converter)
-Battery bypasses main breaker and feeds into the 12v output on the PD board
That's why we beta test! All of that being said, I can't wait to sink my teeth into Electrical, it makes virtual wiring look really nice.
Unread 25-01-2014, 10:30
Thank you TJ for finding these issues. We will take the SolidWorks Electrical KOP down, fix the issues and create a Beta 2 SolidWorks Electrical KOP.
Teams can still download SolidWorks Electrical and review tutorials and the installation process.
But we want to do what is right - every one of the control components contains alot of information. We have to make certain they are defined electrically correct - its like making a spec sheet come alive.
Thank you for everyone who has provided feedback for beta 1.
Marie
Unread 27-05-2014, 23:16
baumgartensam's Avatar
baumgartensam baumgartensam is offline
AKA: Sam Baumgarten
FRC #0751 (Barn2Robotics)
baumgartensam will become famous soon enough
Are there any updates on this? I noticed a little while back the download link was pulled. For a while it said that a Beta 2 was being created, now, there is no mention of it.
Unread 28-05-2014, 17:23
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
I wasn't on CD when this thread first came around and since it was already necro'd, I figure I'll add to this particular posting...
Originally Posted by Alan Anderson View Post
Please remind them not to bury the D-Link router deep in the robot. Have them find a place up high where its radio antennas won't be bothered by proximity to the cRIO, battery, speed controllers, 12v-to-5v converter, motors, or metal framing.
Another reason to not bury it is purely selfish on my part. As an FTAA I like to be able to see the status LEDs so that I can tell a drive team that the radio isn't in bridge mode before a match, hence they aren't connecting to the field. The second main reason being why they couldn't drive for a 10 second period during a match while the radio was busy rebooting and they probably ought to check the power connections and not try to call a field fault. I can't believe how many radios are buried at the bottom of the bot preventing this.
Unread 07-06-2014, 18:36
Working on beta 2 this summer to be ready for the Fall. Some components have not been defined yet.
You can apply for a SolidWorks sponsorship now for the next season at www.solidworks.com/first.
You receive SolidWorks and SolidWorks Electrical software now.
