| Thread Tools |
Rating:
Display Modes |
#16
Re: FTC - Tetrix kit vs. Matrix kit?
As for the debate here, we don't really use much of the either kit but we use tetrix because we already have the very large inventory. I don't think we will switch unless we have too. I think that as each year passes, less and less will be restricted. Last edited by orangemoore : 27-05-2014 at 22:51. |
#17
Our FTC team 3507 has used only Tetrix kits for 5 seasons now, but with the relaxed material rules of the last 2 years, we are phasing out use of very much of the Tetrix channel in favor of 20mm slotted framing with 10-32 assembly H/W.
As noted, the Tetrix axles are horribly weak and ill suited to high torque with bidirectional rotation. We will not use them for anything but low torque transfer purposes. The hollow 5/8" tube end fitting scheme, though improved with new parts is still not great either. Tetrix channel is good for quick prototyping. There are also useful tricks, that allow overcoming some of its weaknesses. Some are shown in PICs below: ![]() ![]() ![]() ![]() |
#19
Because each VRC season begins the day after the prior VRC world championship (mid-April), middle school students (who often *need* it) typically can enjoy a nice long build season before the North American tournament season is in full-swing, and they can study southern hemisphere teams' progress to get field-tested construction and strategy ideas. The BEST program and equipment might be another option. FTC/VRC/BEST/etc. all give students fun and inspiring experiences and challenges. Be a wise consumer and review them all to see which one matches your students' needs. GBlake Last edited by gblake : 03-06-2014 at 16:26. |
#20
I'm new to the Matrix kit. If you could modify it in a way, what would you modify? |
#21
https://lh5.googleusercontent.com/-c...-50-18_416.jpg http://i872.photobucket.com/albums/a...6.jpg~original Only 2 Matrix pieces had to be cut on the entire robot to assemble it. I'd make the set screws more resilient - they have a nasty tendency to come loose. -JTN |
#22
Robogamers made a video reviewing the Tetrix Kit of Parts as well as building both the tetrix ranger bot and the matrix bot. You can see the two side by side. Here are the links:
Robogamers tetrix kit: https://www.youtube.com/watch?v=EDSCy-9WVfA Tetrix Ranger bot: https://www.youtube.com/watch?v=jnt3EVZaCxQ Matrix Quick Start bot https://www.youtube.com/watch?v=Hy4cswZ_Iqk Some of the other videos may help out your new team members as well. Hope it helps. |
#23
