Go to Post :D NASCAR is way harder than we thought. - SL8 [more]
Unread 12-05-2014, 01:06
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: Nvdia and FIRST?
Originally Posted by yash101 View Post
That's a gaming card. It's not meant to paint excessive resolution images to the screeen. Those chips are meant to paint regular HD images to the screen really quickly.
The performance shouldn't be horrible, though. You probably have an i5 or an i7 (or maybe an AMD alternative)! The integrated graphics should be capable of running the program pretty well!
I'm not talking about rendering performance, I'm talking about performance while actually working in the application. It's slow and unwieldy at all times, and has always been this way on every machine I've ever run it on.
"The breakfast of champions!"
Unread 12-05-2014, 07:30
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Originally Posted by Oblarg View Post
If only I had a free solidworks license...
Apply under the FIRST section on the SolidWorks site. This is how we get our free licenses every season.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 12-05-2014, 11:26
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
The GPU chips are actually the same in many cases and based on the same architecture, just optimized for different tasks. What makes workstation cards (Quadros) and gaming cards (GeForce) different is the drivers, build quality, and validation. The drivers of gaming cards are optimized for maximum frames per second (FPS), while workstation cards are optimized for image quality. Workstation cards also follow the reference design from the GPU manufacturer, ie. every card is the same. Workstation cards also undergo validation for hundreds of professional applications, which is why they cost more. The first 3.5 minutes of this video explains the difference well.
But you can still run Inventor on a gaming card. I run Inventor on my laptop which has a GeForce GTX 650m, a Core i7 @ 2.3GHz - 3.2GHz (Turbo), and 16GB of RAM. Inventor runs perfectly fine.
The main factor in in-application performance is going to be the CPU clock speed. Autodesk recommends at least 3.0GHz. The RAM amount will affect the size and amount of parts that can be open and worked on at a time. The hard drive speed will affect how fast parts load and save. GPU and CPU cores will affect rendering times.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 12-05-2014, 13:08
AKA: Eli Barnett
I have a haswell i5 @3.4ghz, 16 gigs of ram, and a SSD. The hardware is not the limiting factor here.
The software simply is, as far as I can tell, poorly-optimized and clunky
Unread 12-05-2014, 14:02
Chris_Ely's Avatar
AKA: luckof13
Interesting, I haven't found that to be the case. On most machines that I have used, Inventor runs just as well as every other program.
Unread 14-05-2014, 09:23
yash101 yash101 is offline
AKA: null
Haha. I run on my netbook kith a 1.4GHz i3. It runs well enough for me to make decent CAD models, consisting of easily 100 parts!
Unread 14-05-2014, 15:58
StillDefective's Avatar
StillDefective StillDefective is offline
In the shop, got my stock, CNC on.
AKA: Paul Johnson
FRC #1094 (Channel Cats)
StillDefective has a spectacular aura aboutStillDefective has a spectacular aura about
I run it on my little i3 @ 2.53ghz laptop with no dedicated graphics and 4gb of ram. It isn't perfect, and if I work for a long time it eats up ALL of the ram and I have to restart, but hey, it works. Kinda
Unread 14-05-2014, 18:09
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Not sure how much help this'll be if teams are running autodesk inventor - I've got a GTX 780 and it still runs like crap
You can get as many free Solidworks license seats as you have registered members on your team...just ask:
www.solidworks.com/FIRST
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 28-05-2014, 15:59
AndreaV AndreaV is offline
FRC #1360
AndreaV has a spectacular aura aboutAndreaV has a spectacular aura about
It looks like this thread turned into a "gpu's, cpu's, and cad" discussion. If you look at the video posted, it actually mentions the Jetson tk1, a dev kit aimed at vision processing and robotics.
http://www.techradar.com/news/comput...ev-kit-1249739
At $200 it's first legal. I can see this being included in the kit or available through first choice.
"Now powering the next era of robotics"
2005-2006,2011 FRC 865 Warp7 Student, Mechanical team
2013 FRC 1310 RUNNYMEDE ROBOTICS Mentor, CAD and Manufacturing
2014-2015 FRC 5031 Downsview Robotics Mentor, Design and Manufacturing
2016-Present FRC 1360 Orbit Community Robotics Mentor, Design and Manufacturing
Unread 29-05-2014, 21:24
Uniwersel Uniwersel is offline
FRC #1828 (BoxerBots)
Uniwersel is an unknown quantity at this point
Nvidia even mentioned FRC in one of their overviews with Newegg: http://youtu.be/XmnM7ikhY1s
It would be super cool to see something like this in the KOP.
