Go to Post The big lesson we learned ... our past does not limit our future, that superior attitude will beat out big budgets. - [more]
Unread 29-05-2014, 18:10
magnets's Avatar
magnets magnets is offline
Turning down the OD of a gear
I'm designing a gearbox that would work really nicely if a gear with an OD of 1.700 had an OD that was .020 less. How bad would it be to to turn down the OD of the gear .020? Also, does anybody know exactly the OD of a CIM motor? The website claims 2.54 max, but do they come in under this?
Unread 29-05-2014, 18:45
audietron's Avatar
audietron audietron is offline
Red for mediocre performance
AKA: Grayson Burgess
FRC #0965 (X3 Robotics)
audietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to behold
Re: Turning down the OD of a gear
I am not sure about turning down a gear. The CIM motors are 2.52 max, they vary depending on manufacturing within a couple hundredths.
2015: Galileo Semifinalists
2015: North Star Regional Finalists (Thanks to 5576 and 2531)
2014: North Star Semifinalist (Thanks to 2175 & 4607)...again
2014: Central illinois Semifinalist (Thanks to 1756 & 1288)
2013: North Star regional Winner (Thanks to 2175 & 4607)
2013: Curie Semifinalist (Thanks to 2056 & 3990)
2013: IRI Semifinalist (Thanks to 359, 1477, & 148)
Unread 29-05-2014, 20:03
If you turn down a gear .020"...
... Your chance of the gear slipping will go up, albeit slightly.
... Your chance of messing up the tooth profile will go up--you really don't want to mess that up, so make sure you clean up carefully after whatever machining op you do.
... If the gear is heat treated, you're probably going to change the heat treating. This will probably lead to unintended consequences, good and bad (but most likely mostly bad).
But, you should be able to get away with it. For a little while, at any rate.
Now, I have to wonder... Why not just move the gear .020" farther away from the other gear, in some direction? And, what's with asking if the CIM comes in under its stated diameter? If you're building a really tight gearbox, I suggest that you also CAD in the assembly tools for that gearbox, just to make sure they will actually work...
Unread 29-05-2014, 20:17
magnets's Avatar
The idea was to have three CIMs drive a large center gear, then have a smaller gear located underneath the CIMs, driven by this center shaft.
Unread 29-05-2014, 20:20
Ah, I see. Maybe move each CIM .010" out from the center, and move the other smaller gear .010" down? Or is there some other space constraint that would prevent that?
Unread 29-05-2014, 20:25
Rauhul Varma Rauhul Varma is offline
Drivetrain and Design Lead
FRC #0192 (GRT)
Rauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud of
You can expect the Cims to be 2.536" OD. I think turning down the teeth of the gear could work, but you would be shortening the involute profile of the gear which could lead to problems depending on the power moving through the gear.
That would mess up the center to center distances.
Unread 29-05-2014, 20:38
That is true. On the other hand, part of design is designing for what is available. If the only available gear is .020 larger than needed, then that needs to be considered. Center-to-center shouldn't affect it--matter of fact, I'm specifically suggesting changing the center-to-center BECAUSE the center-to-center is too small for that gear, and the only thing a center-to-center will affect is where on the gear contact is made (though, that little detail can introduce some backlash, among other things). That can also be mitigated by playing with a few other things--for example, if your center-center is exact distance, most FRC folks will add 2-3 thou to that to account for manufacturing tolerances; if you make it 10 thou instead, you've really only added 7-8 to what is normally done.
Personally, I wouldn't attempt turning down a gear once it was cut, for the reasons listed above--there's too many things that could go wrong, minor enough it would seem, but just too many items to tempt Murphy and his gremlins. That goes for both a mill and a lathe, BTW. If someone really knew what they were doing, then that could work, but in FRC, those types of folks are rarer then we'd like to think, unfortunately.
Unread 29-05-2014, 20:53
FRC #0192 (GRT)
If your center-center is exact distance, most FRC folks will add 2-3 thou to that to account for manufacturing tolerances; if you make it 10 thou instead, you've really only added 7-8 to what is normally done.
Is it really that common in FRC to add 2-3 thou? (I honestly don't know) For every gearbox I've designed I've only added half a thou and haven't had any problems with wear.
I do see the problems with the actually trimming the OD, depending on the team's machining expertise and capabilities it could be quite difficult to do. correctly
Unread 29-05-2014, 21:13
It's been pretty common in the past. Part of the wear thing is that our gears are only running for about an hour per event, give or take a bit (some teams will put more on practicing), which is only about 300,000 cycles for anything going at about CIM free speed, and most gears will be going slower than that. That's not a lot for a typical gear. Even factoring in sudden reverses and the fact that not all gears will be going all the time, it's not a lot of cycles. Once you start getting through a district schedule plus a full round of post-seasons plus demos plus driver practice... Then you might start seeing more wear.
Also, it's a lot easier to add 2-3 thou than 0.5 thou, something about the latter being much harder to do reliably, and needing better measuring tools. (Back in my day, a lot fewer teams had CNC capability. Then again, there were a lot fewer teams.) I'd go into a discussion of tolerancing and its effects, but that would be pretty far off topic, so if you're interested drop me a PM. Short version, X.000 vs X.0005 is probably going to be more expensive and time-consuming one way than the other. Take a wild guess which way is higher cost.
Unread 29-05-2014, 21:16
T^2 T^2 is offline
FRC #5499
I think this practice is also becoming slightly less common because of the prevalence of VEXPro gears. Their hex is oversize, while the shafts are undersize; this leads to slop. Adding .003 to c-c can lead to very noticeable backlash.
Unread 29-05-2014, 21:36
Chris is me's Avatar
AKA: Pinecone
Adding three thou is a psuedo-standard in FRC. It's a good rule of thumb for custom gearboxes. It's also one way to artificially shift your tolerance band.
Yeah... We had a 6(!) stage arm transmission this year and we had over seven degrees of slop in our original arm. We added the three thou but all of the loose hexes added way up. All of the shock loading of the arm flopping around in the straight up position led to multiple gear failures.
So yeah, I think we're going to .001 next year. I've heard people run zero backlash with Vex gears with no problems, but I'd like a little bit more space for grease in there, and this avoids having to break in gearboxes for any extended period of time. (The kids made me promise I wouldn't push for a geared arm again too)
Unread 29-05-2014, 22:20
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
My experience is similar to Eric's: the addition of up to 0.003 in was necessitated by gearboxes being produced by hand by inexperienced machinists on milling machines of uncertain provenance. If you're CNCing the gearbox plates, you can in all likelihood get away with less. But remember that the added centre distance isn't just for position of the holes, it's also for runout of the gear and perpendicularity of the axle. (For example, in 2006, 188 had a bad EDM job that screwed up some expensive hardened gears, and necessitated a lot of rubbing compound to "solve" the runout.)
I would be interested in hearing from some of the VexPro people about the design and tolerances of their gears. How far from standard tooth profiles can they be expected to deviate at perfect form (e.g. due to profile shifting, radiusing, etc.), and how much variance is introduced in manufacturing?
Unread 29-05-2014, 22:24
By the way, what are the dimensions and diametral pitch of this gear? It's kind of important to know how much of the tooth is being lost. But maybe that's part of the solution: you could go with the largest teeth that will work. In most cases, the limit will be set by the undercut of teeth on the pinion as you go down to small diameters. (To improve that, prefer a higher pressure angle given gears of a certain diameter and the same pitch.)
Unread 29-05-2014, 22:42
FRC #0192 (GRT)
We did notice that too, but since we machine our own hex, we make it oversize to mate their bores nicely and haven't had those issues.
Unread 29-05-2014, 22:53
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Can you really hit a half thou accuracy? Even running finish and float passes and really getting to know the machine, program, and material, I can usually only hit around 1-2 thou accuracy on our CNC for stuff like hole to hole distances.
Yeah, 3 thou is the standard number. I've heard that it mostly came into being in a time when FRC gears were pretty low quality, VP gears nowadays are high enough quality that you don't really need the adder. Another reason for the adder is that if you have a bit of runout on your shafts, or poor quality gear teeth, and you put the gears at the nominal pitch diameter, there'll be places in the rotation where the gears get sort of jammed together, and you lose efficiency. Adding a few thou helps make sure that the gears aren't getting jammed into each other in case of tolerance issues somewhere else.
-Plutarch
