Go to Post and don't overestimate the ability of an unskilled fool with exotic tools! - MissInformation [more]
Unread 29-05-2014, 22:59
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
Re: Turning down the OD of a gear
Quick question to the OP:
Why does this matter so much? If it's for clearance to spacers, just move the spacers. And if it's for ground clearance, forget it. You will need more ground clearance than 0.02" due to the tread wear, compression, and random stuff on the ground.
CIMs are always 2.536" outer diameter unfortunately. You could look into RS-775, but if this is for drive CIMs would work better.
Unread 29-05-2014, 23:02
chadr03's Avatar
chadr03 chadr03 is offline
FRC #2582 (PantherBots)
chadr03 has a spectacular aura aboutchadr03 has a spectacular aura aboutchadr03 has a spectacular aura about
Turning the OD of a gear can have some negative issues as people have stated you are removing 10% of the active tooth depth. Depending on the tooth counts used this can have a much more dramatic effect than a 10% reduction in torque capacity. One of the factors that drive the rating of a spur gear is known as the contact ratio. It is essentially a measure of what percentage of time one tooth is in contact verses two teeth in contact. When you truncate the OD of one gear you shift that contact ratio closer towards one tooth in contact more often than two teeth. You could imagine when the load is shared between multiple teeth more more load can be transmitted.
Additionally many times gears have what is known as tip relief. Where the involute is modified slightly on the tips of gears to allow them to enter and exit mesh more smoothly especially when a load is applied. I do not know if FRC gears have tip relief machined in, but if they do you will remove it and possibly cause the gears wear more quickly and be noisy.
How many teeth are on the CIM pinion? Would it be possible to use a larger pinion? If you are trying to keep a specific ratio vexpro might make just what you need. They appear to have some CIM pinions with modified addendums or shifted centers. (The modified addendums will allow you to add .025" of center distance without the increase in backlash or shaving the OD of your gears basically lets you set the center distance up as if the gear arrangement had an extra tooth).
See page 9.
http://content.vexrobotics.com/vexpr...ence_Guide.pdf
Unread 30-05-2014, 09:24
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
This is very case-dependent. Just remember that the teeth are designed to be in contact at the pitch-circle diameter, not at the outside diameter. So cutting the outside will have no effect on many systems.
So as long as you have 'regular' gears, not some kind of ten-tooth pinion or something, the outside two percent of the tooth should never be needed as the next tooth is engaged long before it disengages.
Also, technically, involute teeth aren't sliding, they're 100% rolling contact, but if you change the center-to-center distance, even by adding a measley 3 thousandths, you'll have some sliding contact and less gear efficiency, more wear.
But as someone above mentioned, what is the gear pitch?--if the teeth are very small, 0.020 could be alot. if they're big teeth, 0.020 is less concern.
Unread 31-05-2014, 12:27
DonRotolo's Avatar
Back to humble
FRC #0832
Quoted for truth: It may not be obvious unless you have studied gears, but the teeth if an involute gear don't just push on each other, they actually ROLL across each other. The sliding action (which leads to wear and wants a lubricant) is almost zero. That's one of the reasons center-to-center distances are so very important for gearboxes.
Unread 31-05-2014, 12:55
dtengineering's Avatar
AKA: Jason Brett
And if anyone reading this thread hasn't had a chance to study a little bit about how gears work... take a look. We generally tend to look at gears and say, "Oh, it's just a gear." and take them for granted, but the math and science that goes into gear design is truly fascinating. The modern gear is the product of centuries of engineering evolution.
I know I've still got a lot to learn about how gears work, wear and are manufactured.
Jason
Unread 31-05-2014, 15:46
Rauhul Varma Rauhul Varma is offline
Drivetrain and Design Lead
FRC #0192 (GRT)
Rauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud of
Isn't that a simplification of what the contact actually looks like. Gears contact along the line of action, which is some angle (the pressure angle) off the line tangent to both pitch diameters.
So as long as you have 'regular' gears, the outside two percent of the tooth should never be needed as the next tooth is engaged long before it disengages.
Wont removing that outside bit increase the stress per tooth?
Unread 01-06-2014, 17:48
chadr03's Avatar
Absolutely.
Involute gears do not simply contact at the pitch diameter the contact moves from the tip to the root along the line of action as can be seen on the previous graphic. Gears all have sliding contact and most have at least one place on the line of action that has pure rolling contact. A gear mesh has three distinct actions during mesh. When a tooth begins in contact it is called the approach action there is a combination of sliding an rolling on the mating surfaces. When the contact along the line of action passes through the pitch diameter there is an instant of pure rolling. Then the contact goes into recess action where there is a combination of sliding and rolling once again. A shift in center distance will not change the fact that the contact will move from the tip to the root along the line of action it will simply make the line of action shorter and change the amount of backlash.
Unread 02-06-2014, 18:22
hrench's Avatar
AKA: Bob Hrenchir
Originally Posted by chadr03 View Post
Absolutely.
Involute gears do not simply contact at the pitch diameter the contact moves from the tip to the root along the line of action as can be seen on the previous graphic. Gears all have sliding contact and most have at least one place on the line of action that has pure rolling contact. A gear mesh has three distinct actions during mesh. ...
...A shift in center distance will not change the fact that the contact will move from the tip to the root along the line of action it will simply make the line of action shorter and change the amount of backlash.
Some really great discussion here and the graphic is amazing.
I think I'll add that chadr03 pointing out that the backlash will increase with added center-to-center spacing is correct because the teeth are no longer engaging along the theoretical pitch circle (or near it as the graphic shows) but instead, further out on the tooth--where the two teeth don't fit as well together. Also note, the teeth are narrower out there, hence weaker.
Gears are built with a bit of undercut already to take up a tolerance if the centers are too close. I'm still not an advocate of moving the center distance apart.
