Go to Post The more you cling to the misfortunes that have already befallen you, the less you'll be able move forward from here. - Kevin Sevcik [more]
Unread 29-05-2014, 23:08
Professional Stat Padder
Re: Weight Saving Techniques
A lot of people on this thread have mentioned using thin-walled aluminum as a great weight savings technique.
A lot of people on this thread have not competed at a New England event.
Some of 20's success over the years hasn't been about having the best robot at an event- but by having a robot that survives throughout the event.
Thin-walled aluminum can be weight savings, and it is true that geometry>thicker walls when it comes to making parts stronger.
But some things absolutely deserve thicker tubing and stronger materials- and when you neglect that, you sometimes pay the price when it matters most.
I put together a presentation for my team last year on how to build robots for reliability.
I won't go into it extensively, but my essential point was there are two components to reliability on a robot- durability and maintainability.
The robot needs to be durable enough to survive matches, and mechanisms need to be able to be replaced or maintained in order to keep the robot in peak condition.
Things like the frame of the robot aren't replaceable- and thus mostly not maintainable, so they need to be extra durable.
I'm not saying not to use thin-walled aluminum, because that would be ridiculous. But remember the trade-offs you make when you make parts out of certain materials. Do the math, then add a little safety factor. You might thank yourself later.
(2015-Present)
Unread 30-05-2014, 07:52
Gdeaver Gdeaver is offline
FRC #1640
Fiberglass pultrusions can both save weight and increase durability. Composites in general can save weight. Composites require different construction techniques than metal. There is plenty of good info out on the web on composites for teams to research. This year our ball intake was made out of 1" pultrusion and survived massive hits.
Unread 30-05-2014, 11:10
Gweiss96's Avatar
Gweiss96 Gweiss96 is offline
AKA: Garrett Weiss
FRC #3309 (Friarbots)
Team Role: Operator
Gweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to behold
Holes save weight. Lots of holes.
Unread 30-05-2014, 12:12
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
To lose weight you just have to diet... GET IT!?!?
I apologize in advance.
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
Unread 30-05-2014, 12:32
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
This was one of our worst years for battling weight but really every year we have had a weight problem.
2011 we were rookies so that doesn't count but we grossly overbuilt a multi level superstructure all out of 1/8in box tubing. Like Chris said, this is where most teams waste weight because they make them too complex or they avoid combining elements together to eliminate parts.
2012 we were 130lbs after our scrimmage event. To get under we removed the covers on the AM supershifters and replaced them with aluminum standoffs and 1/32in lexan. We moved to an off-board compressor and put some holes in our wooden shooter sides which got us down. We remained at 120 and I wish we had used more 1/16in tubing in our frame so we could have added a stinger. We passed inspection by cutting off a small zip tie to get stop the scale from twitching between 120lbs. and 120.1lbs.
2013 our first robot was about 2lbs over. After our redesign we were about 106lbs.
2014 we had a completely designed robot in CAD that said we would be 30lbs under without wiring and lexan shields but wound up being about 7lbs over. As it turns out several of the steel components like a few axles and the spring had no weights entered nor did most of the electronics and smaller gearboxes. We cheese holed our intakes and several other parts and removed nearly a pound of useless PVC spacers on our intakes. We also used thinner lexan for all paneling which helped a lot. Never using 1/8in lexan for covers unless we have a lot of weight to spare because you can't get thin lexan smoked. We also swapped some of the 1/8in cross beams for 1/16in tubing.
In the future we will look into using more thinner box tubing elements in our design. Like Kevin said, playing in New England is very brutal but you look at teams like 118, 971, 233, 254, etc who put so many mechanisms and parts on their robot and are either underweight or just at it. Definitely hoping to find that balance.
Something else is to lighten parts as you go. Its easier to throw a few holes in a part you are making before you assemble the robot and find out hours before bagging you need to shave down. Obviously not all parts should be lighted for the heck of it, but there were several parts on our robots over the years that didn't need the thickness/surface area from the beginning.
Properly planning for electronics and wiring is crucial. Many teams pull the "throw everything on the scale" but fail to remember all the wiring/pnuematics they aren't taking into account. Having a 5lb-10lb buffer is good to design around. It gives you some wiggle room to iterate throughout the season like adding a blocker, stinger, minibot ramp, 20in extension (2013 FCS), etc.
1058 PVC Pirates 2016 - xxxx
Unread 30-05-2014, 13:29
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
I'd be really interested in seeing a white paper on this document-- often I see teams with few engineeringg mentors/less experience with major reliability problems that probably could have been avoided.
Back to the topic, planning in your lightening is definitely the way to go-- if you can lighten a part without sacrificing functionality (ie in a chassis- 1/8" box tube is totally overbuilding and can in almost all cases be lightened), plan it in and drill your lightening holes before assembly. Just transfering to doing this saved my team from almost all our previous weight problems for the past few years.
Outside of that, using fasteners intelligently (as previously mentioned) is also huge. You DO NOT need screws and nuts in a lot of the cases I see them-- properly sized rivets, welding, or even using washers can save you a ton of pain, both in weight and maintenance.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 30-05-2014, 15:32
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Another technique we used this year was designing with weight reduction ideas in mind. An example was the chain on our drive system. We spaced the wheel centers so that 35 and 25 chain would both span the distance and built with the 35 chain. We ended up not using it this year, but it could have potentially saved us about 1.2 lbs. As others have stated, there is a trade off with weight and durability.
Our frame is welded aluminum rectangular tubing with 1/16 wall. This is great for weight (our frame weighed a little over 5 lbs), but it does come with its own challenges. The closed cross section actually provides a lot of strength for the material, but it's not invicible. After a particularly hard head on crash at Chesapeake this year, the middle section of the frame is dented in behind the bumper. Using screws to attach other components to the frame very easily leads to "dimpling" in the areas of the screws as students are not careful about stopping when the load gets tight enough.
We have an anodization sponsor to color the robot, which actually is a weight savings over using powder coat. Aluminum gears are almost a standard of our DTs. We save ~2 lbs just by swapping from steel. Several years ago, we made a switch from using 1/4-20 bolts to using 10-24 screws. Rivets are used where it makes sense.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 02-06-2014, 08:16
MichelB's Avatar
MichelB MichelB is offline
Jack Of All Trades
FRC #3941 (Absolute Zero Electricity)
Team Role: Electrical
MichelB is an unknown quantity at this point
(I didn't have time to read the entire thread so I apologize in advance if this has been said before but...) SWISS CHEESE!!! While my team always tries to estimate weight and remain under the limit we always seem to go over, that's when we break out the hole saws and cut as much extra material as possible away without compromising the structural integrity of the part. Since most of the force is taken on the edges of the piece, cutting holes in its center won't affect it too much.
Unread 02-06-2014, 08:31
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Here's a little quip that has kept 95 underweight since I started as a coach in 2010: worry about the ounces, the pounds will take care of themselves.
Edit: *zips up flame suit* I don't like 'swiss cheesing' at all. It has some sort of appeal in FRC that I don't quite understand. It's not very strength-efficient and it takes a ton of extra labor to execute. When I see swiss-cheesing all I can hear in my head is: 'my designer didn't understand my strength requirements or my weight budget and decided to make me weaker by drilling holes in me than by simply remaking me out of thinner or less dense material.' I do not intend this in a condescending way, I used to swiss-cheese parts too, until that little voice popped into my head.
Edit pt2: here is a quick FEA I did of a swiss-cheeses 1x1x1/8 6061T6 tube (on the left) of nearly the same linear density as 1x1x1/16 6061T6 tube (on the right). The middle is fixed, and both tubes' upper surface as 100lbf applied to it. The Mises stress distribution clearly indicates that the 1x1x1/6 tube is experiencing about 1/3 the stress as the swiss-chessed tube. The thinner 1x1x1/16 tube is around 3x stronger than the swiss-cheesed 1x1x1/8 tube for the same weight. Keep that in mind the next time the 'thinner wall vs swiss-cheesing later' thought comes to mind, or when you think that cutting holes in the center won't affect it too much (looking at you MichelB)!
Unread 02-06-2014, 12:49
FRC #1640
Thank You for the picture. It's hard to get this across some times and a stress picture is worth a thousand rants.
Unread 30-06-2014, 17:02
abhem abhem is offline
FRC #0599
abhem is an unknown quantity at this point
Im sure the obvious technique is to always use aluminum as opposed to steel whenever possible. Swiss cheesing is also a great choice. To save on weight, our team uses gusset plates to secure vertical and horizontal posts rather than using crossbars. Although crossbars are very handy to secure posts, gussets work equally well, if not better when made correctly. They also save a ton of weight and lots of physical space on the robot.
Using gussets to secure "swiss-cheesed" bars/c-channel/etc. is a powerful combo to save weight
Unread 01-07-2014, 07:16
RKazmer RKazmer is offline
FIRST Volunteer
AKA: Richard Kazmer
FRC #2363
RKazmer is on a distinguished road
Originally Posted by AluminumNarwhal View Post
Try to use as few wires as possible when doing your electronics. Make the wires just the right length, instead of just using zip ties or something to control the excess wire. It may seem obvious, but my team didn't do this the first few years. When we cleaned up a particularly wasteful wiring set-up, not only did the robot look better, we lost 7 pounds!
This is actually really important in a design. Wire might not seem heavy at first, but add up all the wires you need in a robot and it will weigh quite a lot. Also, it is always better to wire short as not to complicate the wiring and the power drop is also a factor when wiring power to the drive motors or the main power switch.
Unread 01-07-2014, 08:18
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
See post above about the effectiveness of swiss-cheesing.
Do you have any evidence to support the assertion that 'gussets are better than cross-bars'? It seems like you'd be putting bars into bending instead of building a proper truss structure to keep each member in tension or compression. This is not a good plan for structural efficiency.
Unread 01-07-2014, 21:47
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
You must spread some Reputation around before giving it to JamesCH95 again.
I am also not a fan of swiss-cheesing...
The East Coast Armor philosophy was more necessary in the pre-bumper days.
Unread 02-07-2014, 16:59
Joining the 900 Meme Team
FRC #0079
No... it's still required. Playing out here is rough. (This is partially joking, it's a lot rougher than I remember MI being though)
