| Thread Tools |
Rating:
Display Modes |
#16
Re: Questions about building a West Coast Drive with VersaChassis
![]() The blue part is just a bent aluminum sheet metal bracket (1/8 in thick). It bolts to the TB mini through the top two holes that secure the mounting plate to the plastic housing. Then it is secured to the top of the robot frame via four 10-32 screws and rivet nuts (McMaster 93483A661). The green cylindrical parts are just some stand-offs we made from half inch round stock that we drilled through with a .196" clearance hole. We secure the gearbox to the side of the frame by just running a long 10-32 screw through the TB, the standoffs, and the frame. Refer to drawings 4293_2014-005 and 4293-2014-018 for the standoff and the bracket. Edit: Also, we cut the bottom off of the TB mounting plate for ground clearance. You can just trace the profile of the housing on the plate and then use a band saw to cut it down. Drawing 4293_2014-019 shows all the mods we made to the mounting plate. ![]() Last edited by Joel Glidden : 25-05-2014 at 22:26. Reason: Mounting plate mod |
#17
Thanks for all the replies everyone, the project is really coming along. A couple new questions that I came up with:
#18
#19
Ha, duh. Fixed, should be open to everyone now.
#20
Seems like chain and sprocket would be cheaper than belts and pulleys. Also, I'm not sure why you need the WCP side bearing blocks. Do you have CAD you can share?
#21
Chain and sprockets may be a good idea as our team has no experience with them. I would have to factor in the costs of chain accessories like a breaker and holder(?), though, as I never want to do chains by hand/pliers again like my old team used to.
If I go with the round shaft I should be able to save ~$20 by switching to sprocket/chain, but the cost of accessories would mitigate that. Still though, trying something new has its benefits. As for the side bearing block, I was going to use it to hold the bearings for the gearbox shaft. I was kind of assuming that you had something similar in your model as you aren't using the VersaBlock at the gearbox. As for CAD, unfortunately no. I started learning CAD recently but don't actually have a spare computer to put it on. We are trying to find mentors to teach CAD, but as of now I am the only one learning it. Last edited by Monochron : 30-05-2014 at 10:43. |
#22
If you use #25 chain, get Dark Soul Chain tool, which costs about $40 with shipping. It eliminates the connecting links (weak links).
Chain for one WCD costs $10 vs ~$50 for four belts, so it pays for itself. With the sale on the AndyMark pulleys, the cost isn't much different either way, so I would focus more on whether you'd rather end up with belts or chains. I think it would be cool to run belts, but I also like having a bunch of sprockets and chain around so we can make up a manipulator chain connection pretty easily without ordering a specific belt or stocking a dozen different belt sizes. Chain is annoying in some ways, though. |
#23
I do really like the idea of training the students with chains but adding in the cost of accessories pushes this up around $60 more than with belts. It's a tough choice. |
#24
Yeah that's a possibility. Any suggestions for other #35 chain breakers? most of what I have found so far has been for chain sizes in the hundreds.
#26
http://www.amazon.com/Koch-7725010-R.../dp/B004HKIU4C |
#27
If you're going to do the same thing with round shaft, make sure you spin the output shaft by hand or wrench once you have the gearbox mounted to the chassis. If the torque required to spin the wheel is inconsistent or excessive, the bearings are probably over-constraining the shaft. This will kill your efficiency and lead to fatigue problems later if left uncorrected. |
#28
http://www.ombwarehouse.com/-35-Chain-Breaker.html BTW, for #25 I recommend: http://www.davesmotors.com/s.nl/it.A/id.2258/.f If you notice, they are both similar in design and operation. I highly recommend both of them. |
#30
