Go to Post Use sensors to collect data about the surrounding environment, then discard it and drive into walls. - Jared Russell [more]
Unread 31-05-2014, 15:46
Rauhul Varma Rauhul Varma is offline
Drivetrain and Design Lead
FRC #0192 (GRT)
Rauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud of
Re: Turning down the OD of a gear
Originally Posted by hrench View Post
Just remember that the teeth are designed to be in contact at the pitch-circle diameter, not at the outside diameter.
Isn't that a simplification of what the contact actually looks like. Gears contact along the line of action, which is some angle (the pressure angle) off the line tangent to both pitch diameters.
So as long as you have 'regular' gears, the outside two percent of the tooth should never be needed as the next tooth is engaged long before it disengages.
Wont removing that outside bit increase the stress per tooth?
