Go to Post I think it's important to keep FIRST's most important award as the top point getter [in Fantasy FIRST]. It's help reinforce that the Chairman's award, Engineering Inspiration and Woodie Flowers award are actually important and FIRST is about more than just the robots. - Koko Ed [more]
  #31   Spotlight this post!
Unread 01-06-2014, 13:41
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
Re: Questions about building a West Coast Drive with VersaChassis
We have never used a chain holder. The chain breaker has teeth and a lock pin that holds the chain in place. It correctly aligns the links so you can just push the pin in. It's just like the DS one it that respect. If you have to stretch the chain to put the pin back in, it's too short and will likely fail from being over stressed. (Yes, I know chain stretches some).
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
  #32   Spotlight this post!
Unread 01-06-2014, 14:08
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
We have built west coast drives for the last several years using either a toughbox or supershifter with the long hex aluminum output shafts. the wheel is held on by the screw in the end of the shaft, the sprockets to drive front and back are between the inside of the frame and the transmission. the transmission is then mounted to frame crossmembers.
  #33   Spotlight this post!
Unread 01-06-2014, 19:48
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Oh nice I see that now. The DS only has one pin to align one side of the chain (as far as I could tell) so having pins on both sides really makes a difference for that one.
Yeah I knew the output shaft was tapped at one end but I didn't know what to do about all the other shafts for the front and back wheels. I am thinking now that we will just tap each shaft manually and use bolts/washers just like the output shaft.
