Go to Post ...okay, maybe I have a xkcd addiction - plnyyanks [more]
Unread 29-05-2014, 11:51
AustinH's Avatar
AustinH AustinH is offline
FRC #4918 (The Roboctopi)
AustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to behold
Maximizing the in-line CoF of Omni-wheels
Has anyone ever tried adding custom tread patterns to omniwheels in order to maximize front-to-back CoF while retaining free lateral motion? Could you theoretically use custom rubber treaded rollers? I would love to hear of and see examples of people trying this, if it's been attempted at all.
3826: 2013 Seattle Regional Industrial Design Award & Semi-Finalists
4918: 2014 PNW Glacier Peak District Event Rookie Inspiration Award & Quarter-Finalists, 2014 PNW Mount Vernon District Event Highest Rookie Seed Award, Rookie All Star & Semi-Finalists, 2015 PNW West Valley District Event Engineering Excellence Award & Semi-Finalists, 2015 PNW Mount Vernon District Event Semi-Finalists
Visit us on the web at www.team4918.org
Unread 03-06-2014, 17:35
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Maximizing the in-line CoF of Omni-wheels
I was thinking about using rubber rollers with plastic hubs on the omnis, but you would have to make them yourself.
Following.
Unread 03-06-2014, 19:57
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
I've never heard of this done, but building the rollers wouldn't be to hard, Polyurathane would work in that application (same type of material as colson wheels). However, I'm not sure it would be worth your time to develop this type of Omni-wheel unless it had significant benefits (which I don't see).
(2015-?): 973
(2012-2015): 955
Unread 03-06-2014, 20:20
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
Why wouldn't this be beneficial? It could give you significantly better traction with almost no additional weight.
Unread 03-06-2014, 20:37
Nate Laverdure's Avatar
FRC #2363
Significantly better than what? AndyMark lists a forward COF of 1.0 for their 6" dualie omni wheel.
Unread 03-06-2014, 21:15
FF TSL: Frog Farce
Significantly better than omnis with standard rollers. Even if you could only get the COF to 1.1 or 1.2, that would be 10 or 20%. Looking at the difference of the two different vex versawheels (http://www.vexrobotics.com/vexpro/wh...sawheels.html), the W tread adds an additional 20% compared to the DT tread. You could probably get a similar increase by adding a pattern to the omni rollers.
Unread 03-06-2014, 21:26
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
I might be concerned about the depth of the cuts. If they were too deep, you definitely could run the risk of chunking out the rollers.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 03-06-2014, 21:30
FF TSL: Frog Farce
-Nick
Yeah, I think that I would get bigger rollers (anyone know how?) and trim them down with the cuts.
Unread 03-06-2014, 22:56
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Most omnis have rollers with rounded edges, that is, they try to follow the arc of the outside of the wheel to minimize bouncing as the robot drives. If they were kept square, it's possible that they could dig into the carpet at the edges, and still drive relatively well (because the carpet would compress to compensate).
-Plutarch
Unread 04-06-2014, 00:35
Pumped
AKA: Ryan
All things equal, it would, but given how Omni's behave in a pushing match against another robot that isn't dead center. It would likely negate much of the gain that would be seen. (i.e. they break loose/slide in a direction away from the pusher, effectively rendering the friction gain useless)
Given the amount of time that would be put into building these (taking apart the wheels, rollers, testing,ect.), I think a team interested in Omni's could easily design something else that fits the bill better (Such as Butterfly) and be much happier with the results.
(2015-?): 973
(2012-2015): 955
Unread 04-06-2014, 01:01
EricH EricH is online now
Back when mecanum wheels were still new to FRC, at least one team tried getting better grip with patterned rollers/rubber coatings on plastic rollers. As I recall, it wasn't fully tested, but there was an improvement. (Though as I recall, the biggest improvement came from adding the rubber, so that's out with AM wheels.)
Unread 04-06-2014, 10:39
Joining the 900 Meme Team
FRC #0079
3D print a master, make a silicone mold, poured urethane rollers.
Screw trimming, just model it in there initially.
Unread 04-06-2014, 15:26
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
I think with the right wheel configuration there's a way to solve some of the pushing problems. I need to think on this one a bit.
The benefits of this is that it would be a direct swap out for a normal omni drive, so you would only need basic testing in the offseason. With butterfly and similar drives, there is a LOT more weight involved and it has to be custom built for each robot. Plus, you don't get a lot of push power in mecanum mode. So IF (big if) a modded omni could be omproved it could offer an advantage over butterfly drives.
Unread 04-06-2014, 20:57
Pumped
AKA: Ryan
Butterfly is Omni, Octo-canum is with Mechanum.
I see the gains to be made here, I just don't think post-manufacturing modification is a very efficient route to go in this application. I'm also not convinced it would be very helpful just because of how the Omni's react to lateral loads.
(2015-?): 973
(2012-2015): 955
Unread 06-06-2014, 01:41
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
You're assuming that you are configuring the omnis in a traditional manner. I think ther emight be a way to get them all nice and on the ground (maybe with thingy-which-name-escapes-me with springs)
Post-manufacture, I agree, is somewhat dead because the rollers can only be modified so much. Swapping out the rollers with polyethurane with a delrin hub might work if you were to modify an existing wheel.
I've never assembled an omni before; is it possible to take the rollers off?
