Go to Post I also predict that most predictions will be wrong. - Joe Ross [more]
Unread 04-06-2014, 01:07
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
CNC punch usage
Hi CD,
I am not sure if I am using the right technical words so please forgive me for the first time.
My team has a sponsor that make part for us in a CNC punch machine.
To this day we gave to the machine operator pdf drawings of the parts we needed. It was not efficient at all because the operator had to copy the drawings into the machine. We assume we could save about a week in the build season by exporting the 3D models of the parts into a format which the machine knows. I know the machine is old but the operator told us it can read dxf files. We tried to do it without success. Probably we did not do that right, so I am looking for detailed instructions how it should be done.
I am also checking an option of programming the CNC by ourselves, It seems unnecessary because we don't really know how to do it.
We are using NX Unigraphics 6, I know many of the FIRSTers don't use it but I assume the instructions should be the same.
Thanks,
Yarden
2016 - Curie Sub-division Winners, Regional Winners
2015 - Carson Sub-division Winners, Regional Winners
2012 - 3339 Captain and Dean's List Finalist
Unread 04-06-2014, 01:11
Re: CNC punch usage
Most CAD programs have an "Export" command, usually under the "File" menu.
So: File->Export, and make sure to select the .dxf file type.
For programming the CNC, you'd need some form of G-code generator, unless you really wanted to program it command by command.
Unread 04-06-2014, 01:16
yarden.saa's Avatar
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
Re: CNC punch usage
We tried it. I will try it again with a test part. Can you explain me what is the dxf file? 3d model/2d model? as I mentioned the machine is old (very old), I don't really know but it can be the problem maybe?
Unread 04-06-2014, 02:48
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: CNC punch usage
DXFs are a 2d file that includes dimensional data. They're used to transfer 2-d CAD data (usually to CAM/manufacturers). DXFs have been around for a while, but I guess whether or not they can read it does depend on the age of the machine (a machine from 1965 will not be able to read DXFs). In any case, they likely take the DXFs into a CAM (Computer Aided Machining) program instead of directly inputting it into the machine. The CAM program would take the DXF and (with the help of a user) turn it into G-Code, the actual instructions that run the machine. Basically all CAM programs should be able to open DXFs.
-Plutarch
Unread 04-06-2014, 07:16
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
Re: CNC punch usage
How does your sponsor create their CAM files? Do they produce .dxf files from a specific type of modeling package? See what they do and perhaps be able to copy their process?
Also, when you say that you tried giving the operator a .dxf files without success, can the machine not read the files, is the scaling on the parts off, or something else?
FRC78: 2010-Present
FRC121: 2002-2009
Unread 04-06-2014, 07:39
yarden.saa's Avatar
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
Re: CNC punch usage
The machine could not read the file.
I searched some more info and found that there are several ways to make dxf files in NX, I don't know what the difference is.
I think I will go with the computer to the sponsor's machine shop and try again.
Unread 04-06-2014, 08:00
AKA: Tom Dolan
Re: CNC punch usage
Working with the sponsor with your computer setup will definitely help...they should be able to spot the problem. Good luck!
FRC78: 2010-Present
FRC121: 2002-2009
Unread 04-06-2014, 08:02
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Re: CNC punch usage
Yarden,
I am not terribly familiar with NX in regards to exporting DXF files, but found this video tutorial. As Eric mentioned, it is an export operation; but you have some control over what you export. DXF files can be more than 2D. It is important to only export to a 2D (flat) version of the face/surface you want to manufacture.
Much like any other CAD system, DXF has different file versions (e.g. NX 6 vs NX 5, or SolidWorks 2014 vs SolidWorks 2013). Attached is a screen capture of what I am talking about. Where I work, we have an old machine that is used on rare occasions, but requires us to save the DXF as an older version (AutoCAD 2000/LT2000 DXF) in order for it to read the file properly.
It does not look like this option is built into NX, although I could be wrong, so you may have to download AutoCAD or similar to convert the DXF version. Creo (Pro/E) has the option for us to do this as part of the export operation - we can select 2010, 2007, 2004, 2000, 14, 13, or 12.
Name:	DXF options.png
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 04-06-2014, 08:11
yarden.saa's Avatar
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
Re: CNC punch usage
Originally Posted by tim-tim View Post
Yarden,
I watched the same video, and learned that there are several dxf formats. NX has all the formats.
Thanks
Unread 04-06-2014, 09:29
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: CNC punch usage
I've found AutoCAD R12 DXFs to be the most universal for importing into other software packages. Try that type.
Unread 04-06-2014, 15:06
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Re: CNC punch usage
Another thing to be careful of is if you plan to form the sheet after putting it through the punch you need to either figure out the k-factors/bend deductions your shop uses and apply them appropriately when going from 3D to flat pattern or ask your sponsor to help you make the flat. Really it's whatever will work the best for your sponsor - we just send ours the 3D part and they figure out what the flat pattern should look like based on their machines. If you're only doing flat parts though, you'll be fine
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Unread 07-06-2014, 16:53
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Re: CNC punch usage
How did you even get your hands on NX?
Unread 13-06-2014, 13:50
yarden.saa's Avatar
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
Re: CNC punch usage
university...
