Go to Post We need to all remember we are no better than our fellow man, no matter what job we all hold, what socio-economic status that's involved, or anything. Plain and simple, we're all fellow travelers on this pale blue dot called Earth. - trobots.com [more]
Unread 03-06-2014, 22:48
audietron's Avatar
audietron audietron is offline
Red for mediocre performance
AKA: Grayson Burgess
FRC #0965 (X3 Robotics)
audietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to behold
unknown electrical issue
We are having an issue with our robot working great for about a minute before the battery starts to drain rapidly. It continues to drop to about 11 volts at around 3 minutes of hard defense before it starts to jitter like seen in this video.
http://youtu.be/_hXEWTRuxOU
Also shown in the video is that nothing else is able to be controlled while it is happening. The motor controllers run green yellow red rapidly when this is occurring. We have changed out the breakers and checked all the wiring connections and are still not able to figure it out.
Any help would be appreciated.
2015: Galileo Semifinalists
2015: North Star Regional Finalists (Thanks to 5576 and 2531)
2014: North Star Semifinalist (Thanks to 2175 & 4607)...again
2014: Central illinois Semifinalist (Thanks to 1756 & 1288)
2013: North Star regional Winner (Thanks to 2175 & 4607)
2013: Curie Semifinalist (Thanks to 2056 & 3990)
2013: IRI Semifinalist (Thanks to 359, 1477, & 148)
Unread 03-06-2014, 23:45
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: unknown electrical issue
You are drawing enough current when you are trying to turn that you are dropping the battery voltage to the point where you are browning out. 3 minutes of hard defense might very well do it, especially if you scrub when you turn your drive train and spend a time pushing without spinning your wheels (stalled).
Make sure you don't have any mechanical binding in your drivetrain, make sure your gears are greased, sprockets / belts aligned and tensioned, and all your bearings are good. Double check you've got drive from each one of your motors individually (just pull breakers one at a time to make sure all your drivetrain cims are working). One way or another, if you're starting with a fully charged battery you're draining it quickly.
We found with the Andy-Mark kitbot wheels the center wheel wore fast enough that by the end of a competition all 6 wheels were rubbing the carpet at once causing a lot of scrub when we turned.
Unread 03-06-2014, 23:51
Aaron.Graeve Aaron.Graeve is offline
FRC #1477 (Texas Torque)
Aaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to all
Would you mind posting the Driver Station Log from the video (or any instance of this happening)? The logged battery voltage is something I would like to take a look at.
My first instinct is to check the battery and how many Amp-hours it will still hold since it has been used. A brand new battery is generally at 17 Amp-hours. The lower the A-Hr, the faster the voltage on a battery will drop. A full battery dropping to 11V after 3 minutes is not unheard of, but not common either.
Does anyone see the RSL (Robot Signal Light) flash in the video? I am not seeing it flashing or are momentarily blind (or both). The jitter could be a low battery undervolting the sidecar, but without the Log file, it is just speculation.
Any FTA's, FTAA's, CSA's, or anyone else are more than welcome to throw out other ideas.
Alamo, Bayou, and Lone Star Regional FTAA
2015:
Dallas, Alamo, Bayou, and Lone Star Regional FTAA
2014:
Alamo, Dallas, and Lone Star Regional FTAA
Alamo Regional Robot Inspector
2013:
Einstein Champion and 2013 World Champion (Thanks 1241 & 610), Galileo Division Champion, Razorback Regional Winner, Alamo Regional Semifinalist, Bayou Regional Semifinalist, Lone Star Regional Quarterfinialist
2012:
Curie Division Semifinalist, Lone Star Regional Finalist, Bayou Regional Winner, Alamo Regional Winner
Unread 04-06-2014, 00:11
audietron's Avatar
My first instinct is to check the battery and how many Amp-hours it will still hold since it has been used. A full battery dropping to 11V after 3 minutes is not unheard of, but not common either.
I can try and get the logs on thursday when I get to the robot again and try and upload them. The rsl is not blinking because of a broken connector which is on the list of things to fix. I do know that when it does jitter the voltage goes down to around 4.5, which I could see messing with the sidecar. I will check to make sure all the cims are working properly as well.
Unread 04-06-2014, 00:29
Good to hear you still have the logs. If the battery voltage is dropping down to ~4.5V during the jitter, I am quite confident that that is most of the problem. If the voltage to the sidecar drops below a certain point (I think 5V), the sidecar will not be able to generate the PWM signals correctly.
2015:
2014:
2013:
2012:
Unread 04-06-2014, 06:58
I agree with what others have said. I suspect that the log file will show frequent drop and recover of the battery voltage. The drop is due to large draw by the motors at stall. The recovery is because the cRIO FPGA cuts the outputs in order to avoid reboots by critical systems such as the radio and cRIO.
Verify that the battery is good, verify it is fully charged, and see what the voltage drop is when you initiate a turn. If it isn't hard, swap the wheels or place new ones on the center. I can't see much on the robot, but I assume it has dropped center wheels.
Greg McKaskle
Unread 04-06-2014, 10:23
G_rupp's Avatar
G_rupp G_rupp is offline
FRC #1108
G_rupp is an unknown quantity at this point
You should also check all of the battery power connections. Check the lugs on the power distribution board and each of the batteries. You could have loose connections that causes heat. How warm are the battery cables after you turn off the robot?
Unread 04-06-2014, 10:38
Tungrus Tungrus is offline
Tungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the rough
If the battery voltage drops to 8 or below you will run into other issues. We were told by a FTA that cRIO will crash which may not be recoverable. Check for pinched PWM wires, if moving parts pinch and short for short duration, the circuit breaker may not get activated, but battery drains out.
Unread 04-06-2014, 11:13
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Related to the above, can you check the drive motor circuit breakers to see if they are tripping? You should hear an audible clicking. Also, the PDB has a red LED which should light up when this occurs.
Unread 04-06-2014, 11:18
Audie,
This is not a classic demonstration of battery voltage brownout but it may be complicated by a frame short somewhere. When you are listing your battery voltage are you telling us the dashboard reading or are you measuring the battery directly? I would check all wiring first, starting with the power to the DSC and the multi-conductor between DSC and cRio. The rapid on/off that appears in the video is likely caused by a circuit breaker rapidly resetting. That is usually caused by a short or a partial or intermittent short. Coupled with a rapid battery discharge, a pinched cable (power to the DSC) is the likely culprit. If you have any servos, check for a pinch in those PWM cables since they are fed from the DSC. If it is a short, then something is getting warm. Carefully feel around all wiring for some thing is hotter than the others.
Unread 04-06-2014, 11:22
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Is this the first time the robot has done this?
What is your wheel setup? I would expect this issue with 4 high traction wheels in that configuration. If you have omni's on front or back, I would not expect this behavior due to the drivetrain configuration.
Edited for clarity:
**If you do not have omni's on one set of wheels, you will stall your drivetrain motors, likely pulling too much current and tripping the breakers.
Don't discount a mechanical issue as a result of an electrical symptom.
If this occurs after three minutes of heavy drive motor usage, you could likely have a dead battery. If you have a Battery Beak, check the condition of the battery when it exhibits these symptoms. Hopefully, it will point you in the right direction.
Unread 04-06-2014, 17:24
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
This is very strange, and I don't know the cause other than low battery, but something I know is that we would have the same problem from time to time, and I'm pretty sure the robot is enabling and disabling at the same time while this happens, as whenever this would occur in a match, our pneumatics would retract and extend with the twitches, if they were extended beforehand. Also, our LEDs would flicker greatly, which were directly wired to the PD board at 20 amps. I don't know if this would help, but just contributing if possible.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 04-06-2014, 22:01
BriteBacon's Avatar
BriteBacon BriteBacon is offline
Happy birthday to me!
AKA: Brian Jung
FRC #0074 (Team C.H.A.O.S.)
BriteBacon is on a distinguished road
The same thing happened to us at Gull Lake in semi's, the only way we figured out to fix it and prevent it from happening is by restarting the driver station after each match.
2014 FRC World Champions- 254, 469, 2848, and 74
2014 Michigan State Finalists- 1718, 67, and 74
Unread 05-06-2014, 06:55
A cRIO crash due to low voltage or otherwise should not brick the cRIO. Every time you open the Anderson switch to "turn off" the robot, you are removing power from the cRIO. It isn't aware you were going to do that, and it runs out of juice and has an abnormal shutdown -- a crash.
When voltage drops below a threshold, the cRIO disables outputs. In its status packet back to the DS, it explains that it cannot run outputs because it is disabled. This is similar to what happens with a watchdog timer. The DS it telling the robot it can be enabled. The robot is saying it chose not to be. I don't believe rebooting the DS has any effect on this. I don't believe it hurts anything, but I don't believe that it fixes issues with a low voltage battery in anyway.
Please post the logs and that will give some data to confirm our speculations. Or it will hopefully point in another direction.
Greg McKaskle
Unread 05-06-2014, 13:51
audietron's Avatar
I will post logs ether tonight or tomorrow morning due to the fact i don't have the robot or driver's station at the moment. I am mostly thinking it is a short like many people have said. I will check to see what gets really warm when we run it today and see if it is in fact the power cables for the DSC.
The battery leads do get somewhat warm as well as all 4 Drive cims, The main breaker does not get hot as well, this is why i am pretty confident is just a short somewhere.
Thanks for all the help.
