Thread Tools |
Rating:
Display Modes |
My favorite part is doing bounce shots off the side rails into the high goal, (not sure if it is a feature or not, but still pretty cool).
Re: Team 2067 Swerve Drive Game
I updated the game with controller support, timed matches, and an AI defensive bot that gets in your way. The robot interactions are rather buggy (weird things might happen if you get pinned), so there's a link to a version without enemies if you don't like it.
Clear the cache if you've played before. Html5 with enemies: http://applepi.tk/swerve Html5 without enemies: http://applepi.tk/swerve_noenemy Desktop with enemies and controllers: http://applepi.tk/swerve.jar Controllers don't work in html, I haven't figured that out, so use the desktop version if you want to use a controller. Tested on a Logitech Gamepad F310. Left stick for translation, right stick for rotation, LT and LB for harvester, RT for shoot, A for field centric, B for robot centric, D-pad for move rotation point, back for reset rotation point. And it wont let me update the first post to add the links... There's no edit button Last edited by cjl2625 : 06-06-2014 at 22:08. |
You should github the source code. That way, more people can work on it and perhaps make it better!
You can shoot over the truss as well !
Sweeeeeet. Would be nice if there were 2 blockers though.
Next step: 3D! lol |
#7
Yeah, I can do that. I'll add a settings menu
#8
Cory, great work on this it is a really neat simulation!
One slight recommendation would be to have the score and timer in constant view and a little larger. And 2067's swerve was pretty neat this year too! ![]() |
#9
so, what are your high scores?
#10
#11
Protip, don't refresh..
#12
The ball bug, yeah, I'm aware of that. In general, things tend to get weird when you go against the wall ![]() I'll probably add something to prevent you from mystically warping through the ball like that. Quote:
If I turn down the acceleration, the robot drifts to the side when you move forward while rotating. As it is, this happens a little bit, but not that much. I'll play with it, though. Yup... that's the free hosting service I'm using. Dunno why that shows up. |
#13
170 points, with enemy.
http://imgur.com/eWwXp3f |
#15
I keep getting webpage is not available errors on chrome
Does it not work well on chrome? |
