Go to Post And that's why we all need to consider reserving a "No! Bad robot!" button for the robocoach. :yikes: - vhcook [more]
Unread 08-06-2014, 01:40
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
The in-wheel swerve shifter!
So I made an autoshifter in CAD using a weird custom dog, parts from the GEM gearbox (ring gear is a measely $10 vs. $100 for other internal gears) modified for this purpose, and a custom wheel made to fit the ring gear.
The way this works:
0. There is a primary reduction from CIM to wheel shaft.
1. The shaft is spinning in one direction, say, clockwise. The dog is keyed to the drive shaft and spins with the shaft. It also engages with the hub of the wheel, to direct drive the wheel from the shaft. The dog is "locked" to the wheel due to the acute angle of the teeth. The wheel spins clockwise with the shaft.
2. There is a collision with another robot and the robot gets into a pushing match. The driver flips and switch, and the CIM then reverses direction- now the wheel shaft spins counterclockwise.
3. The dog spins with the shaft. However, now the dog is no longer "locked" in place due to the shape of the teeth. Now, the obtuse-sloped side of the tooth contact the like side of the wheel hub and pushed the dog into engagement with the sun gear of the planetary gearset.
4. The dog "locks" into place with the sun gear due to the acute angle of the teeth. The sun gear spins the planet gears which transfer power to the ring gear. Due to the nature of planetary gearsets, a counterclockwise rotation of the sun gear with the planet carrier locked produces clockwise rotation of the ring gear. This means that the ring gear, which is locked to the wheel, now spins clockwise. Thus, the wheel still spins clockwise after the shift.
Essentially, all you need to do in order to shift is the reverse the direction the CIM is spinning in.
Obviously, this poses the problem: how do you go backwards if you reverse the CIM to shift and the wheel only goes forward?
The answer: you can't. This is only suitable for swerve drives for this very reason. You have to turn the wheel to go backwards. RS-775 18v are suggested for turning motors.
In order to manufacture the parts in the CAD, you would absolutely need at least a 4-axis CNC due to the weird dog and mating gear/ hub. Not to mention the wheel itself. Because my team lacks the resources to do this, I decided it would be fine to release my CAD of this.
There's probably a ton of errors in the CAD right now (I've only cadded a few of these, and this is the first actual possible swerve module with it) but I wanted to see what the CD community thought of this idea quickly. The CAD is missing bearings, circlips/ eclips (I use the latter), and a miter gear on the primary shaft. Reduction is accomplished with the sprocket for an adjusted 20.0fps high gear and 7.5fps low gear. This is can go down to something like 18fps high gear pretty easily just by increasing the size of the versasprocket. I only had a 34t versasprocket on hand in CAD, but 38t would be preferred.
I use SolidWorks, so if anybody would like the native SW files I have those on hand for the weird dog geometry.
Files in STEP format for download here in a zip folder: https://drive.google.com/folderview?...&usp=sha ring
EDIT: Forgot to say, feel free to slam this however you feel. Anything at all. I have designed a ton of swerve modules (upwards of 15) but none of them have been built. So any input at all will help with the next ones.
ID:	17093  Click image for larger version
Name:	WST-101 wheel guts.JPG
ID:	17094  Click image for larger version
Name:	WST-101 shifting shaft.JPG
Unread 08-06-2014, 02:05
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
Re: The in-wheel swerve shifter!
Its a really cool idea. I would be really scared of the gears teeth shearing off that close to the final reduction of the drive train.
This may also cause major latency in the drive train something that i don't even know if the shifting could compensate for. Also you could not do on the fly shifting and the complexity of the system is high little lone putting it in the already complex swerve drive. I love the idea tho and think that it may have uses in non drive applications.
Also a RS-540 would work well too, 775's are over kill in my opinion.
Unread 08-06-2014, 02:19
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Thanks for the input!
The gears are from a GEM planetary and are all 4140 steel IIRC, so I'm not too worried about the stripping.
Due to the wheels not reversing direction every time you shift, the only thing that the CIM has to fight against to accelerate is the inertia of the shafts and gears, not the inertia full robot like in a normal reverse. I did a small test with an unloaded cim and it would reverse instantly, but definitely something to look into. I think/hope the lack of inertia would reduce latency to almost nothing.
Unless you're talking about the sheer number of gears, which I have nothing to compensate for.
The reason I said RS-775 is so that you can turn very very quickly to compensate for not being able to reverse the cims to go backwards. Plus, anywhere you can use a 775 power-wise you can use a CIM (you would have 2 left with this drivetrain), except on a versaplanetary (preferred turning gearbox) which requires modifications.
You can't really do not-on-the-fly shifting technically, because the cim's turning is what keeps it engaged. But in reality you could probably not shift on the fly and be okay.
Unread 08-06-2014, 02:31
Tyler2517's Avatar
ShortOnes
AKA: Tyler Gibb
For latency i meant the time it would take to turn the wheel.
Unread 08-06-2014, 02:33
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Yeah, that's something I can't really address. This uses the minimum number of intermediate gears that is possible with this size wheel.
1717 doesn't seem to have problems with their gears, but it's true that the GEM gears have a TON of slop in them. I still can't figure out addendum mods for planetary gearsets, so for now I'll stick with this. Definitely something to work on in the future though.
Unread 08-06-2014, 10:51
Chris is me's Avatar
AKA: Pinecone
I'm not sure if this would work, but it's an interesting idea. Is there any reason you have only one planet gear? Are the planets going to be carried by anything or are they just floating? Is the planet arm fixed, free spinning?
If you need an initial reduction from the drive motor, why not just shift there?
Unread 08-06-2014, 11:48
Greg Woelki's Avatar
Greg Woelki Greg Woelki is offline
FRC Alumnus
FRC #1768
Greg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of light
I like the idea. My first thought was that this could be better suited to lifts (think 2013 climb) where there has little load when traveling one direction and much more in the other.
Unread 08-06-2014, 12:42
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Wow, that's a really cool idea!
I'll agree with others that it may not be practical for a drivetrain (not being able to shift on the fly, and having to turn the wheels around to go backwards), but I can see this kind of mechanism making it's way into other parts of a robot!
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 08-06-2014, 13:34
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
There are actually 5 planet gears. The way I CAD stuff, I want to put in all the shafts and e-clips before patterning the planet gears 5 times.
So the reduction comes from the sprockets on the wheel and shaft above the wheel. The cim can go directly above the module right in the center of rotation, to remove the need for gears outside the swerve module.
Why can this not be shifted on the fly? Am I missing something here? Keep in mind that this can ony go forward. There is no reverse because I'm driving sun-ring, not sun-carrier in the planetary gearset. This means that the reverse of direction by the cim will only work against the inertia of the drive shaft, not the whole robot.
Here is a good link to learning about planetary gearset ratios: http://science.howstuffworks.com/tra...ment/gear7.htm
As you can see, the ratio between sun and carrier, which is normally used in planetary gearboxes, is (ring/sun + 1):1. However, this uses a sun and ring mate, for which the ratio is -(ring/sun):1. So when the shaft reverses direction, the wheel continues spinning the same direction that it was before.
Unread 08-06-2014, 13:57
AdamHeard's Avatar
Lead Mentor
If you're willing to give up direction changes (as this drive does), there is a simpler way to get the same affect.
Run two parallel stages of reduction from the motor to module input with different ratios. Put all of the involved pulleys/gears on one way bearings.
When you drive on direction, power will be transmitted through set A while B free spins and vice versa.
Something I thought of that Aren Hill and I have been debating about for a while.
Unread 08-06-2014, 14:15
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Interesting, and clever! That would be a good way to do it outside of a swerve or wheel, for something like a PTO. However, this way is a lot more compact if you are using it inside a wheel. Outside a wheel though, one-way bearings would do really well.
I always wondered, how do you get the one-way bearings to spin with the shaft though? Wouldn't the shaft just slip? Or do you add screw locker or something?
Unread 08-06-2014, 14:22
FRC Alumnus
FRC #1768
Slip inside the bearing you mean? My team used a one way bearing on our winch this year. We press fit it into a bearing block and press fit a coupler into it. The friction was strong enough to hold everything from moving even with 500 in*lbs of torque on the coupler acting against the bearing.
Unread 08-06-2014, 15:00
Madison's Avatar
Madison Madison is online now
Dancing through life...
FRC #0488 (Xbot)
Would you happen to know of a source for one-way bearings that fit in typical FRC drives and are rated for the loads we see?
--Madison--
...down at the Ozdust!
Unread 08-06-2014, 15:04
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
McMaster has some. You would need to do some load tests though; they're rated pretty low. For that reason they would probably be on the CIM shaft (they come with 8mm bore)
Wow, that's pretty buff!
Unread 08-06-2014, 15:16
AdamHeard's Avatar
Lead Mentor
I would run 2489K23 on the CIM and 2489K5 on the module input.
Both have quite comfortable FOS as a CIM stalls at ~ 1.7 ft-lbs.
