Re: Custom West-Coast Design Feedback
Anyway, buying the stock and cutting it yourself is different from just using versachassis, because you actually have to design in different chassis elements such as slots and mounting holes. This is good practice. The more custom work you can do in the offseason, the better for when COTS parts are not available or don't exist. Anything new has to be done in the offseason or it has a much higher chance of not working/ failing. Anybody can take the versachassis and use it during the season, but the offseason should be used for custom parts and designs. There's little reason to just build a versachassis instead of actually inputting custom work somewhere into the equation; that can be accomplished during build. Yes, it is less effort and more effective to use a versachassis, but doing a custom build makes good use of the time available. |
IMHO steel is a acceptable material for making a robot drive train. I like it because it will keep the weight down low to improve your COG. Steel is appx 3 times heavier than alum but designed correctly can be much stronger/ less costly in the same size package.
Steel is much cheaper in terms of cost/lbs vs alum. CRS and stainless sheet is readily available from material suppliers. Steel can be easily spotwelded and mig welded. Welding steel is much easier than welding alum. Laser cutting light guage steel is significantly faster than cutting the same thickness aluminum. Here's some stats you can use for you analysis Cost/lbs of Cold roll sheet sheet is appx. .55/lbs Cost of Alum 5052 is appx 2.00/lbs density of steel is .29 lbs/sqft alum .098 for alum. Take a look at using .036 or .048 CRS for your sheet stock and using .065" thin wall 2x1 , 1x1 tube. Here's a website of a company that can laser cut tubes. Think of designing tab and notches to click together your frame and use the sheet metal as gussets and brackets http://www.tubeservice.com/index.html |
This is main reason I wanted to go with steel in the first place; we don't have a massive budget and I wanted to incorporate some welding into the project. Thanks, daliberator |
My above post explains my reasoning, and the same logic holds true for offseasons. Teams might get much more out of dedicating their resources to arms, elevators, etc. than drives. It's certainly true that for some teams the reverse exists (or they have plenty of resources) and they can go custom and not negatively impact overall learning. Each team has a unique circumstance, and it's unfair to imply that teams are doing things right or wrong in this capacity. |
#7
I'm not saying anybody is doing things right or wrong, I'm sorry if I came off that way. My apologies, I wasn't considering making things other than drivetrains (I'm a drivetrain freak) so totally, arms and elevators are cool too. Especially given that we've had so many ball games, having a usable elevator design would be nice to have. I'm not sure how resources factor into this specific instance; I am assuming the OP has resources to build a WCD? |
#8
Something I've learned over the past 4 years: Never assume anything that the OP didn't tell you. One small piece of new information can change all possible applicable advice.
#9
Good point. I just thought that the OP's cad was an example of their machining resources.
#10
Another downside of relying on COTS as we saw this past year is when the supplier has issues delivering or keeping up with demand. Obviously some of what happened was out of VexPro's control but its a risk teams face. If a team wants to devote more of their time to machining over buying similar parts more power to them. Some of us might not agree if its the most time efficient manner to build a robot but that is their choice as a team since we all accomplish the game differently and seek to gain different lessons from participating in the program. If the OP and team want to make a fully custom WCD in the off-season to try new design and build techniques go for it if that's how they feel they want to spend their off-season. I happen to remember your team did something similar last year Andrew. |
#12
Perhaps this is pedantic but I would also say you are not "designing" a drivetrain when you take COTS parts, decide how long four pieces of tubing should be, and then put them together in a preconfigured pattern. It's like saying building a Lego model from the instruction book is design. About the only design work being done is the choice of gearbox, wheels, and gear ratio. That's not to say COTS is bad or whatever, but using the VersaChassis isn't exactly the same as designing a custom drive at all. -- What is right for your team depends on your resources. Basically, do you have more money or more design resources? Most teams have not enough of either, but money is way easier to get more of than design and build resources. I agree with others who say that focusing design effort on the manipulator and sticking to COTS drives is a general good idea. However, it depends on the team. In the off season, you have a lot more freedom to experiment with new ideas (and usually, less money to spend), so working on custom drives is a very good idea, even if you stay COTS for another build season or two. There's no universal right answer, there is no single optimal solution. Nothing one size fits all. Asserting facts as such is probably a bad idea. |
#13
As I posted before a fair amount of good design in industry is actually configuration. It's a valuable skill to have, few industries fabricate everything. We certainly can all agree that each team is unique, and there is no universal correct answer here. |
#14
The parts that I would refer to as the system design (excluding the choice to use VersaChassis itself) would be the choice in gear ratio, gearboxes, and motors (perhaps power transmission as well). Certainly few real world situations involve engineers doing detailed design of every component - lots of off the shelf parts or reused designs are implemented in lieu of all this extra work. My point is essentially that it's the off season, and the OP is building an off-season drive. The constraints likely are in favor of more time and less money rather than the other way around. This I don't think the notion of doing something custom should be inherently knocked in favor of a COTS chassis. They could just buy and build it in the build season if it makes sense to run then. |
#15
