Go to Post To go a step further, to be "steam punk", electrics would need to be powered from a steam turbine operated dynamo but electric wiring would still be required to follow all rules as they would apply. - Al Skierkiewicz [more]
Unread 11-06-2014, 02:17
AdamHeard's Avatar
Lead Mentor
Re: Custom West-Coast Design Feedback
Originally Posted by asid61 View Post
Oh, ok. I wasn't quite sure what you meant.
Anyway,
buying the stock and cutting it yourself is different from just using versachassis, because you actually have to design in different chassis elements such as slots and mounting holes. This is good practice. The more custom work you can do in the offseason, the better for when COTS parts are not available or don't exist. Anything new has to be done in the offseason or it has a much higher chance of not working/ failing.
Anybody can take the versachassis and use it during the season, but the offseason should be used for custom parts and designs. There's little reason to just build a versachassis instead of actually inputting custom work somewhere into the equation; that can be accomplished during build.
Yes, it is less effort and more effective to use a versachassis, but doing a custom build makes good use of the time available.
This is entirely your opinion, and not fact.
My above post explains my reasoning, and the same logic holds true for offseasons. Teams might get much more out of dedicating their resources to arms, elevators, etc. than drives.
It's certainly true that for some teams the reverse exists (or they have plenty of resources) and they can go custom and not negatively impact overall learning.
Each team has a unique circumstance, and it's unfair to imply that teams are doing things right or wrong in this capacity.
Unread 11-06-2014, 02:23
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
In all fairness, many things said here are opinions. Very little that I say myself is "fact" and I (try) not assert myself that way. I should probably hack that into my signature so I remember.
I'm not saying anybody is doing things right or wrong, I'm sorry if I came off that way.
My apologies, I wasn't considering making things other than drivetrains (I'm a drivetrain freak) so totally, arms and elevators are cool too. Especially given that we've had so many ball games, having a usable elevator design would be nice to have.
I'm not sure how resources factor into this specific instance; I am assuming the OP has resources to build a WCD?
Unread 11-06-2014, 02:25
Andrew Lawrence
Posts: n/a
I'm not sure how resources factor into this specific instance; I am assuming the OP has resources to build a WCD.
Something I've learned over the past 4 years: Never assume anything that the OP didn't tell you. One small piece of new information can change all possible applicable advice.
Unread 11-06-2014, 02:33
asid61's Avatar
AKA: Anand Rajamani
FRC #1072 (MVRT)
Good point. I just thought that the OP's cad was an example of their machining resources.
Unread 11-06-2014, 02:38
Andrew Lawrence
Posts: n/a
Okay, I agree 100% with you. My own experience with bad CAD and apathy on my team has made me a stickler for CAD and custom parts. It just really annoys me when team members try to make things by hand that should really be machined. I feel like if my own team tried this, we would end up doing a lot by hand that should really be sent to a professional. Thus, I say 2x1 because versachassis looks "finished" and could end up badly if people start messing with it with hand drills.
Not sure if I'm getting my mindset across here.
I totally get what you mean. I make sure that whenever we use COTS parts, everything is put in CAD and treated as if it were a custom part that we designed, sketched, extruded, mated, and assembled ourselves. The only difference between the CAD and the real part is that we buy the real part, we don't make all of it (though like in the case with the versatubing, we do machine parts of it ourselves, but all machining is already included in the CAD model). This method allows our students to learn as much as possible as if we designed the part ourselves, but still have the ease of use, reliability, and time saving advantages that a COTS component normally has, like Adam previously mentioned.
Unread 11-06-2014, 09:33
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
COTS parts can be very expensive for teams to just dish out the money on off the shelf solutions. I know many teams who operate under having unlimited access to aluminum stock (tubing, sheets, blocks, etc) or other materials and limited budgets that push them to instead focus on making their custom parts and save the money on the upper assemblies.
Another downside of relying on COTS as we saw this past year is when the supplier has issues delivering or keeping up with demand. Obviously some of what happened was out of VexPro's control but its a risk teams face.
If a team wants to devote more of their time to machining over buying similar parts more power to them. Some of us might not agree if its the most time efficient manner to build a robot but that is their choice as a team since we all accomplish the game differently and seek to gain different lessons from participating in the program.
If the OP and team want to make a fully custom WCD in the off-season to try new design and build techniques go for it if that's how they feel they want to spend their off-season. I happen to remember your team did something similar last year Andrew.
1058 PVC Pirates 2016 - xxxx
Unread 11-06-2014, 09:44
AKA: Brendan Browne
Originally Posted by daliberator View Post
Hey CD!
This year in the off-season, my team is going to work on a custom drivetrain. It looks like it's gonna be a west-coast, so I threw the attached design together.
Its main structural element is 16th inch steel sheet. For main supports, it has 16th inch steel tubing of varying heights, as well as a 8th inch steel chain-guard (For lack of a better word). The bearing blocks are 8th inch steel and the are at an interference fit with their respective bearings. I didn't know exactly how much to drop the center bearings, so I just guessed at 3/16ths of an inch.
This is the first drivetrain I have attempted, so any and all feedback is welcome.
Thanks,
daliberator
I apologize for the double post.
That's a very unique design you have their but unique designs are good! Exploring something new is a fun experience.
Before you settle on one style of drivebase, would you care to explain how your team decided that building a WCD style base was the right ones for you? What type of advantages do you see in building one? What are your design criteria(s) such as lightest, simplest, ease to build, ease to swap out parts, space efficient, etc.
Our team listed out what we wanted to see in a drivebase separate from a certain type of base and in the end we came up with a very decent solution that was extremely easy for us to build based on our immediate resources, was highly reliable considering it hasn't broken since we assembled it and put it through 6 competitions, and highly competitive as it gave is a good high speed our driver could control coupled with nice traction wheels and low gear for pushing through defenders.
Unread 11-06-2014, 12:03
daliberator's Avatar
daliberator daliberator is offline
Ace Machinist
AKA: Henry O'Callaghan
FRC #4536 (MinuteBots)
daliberator will become famous soon enoughdaliberator will become famous soon enough
Thanks for the reply!
We're not quite done deciding, but we really liked how the west coast robots performed at the events we were at. We have fairly good machining resources, so it seemed like a logical step up from our KoP drive this year.
As for my design, after what I have seen in this thread, I have gone supports crazy. I grossly overestimated the amount of structural elements I need, as well as the fact that steel may be way overboard. I'm working on a new design that will feature aluminum. Are there any other changes you could reccomend?
Thanks,
daliberator
Unread 11-06-2014, 13:06
AKA: Brendan Browne
Thanks,
daliberator
Yes, WCD style bases many times lend to perform better but this is typically from the components they are using such as wheels, motors, no. of motors, gearboxes, wheel type/tread, wheel layout 6wd vs. 8wd, driver skill, etc among many other little details. WCD does give you some advantages in how you package these items to be lighter, take up less space, and provide a more efficient setup.
I personally have never built a WCD base only designed a few in Inventor. Some of the reasons teams jump to do a WCD is because its easy to change out a wheel and if you use bearings blocks you have integrated chain spacing which were two features that stuck out to our team a lot after last year. In the end we opted over building a WCD to try new products/techniques while improving performance. For instance we used solid rubber Colson wheels for our drive wheels and found a C-C chain spacing calculator from team 1640 to calculate the space between each wheel to eliminate chain tensioners (we used #35 chain). These two decisions allowed us to never touch the base and accomplished our two main reasons for looking at a WCD which is why we haven't made one. Our base was really easy to make and it built off of what we were comfortable with.
Its just always good to discuss why you intend to build something compared to doing something that a majority of high performing teams do just because they do it. Yes their WCDs are very, very good drivebases but their drivers are what really make them shine and that goes for every team. WCDs aren't very popular up here in New England but we do have our share of extremely good base drivers that can compete with the best. Most notably, team 195 the Cyberknights driver destroys the playing field to be honest. He is very in tune with the match play and more importantly how his robot best moves on the field. He does all this with just a modified kitbot. They swapped the front wheels for omnis and upgraded the gearboxes to 3 CIM single speeds and he uses them to the full potential which is something a lot of teams overlook. I use 195 as one of the many examples we have up here but a little goes a long way.
If its performance you are looking for make some small mechanical tweaks but really give your driver that time to practice especially in the offseason. That is what makes good drivebases.
Unread 11-06-2014, 13:29
Chris is me's Avatar
AKA: Pinecone
There's a world of difference between designing a part and drawing it in CAD and putting it in an assembly. You're just making models, not designing a part.
Perhaps this is pedantic but I would also say you are not "designing" a drivetrain when you take COTS parts, decide how long four pieces of tubing should be, and then put them together in a preconfigured pattern. It's like saying building a Lego model from the instruction book is design. About the only design work being done is the choice of gearbox, wheels, and gear ratio. That's not to say COTS is bad or whatever, but using the VersaChassis isn't exactly the same as designing a custom drive at all.
What is right for your team depends on your resources. Basically, do you have more money or more design resources? Most teams have not enough of either, but money is way easier to get more of than design and build resources. I agree with others who say that focusing design effort on the manipulator and sticking to COTS drives is a general good idea. However, it depends on the team. In the off season, you have a lot more freedom to experiment with new ideas (and usually, less money to spend), so working on custom drives is a very good idea, even if you stay COTS for another build season or two.
There's no universal right answer, there is no single optimal solution. Nothing one size fits all. Asserting facts as such is probably a bad idea.
Unread 11-06-2014, 14:20
AdamHeard's Avatar
Lead Mentor
There are distinctions between component design and system design. It certainly still is system design.
As I posted before a fair amount of good design in industry is actually configuration.
It's a valuable skill to have, few industries fabricate everything.
We certainly can all agree that each team is unique, and there is no universal correct answer here.
Unread 11-06-2014, 15:01
AKA: Pinecone
I'm definitely getting to the point where I'm just splitting hairs here, but I interpreted Andrew's post as "buying a COTS part is the exact same amount of design as making your own", which it isn't since one stops doing component design. That's not to say component design is better or necessary, it's just not the same set of skills being used and practiced.
The parts that I would refer to as the system design (excluding the choice to use VersaChassis itself) would be the choice in gear ratio, gearboxes, and motors (perhaps power transmission as well). Certainly few real world situations involve engineers doing detailed design of every component - lots of off the shelf parts or reused designs are implemented in lieu of all this extra work.
My point is essentially that it's the off season, and the OP is building an off-season drive. The constraints likely are in favor of more time and less money rather than the other way around. This I don't think the notion of doing something custom should be inherently knocked in favor of a COTS chassis. They could just buy and build it in the build season if it makes sense to run then.
Unread 11-06-2014, 15:04
highlander's Avatar
highlander highlander is offline
Registered Boss
Team Role: Student
highlander has a spectacular aura abouthighlander has a spectacular aura abouthighlander has a spectacular aura about
+1. A lot of people overlook the fact that the driver is at least 50% of how well you do at competition. A lot of the top teams spend years training their drivers before they even get to drive at competition. Make sure to chunk in time in your schedule to practice with your drive base.
Unread 11-06-2014, 15:29
asid61's Avatar
AKA: Anand Rajamani
FRC #1072 (MVRT)
Totally true. Driver practice is the bomb.
Unread 11-06-2014, 15:44
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
IMHO steel is a acceptable material for making a robot drive train. I like it because it will keep the weight down low to improve your COG. Steel is appx 3 times heavier than alum but designed correctly can be much stronger/ less costly in the same size package.
Steel is much cheaper in terms of cost/lbs vs alum. CRS and stainless sheet is readily available from material suppliers. Steel can be easily spotwelded and mig welded. Welding steel is much easier than welding alum. Laser cutting light guage steel is significantly faster than cutting the same thickness aluminum.
Here's some stats you can use for you analysis
Cost/lbs of Cold roll sheet sheet is appx. .55/lbs
Cost of Alum 5052 is appx 2.00/lbs
density of steel is .29 lbs/sqft alum .098 for alum.
Take a look at using .036 or .048 CRS for your sheet stock and using .065" thin wall 2x1 , 1x1 tube.
Here's a website of a company that can laser cut tubes. Think of designing tab and notches to click together your frame and use the sheet metal as gussets and brackets
http://www.tubeservice.com/index.html
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
