#31
Re: Why is swerve so slow?
We try to build robots that can complete the game challenges in the simplest, most efficient manner (in both design and implementation). We have not seen a game where our primary scoring objectives cannot be efficiently accomplished by a 6/8 wheel drive. There may be games in the future where this is no longer true, but (I'm practicing my Pat Fairbank-isms here) we'll burn that bridge when we get to it. We've talked about building one as an academic exercise but I think there is enough community experience on the subject that we could put something together, if we needed to, without a homegrown proof of concept. Now for other teams, this could be different. Swerve drives are incredibly cool and building them definitely inspires a lot of students every year. It's a hard engineering challenge which some people may want to try out, and that is awesome. We just concentrate on other things. |
#33
#34
It will only ever let you drive smooth splines essentially, so you're always carrying your speed with you. You can still do very tight radius (and at no speed zero radius) turns. They then have multiple (maybe just one?) other modes they toggle into for strafing variants. 16 could explain better, but I think I got the jist of it. I feel video of their 2012 bot shows this pretty well. |
#36
We are in 4-wheel (Ackermann?) steering that is NOT field-centric by default. In that mode we maintain a lot of our momentum because the turns are very smooth. When the driver needs to make a quick maneuver, he pulls (and holds) the trigger on the joystick to enable crab that IS field-centric from the orientation of the robot when the trigger was pulled. The driver has the x and y motion on one joystick and a twist motion on the other. When the trigger is released, the driver is back in 4-wheel steering mode.
#37
We have toyed with other driving/aiming modes, but they are just variants of those two basic functions. |
#38
What do you mean by monster truck steering?
#39
List of reasons swerve is "slower" than a traditional skid steer. Reasons may not be valid for all swerve variants.
-Likely has more stages of power transmission, and if using bevel gears has more inefficient power transmission. A good skid-steer is typically 2-3 stages of decent spur gears. A swerve could be 3-4 stages easy. Motor in module variants are an exception. This changes a drive efficiency from a possibly 90% to maybe around 70% (made up numbers!) -For the same reasons as above, there is likely more rotating mass (inertia) in the drive to accelerate, this could easily be a few percentage points slowdown. -Steering error. The odds of all your modules pointing perfect is low, there are likely appreciable losses due to friction here. -Steering time. It takes time to steer the modules to where they want to go, and teams have different methods for dealing with this. Some assume it's instantaneous as they gear it fast, but this leads to a lot of the above error on the way there, which wastes battery and heats the motors more. Some teams turn power down until wheels are pointing where they want to go, and this also obviously adds a delay as the drive must wait before it starts really going. -Weight Transfer. Depending on the exact gearing, CG, overall robot geometry, tread, etc... it's possible that during initial acceleration enough weight is transferred such that half your wheels are now breaking traction. Even if this happened for .1-.2 s it would appreciably slow you down. This is only valid for independently powered modules. -Driving style/Control Scheme. Except for 16, most famous swerves have been driven by point to point drivers. As Tom pointed out top drivers on skid steer are forced to learn to carry their momentum to be quick. Many swerves don't do this. If we swerve again, we will spend time looking at this. There are more reasons, and if I think of them I'll edit and add them. None of the above are huge, but a few small things could easily add up to make something seem/feel a bit slower. Maybe if I get a good block of time I'll model the above and see if I can point out a difference. |
#41
Like most robots, it's not hard to learn the basics, but it takes hours and hours of practice to get good. There's no time to stop and think behind he glass. |
#42
You have gas (speed) and steering angle inputs. All four wheels turn to create the desired robot turn. Wheel stop turns will spin about the center of the robot with no translation.
#43
I didn't know monster trucks drove like that ![]() |
#44
We noticed our drivetrain chewed up batteries much faster when we swapped the Denso window motors for the AM 9012. |
#45
You killed that chair...
