| I'll pick you up anytime. (with a claw) |
Re: Attaching Things on WCD
Well what I mean is say I want to mount an arm or any other part onto the chassis. I just don't know where the mounting point would be at
We usually weld some plates to the bottom of whatever our superstructure is, and then those plates can then bolt to the top of the siderails. This makes it really easy to remove the structure, and there are plenty of ways you can mount to still be really strong.
Almost all of ours WCD robots have ended up with a crossmember that bolts to the top of the siderails. Check out our 2011 CAD for reference in my sig.
I'll post a picture of what I have so far with the drivetrain I am designing.
#7
Yeah, you use small plates with holes in them and rivet them to the parts they attach to. Rivets are really strong but can be drilled out easily if you use aluminum.
#8
It appears as if you are using 3x1 tubing. Most teams use aluminum 2x1 in their drives since it's lighter and is still plenty strong to get the job done.
#9
You can mount things just about anywhere. We made simple brackets to attach our superstructure this year:
https://drive.google.com/file/d/0B4u...it?usp=sharing EDIT: Quote:
#10
Edit: Here's a view of one of our superstructure attachment points from our 2014 comp bot. ![]() Last edited by DampRobot : 15-06-2014 at 02:15. |
#11
Generally, the superstructure is what things get attached to, it can be pemanently attached via welding, temporarily attached through rivets (use steel), or Bolted on with nuts and bolts. As posted above, the superstructure can even be made removable for easy changes to the drive base.
One small suggestion, have you thought about 3Cim gearboxes? They are an easy way to increase the torque available on your robot and make it generally faster. Awesome to see more Oregon Teams on CD, good luck! |
#12
We just gusseted our upper structure stuff right to the side of the rails with rivets. The rivets had low enough heads so they wouldn't contact the wheels. The other set of gussets were in a funky shape to avoid the bumper support, but overall it worked very well.
#13
If you don't know what you're doing, a 6 CIM drive could show little benefit, and sometimes even hinder your drivetrain. They're useful if you're purposefully planning on optimizing for their advantages, but otherwise I'd stick with 4 CIM drives. They're just as good, and won't give you problems if you don't plan for everything (source: used two 6 CIM transmissions on two different robots - transmissions were fine but didn't get much of an advantage from them because there wasn't much correct optimization).
#15
