Go to Post Looks like it will be to your advantage to keep the Refs happy. Remember, Donuts go a long way toward that end! - billbo911 [more]
Unread 15-06-2014, 17:04
JorgeReyes JorgeReyes is offline
Team Captain
FRC #2002 (Tualatin Robotics)
JorgeReyes is an unknown quantity at this point
Re: Attaching Things on WC
Originally Posted by Dunngeon View Post
Generally, the superstructure is what things get attached to, it can be pemanently attached via welding, temporarily attached through rivets (use steel), or Bolted on with nuts and bolts. As posted above, the superstructure can even be made removable for easy changes to the drive base.
One small suggestion, have you thought about 3Cim gearboxes? They are an easy way to increase the torque available on your robot and make it generally faster.
Awesome to see more Oregon Teams on CD, good luck!
I've been considering 3 cim gearboxes but I am worried about the cost of getting them. If we find a way to set aside a bigger budget for our drivetrain then we might switch to 6 cims
