Go to Post We don't just build robots. We build people. - Koko Ed [more]
Unread 15-06-2014, 17:11
Andrew Lawrence
Posts: n/a
Re: Attaching Things on WC
Originally Posted by JorgeReyes View Post
I've been considering 3 cim gearboxes but I am worried about the cost of getting them. If we find a way to set aside a bigger budget for our drivetrain then we might switch to 6 cims
If you don't know what you're doing, a 6 CIM drive could show little benefit, and sometimes even hinder your drivetrain. They're useful if you're purposefully planning on optimizing for their advantages, but otherwise I'd stick with 4 CIM drives. They're just as good, and won't give you problems if you don't plan for everything (source: used two 6 CIM transmissions on two different robots - transmissions were fine but didn't get much of an advantage from them because there wasn't much correct optimization).
Unread 15-06-2014, 17:17
JorgeReyes JorgeReyes is offline
Team Captain
FRC #2002 (Tualatin Robotics)
JorgeReyes is an unknown quantity at this point
By this do you mean calculating the correct gear ratios to use?
Unread 15-06-2014, 17:29
Chris is me's Avatar
AKA: Pinecone
There's a range of ratios where you're geared too fast to push continuously anyways but too slow to really get an acceleration benefit. It's around the 9-12 FPS range depending on who you ask. I would recommend experimenting with 4 vs 6 CIMS on your own in the off season to get a better grasp on how they help. 4 CIMS is perfectly adequate for a lot of robots; the jump from 4 to 6 CIMS is a lot less dramatic than the jump from 2 to 4.
If your budget is constraining your design I would probably stick with 4 unless you want a drive in the 5-9 FPS range (you'll be able to push for longer stretches of time before tripping a breaker), or you are going 13+ FPS at full weight (acceleration is noticeably better). Even in these ranges it's not mandatory to go with extra motors.
Unread 15-06-2014, 17:30
Andrew Lawrence
Posts: n/a
Not just gear ratios. You need to know how you'll be using your robot. If it's acceleration Have a target distance you want to travel to (ie. 13.5 ft), and optimize the acceleration to reach that distance in as little time possible. Remember, the higher the gear reduction, the more the effects of acceleration are noticeable, but that also means you'll be moving slower. You need to find the happy medium where your speed is high enough to utilize the high acceleration to get to your target distance as quickly as possible, but your speed has to be low enough to make the acceleration effects noticeable. You can play around with numbers in the JVN design calc and JVN's acceleration spreadsheet, and see what works out best. A good thing to do is set a speed for a 4 CIM drive, then change the number of motors to 6 CIMs, and see how the time to distance changes. If it's significant, it's worth using. If it's insignificant, the extra motors aren't helping. Of course results may vary, but from some quick testing I did over the past year I've found that for most usable speeds in FRC at common target distances, the average amount of time shaved off from travel time between point A and point B is no more than a quarter second at most, which I'd consider not being worth it. That being said, this was assuming a total robot weight of ~110 lbs. Lighter robots will feel the effects of acceleration a lot more.
Another thing to optimize for in 6 CIM drives is torque, especially if using a PTO. Torque is straightforward - the greater the reduction, the more torque there is. However it is still something to optimize for if you are using PTO.
Like I said - it is all dependent on how your team sees things and the data you get from testing and doing your own math. My experiences over the past year have made me come to believe that unless you are using a PTO, a 4 CIM transmission will get the job done just as well, without the danger of tripping the main breaker and without the extra 5.64 lbs of the two other CIMs. While these are my experiences, the best way to make a decision is to go out and test things out for yourself.
Unread 15-06-2014, 17:45
AKA: Pinecone
Re: Attaching Things on WCD
Here's one example of how we attach super structures to our base frame. In 2012 we did something similar to what DampRobot posted, and in 2013 our superstructure consisted of four 1/4" plates serving as a gearbox and arm mount. Not a great example for general purpose robot building.
The white superstructure frame was welded at the ends to 1x1 1/8" wall box tubing. The tubing had a 3/16 rivet hole pattern in it, as we try to do for all of our parts, so we drilled out 4 holes per side for #10 clearance. The tops were drilled out for tool clearance. The corresponding holes on the chassis were drilled out and 10-32 rivnuts were installed. Rivnuts are awesome as they let you bolt things together to material of any thickness without having to hold a nut anywhere. To install or remove the entire superstructure we just screw 8 bolts in or out.
There are a number of ways to attach things to the frame without welding them to another member. Flat gusset can do a lot if you pay attention to how these gussets are loaded. The VersaChassis 90 degree bent gusset is also a big help.
Unread 16-06-2014, 00:20
Team Captain
I think I might completely change my chassis design to something like this because I was also looking at the chassis from 1241 and it looks extremely light and really easy to attach anything.
Unread 16-06-2014, 00:22
Team Captain
Weren't there only 6 cims allowed? It looks like you have 8 in the picture
Unread 16-06-2014, 00:28
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Two of the pictured motors are miniCIMs.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 16-06-2014, 03:06
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
This is a picture of our chassis, it isn't a WCD, but it is simpler for us to manufacture requiring only 2x1 al tubing, steel pop rivets, and a standardized aluminum gusset.
On the sides, you can see the gusset plates and the bolts that supported the intake structure. Our biggest problem with the chassis was the lack of super structure, made mounting many things harder, so depending on the game next year we will be adding a superstructure to assist in mounting game components.
Those plates to mount the intake structure were later modified, because they became increasingly cockeyed as the bolts deformed the aluminum tubing wall. Our solution was to create a wider contact structure and use 8 pop rivets to distribute the load better.
Also note it was in fact a 6wd later in the season, just not in this picture
http://team955.com/gallery3/var/albu...G?m=1394932723
(2015-?): 973
(2012-2015): 955
Unread 16-06-2014, 08:42
Bumpers are always a nice addition. Just saying...
Unread 16-06-2014, 14:26
Team Captain
Initially I was thinking of going with a welded chassis design but after getting all this advice I think I am also going to go with a riveted design because it seems much easier to mount things or change things around
Unread 16-06-2014, 14:43
Andrew Lawrence
Posts: n/a
A lot of teams do a mixture of both welding and gusseting, sometimes even both in the same place. Sometimes there are places where gusseting isn't the easiest to do - in which case don't be afraid to use welding.
tl;dr: If you have two ways of attachment, don't limit your design by only choosing one.
Unread 16-06-2014, 14:55
JohnFogarty's Avatar
AKA: @doctorfogarty
Yeah, doesn't 254 do both welding and gusseting. Their frame was so easily visible this season that was the one thing that stuck out in my mind that they did a lot of.
John Fogarty
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632, FRC 4901
Unread 16-06-2014, 16:27
Andrew Lawrence
Posts: n/a
Yes - as seen by this high definition picture of Barrage, they weld, gusset, and weld gussets.
Unread 16-06-2014, 17:04
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #1072 (Harker Robotics)
I never got the point of that. Why would they weld after gusseting? Gussets are pretty strong and can be removed if there is a problem.
