Go to Post I'd like to thank FIRST for giving me this wonderful opportunity. I've learned so much! - Leav [more]
  #31   Spotlight this post!
Unread 16-06-2014, 17:25
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Attaching Things on WCD
Originally Posted by asid61 View Post
I never got the point of that. Why would they weld after gusseting? Gussets are pretty strong and can be removed if there is a problem.
Many teams use gussets as a jig for welding. We pretty much always gusset before welding, it makes life a lot easier.
R.C.
MadTown Robotics Team 1323
  #32   Spotlight this post!
Unread 16-06-2014, 17:27
Mike Marandola Mike Marandola is online now
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Probably for just added security. As you can see, they welded the gussets on the parts that need to be strong such as the main center frame and the pickup. It would also be a lot easier to keep the gussets positioned on the tubing during welding if they are riveted first.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
  #33   Spotlight this post!
Unread 18-06-2014, 01:24
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Then the real question is why weld? You've already got the gusset, and I can't think of a time when I saw a gusset fail in a way a weld wouldn't.
-Plutarch
  #34   Spotlight this post!
Unread 18-06-2014, 01:26
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (Harker Robotics)
That's what I was thinking. According to one of our older mentors, welding actually reduces the strength of aluminum unless it's heat treated afterwards.
I've never welded before though, so I wouldn't know myself.
  #35   Spotlight this post!
Unread 18-06-2014, 08:28
Chris is me's Avatar
AKA: Pinecone
Welding can reduce the strength of aluminum in terms of overall material properties, but that is a lot different than saying a welded joint is less strong than a riveted gusseted joint.
