Thread Tools |
Rating:
Display Modes |
Re: Pneumatics system code
I suspect from your photo that it is a 24v solenoid just because that's what has been offered in the KOP, but that style can be either voltage rating. The black end caps will have a voltage printed on them.
If it is a 24v solenoid, then it gets wired to two sets of pins on the Solenoid Breakout and the Solenoid Breakout must get 24v power from the empty connectors of the Power Distribution's special 24v output. |
I should be able to use the code above posted by Domenic Rodriguez correct? |
Correct, that code looks good.
I tried out the code but it did not work out.
If I am right the spike has a light that is supposed to flash when I pressed the assigned button on my joystick. Also on my driver station when a activate any of the other functions such as (movement, or intake motors) the voltage spikes, is that not supposed to happen when a press the button assigned to the pneumatics spike. None of the things is happening, so I don't know what to exactly do. I am sitting here with my team so any immediate help would be greatly appreciated. |
Please provide a copy of your code for this.
Also, what is the LED on the spike doing? (Blink Status & Color) |
