Go to Post Several West Coast teams have attended IRI. I don't know of a single team from east of the Rockies that has attended ANY West Coast off-season. So who is afraid of who? - ChrisH [more]
Unread 17-06-2014, 21:14
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
Pickup System Fix
With so many offseason right around the corner we looked back at our robot today and saw the piece we "Innovated". We were wondering if there was a better solution or a better part we could use.
The piece basically connects our pneumatics cylinder to our mechanism. Any ideas?
2014 Dallas Semi-Finalist (Thanks 3847 & 231)
2014 OKC Semi-Finalist (Thanks 2341 & 2461)
Unread 17-06-2014, 22:27
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: Pickup System Fix
Are you just looking to replace the zip ties or the entire mounting setup? I assume there is a clevis in there to attach to you mechanism, and if you simply want to replace the zip ties, we have found that a simple piece of rubber hose that fits over the cylinder's shaft. We used some 1/4" air line on a smaller cylinder this year. It is nice because it provides an easily customized stop position and also a cushion when the cylinder retracts.
If that isn't what you meant, at least it could eliminate the zip tie jungle...
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 17-06-2014, 22:59
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
You will seriously reduce the forces in your linkage if you mount the cylinder more horizontally, rather than vertically.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 18-06-2014, 03:54
Knufire Knufire is online now
I believe what you're looking for is called a clevice. There should be a section for them on McMaster-Carr. Depending on your machining resources, they're not a particularly hard part to make yourself either. Essentially it's just a block of metal with a threaded hole on one face and a through hole perpendicular to it.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 18-06-2014, 07:40
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
if your talking about the zip ties than you could get some PVC round tubing that has an ID slightly larger than the bore of the piston and use it as a spacer. just make sure that the OD is large enough that it doesn't hit the bushing on the inside of the cylinder
Also you could try to move the piston back a hole so that it isn't as vertical and more on an angle instead (as long as it doesn't impact your ability to intake a ball).
Matthew Lantry
Team 4475 2014-present
-College Mentor 2014-????
Team 1676- 2011-2014
-Mechanical 2011-2014, Subteam leader 2013-2014
-Robot Operator 2014
George G. White FLL mentor 2011-2014
“Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute.”
Unread 18-06-2014, 13:59
autox_vette autox_vette is offline
FRC #2451 (PWNAGE)
autox_vette is on a distinguished road
We used a shaft collar this year to limit the stroke on one of our air cylinders. McMaster has lots of different sizes so you should be able to find one the right size, or take one smaller and drill it out a bit to fit the shaft correctly. Very easy way to adjust the travel of a cylinder as a tuning mechanism.
Unread 18-06-2014, 14:51
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
I completely misunderstood your question. You are asking for a solution for replacing the stack of wireties and the hose clamp right?
We limit the stroke of our cylinders with simple lengths of aluminum tubing. See the stroke limiting spacer on the cylinders that change the elevation angle of our shooter from 2013, below.
Todd F.
Photo gallery
video channel
Triple Helix mobile
