Go to Post Perfection of a system comes not when you can add nothing more but instead when you can remove nothing. - Andrew Schreiber [more]
Unread 18-06-2014, 07:40
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
Re: Pickup System Fix
if your talking about the zip ties than you could get some PVC round tubing that has an ID slightly larger than the bore of the piston and use it as a spacer. just make sure that the OD is large enough that it doesn't hit the bushing on the inside of the cylinder
Also you could try to move the piston back a hole so that it isn't as vertical and more on an angle instead (as long as it doesn't impact your ability to intake a ball).
Matthew Lantry
Team 4475 2014-present
-College Mentor 2014-????
Team 1676- 2011-2014
-Mechanical 2011-2014, Subteam leader 2013-2014
-Robot Operator 2014
George G. White FLL mentor 2011-2014
“Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute.”
